Question about John Deere Garden
JD5 LOG SPLITTER
NO FIRE TO ENGINE
My kohler engine on my oregon log splitter will start but will only run for about 1 minute before cutting off
I had a similar problem (only not with a log splitter). The problem was that the fuel filter was clogged. When the motor was off, the dirt would fall down to the lower side of the filter, allowing fuel to pass until the fuel was flowing again. It may not be your answer but it's an easy and low-cost fix. Best of luck!
Oct 23, 2016 | Cars & Trucks
Works for 15 min and then ,the ram moves to log and stops,checked fluid ok, voltage 115 ok
My thought is that there is air in the line. I had problem like that with my splitter. To cure it I had to stand the splitter on end because the oil fill is at the wedge end. I filled it. set it back horizontal and cycled the ram full length 3 times. I stood it on end again and could add more fluid. When I filled again it was now full of fluid and works properly. It also could be that the splitter is not powerful enough to split that size log down the middle. I must take a smaller bite then it works.
Dec 13, 2015 | Earthquake 5 - Ton Electric Log Splitter
Splitter runs through the cycle too slow
Make sure you hydrolic fluid tank has the proper amount of fluid.
Sep 11, 2014 | Swisher 28 Ton 11.5 HP Log Splitter -...
Masport log splitter how do you rewire a 7tonne pressure log splitter
Make sure the device is unplugged from the 240 VAC power source.
Connect the 240 VAC line and neutral wires to the momentary switch. Examine the motor wires to determine line and neutral.
This log splitter is equipped with a control system that requires to be operated by both hands of the user - Left hand controls the
hydraulic control lever while right hand controls the pushbutton
switch. The log splitter will freeze upon absence of either hand. Only
after both hands release the controls, the log pusher starts to return
backward to the starting position.
http://www.masport.co.nz/common/download/556964/
Hope this helped.
Apr 20, 2014 | Tools & Hardware - Others
Log splitter blows fuses
It now has a bad dead short in the wiring and that is why the fuse keeps blowing.. Check for bad wiring
Mar 07, 2014 | Cars & Trucks
Adding hydrolic oil to yardworks 4-ton wood spliter
Replace the Hydraulic oil in the log splitter after
every 150 hours of use. Take following steps to
replace it.
  1. Make sure all moving parts stops and the log splitter is unplugged.
  2. Unscrew Oil Drain Bolt with Dipstick to remove it.
  3. Turn the log splitter on the Support Leg side over an 4 liters capacity container to drain the hydraulic oil off.
  4. Turn the log splitter on the the motor side.
  5. Refill fresh hydraulic oil at the volume as per the hydraulic oil capacity of a particular model indicated in above specifications table.
  6. Clean the surface of Dipstick on the Oil Drain Bolt and put it back into the oil tank while keep the log splitter vertically.
  7. Make sure the level of the refilled oil is just between 2 grooves around the Dipstick.
  8. Clean the Oil Drain Bolt before thread them back. Make sure they are tightened to avoid leakage before place the log splitter horizontally.
Periodically check oil level to ensure it is between
2 grooves around the Dipstick. Upon Lower oil
level, oil refilling is required.
Source:
http://www.qci.net/files/5_Ton_Log_Splitter_-_USE_THIS_MANUAL.pdf
Sep 22, 2013 | Hardware & Accessories
Looking for manual for old Sears (ca 1981) log splitter
I have the same splitter. I can copy the manual and send it to you in a few weeks if you'd like. Email me direct at mike AT swedishbrickyard DOT com.
Jun 01, 2010 | Sears Heavy Machinery
Swisher 22-Ton 7 HP Log Splitter #LS722
For all swisher log splitter problems go to swisherinc.com.
Dec 10, 2008 | Garden
Garden Logo
14 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
