SOME ONE TO THE AC OUT A LONG TIME AGO AND CUT THE WIRES FOR IT UNDER THE HOOD NEED ELECTRICAL DIAGRAM
    Sergeant:
  • 340 Answers
Not for free
Posted on Jun 19, 2009
  • taa43 Jun 19, 2009
    not for free
1983 F-250 XLT, 5.8L. Where can I get a under hood wiring diagram?
Obtain a good work shop manual the wiring diagram should be in the back.
Sep 29, 2015 | Ford F-250 Cars & Trucks
Need vacume diagram /routing 1984 B series pick up
We do not have thses diagrams. There is a sticker under the hood that has the routing diagrams.
Sep 27, 2012 | 1987 Mazda B-Series
Someone cut all wires took some off so I need to see a diagram to get them back on
My suggestion is to go to www.searspartsdirect,com and put in your model # (Under Seat). Then you should be able to see the electrical diagram for your tractor.
Jun 21, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
The air is not cool when idling, it blows warm. Also the setting 1 and 2 doesnt work, only 3 and for makes air blow.
Sounds like 2 different problems here. The ac gets warm when standing idle, is most likely the under hood fan not kicking on when ac is on. This may be a fuse issue or a relay. When ac is on, the fan should be on all the time. Relay maybe in an electrical box under the hood. Unplug the fan and test for power with a test light to see if the fan has power when ac is "on".
The inside fan not working on levels 1& 2 is likely the voltage ballast issue. this is an electrical block which controls voltage to change fan speeds. Usually found under the passenger side dash, right in the air flow comming from the fan and inside the air flow housing. Usually held in by 2 or 3 screws with a connector and 3-4 wires sticking out. this should be under $20 to buy and quite easy to change, if you can find it. Try behind glove box etc. Do not test the new one without it being in place, as it may burn out very quickly without the air flow to cool it.
Good luck
Apr 30, 2011 | 2002 Chevrolet Cavalier Coupe
I have an 1987 buick t- type regal need wiring diagram for ignition the recent owners put a 455 in wires under hood coming out of fire wall have been cut out. like to get a wiring diagram, to re-wire the...
If you purchase a repair manual it will contain the wiring diagram. Your local auto parts store sells these books. They may have to order the one you need. Also any book store can order what you need.
Two publishers are Chiltons and Hayes.
Mar 06, 2010 | 1987 Buick Regal
I was clean under the hood found alot of wiring
You can go to autozonecom and register for full free online repair manual with all the diagrams you could need. Along with everything else you could need.
Nov 18, 2009 | Oldsmobile Cutlass Calais Cars & Trucks
1993 Lexus ES300,Heater/AC dont work and lights, also Gear light
YOU NEED A ELECTRICAL DIAGRAM TO FIX THE WIRES.REPLACE THE FUSE YOU BLOWED.GET A HAYNES REPAIR MANUAL IT HAS YOUR CAR ELECTRICAL DIAGRAMS.
Nov 13, 2009 | 1993 Lexus Es 300
I have a 2000 Ford Windstar. While driving the other day I lost all electrical power. Nothing would work and engine cut off. After sitting for a brief time the van cranked back up and I drove it home. ...
Most probably...a loose electrical connection. Since you mentioned that the electrical power and the engine got cut off and after sitting for a brief of time, the van cranked back up. You need to check the wiring to see if there's any loose connection.
Here, I provided you the link where you can download the wiring diagram for your 2000 Ford Windstar:
http://www.installdr.com/InstallDocs/FLM/PDF/356021.pdf
This diagram (manual) will help you trace the problem.
Have a great day!
Jun 06, 2009 | 2003 Ford Windstar
Wiring diagram
Do you have any connectors left intact? All you should need is the alternator power, grd, starter, distributor power, advance
Jul 23, 2008 | 1986 Chevrolet Monte Carlo
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
