Question about Char-Broil CharBroil Master Flame Gas Barbecue Grill
No gas flow from barbecue
I cleaned barbecue with power washer & now have no gas flow when switching on grill.
  • Marvin
    Marvin May 11, 2010
    use a heat gun and dry out the burners
    President:
  • 1,185 Answers
If you used a power washer you may have driven rubbish into inlets for the burners, or as my collegue has already pointed out, water.
If the BB is empty then turn it upside down onto some newspaper and see if you get a water discharge..
The gas is normally supplied through a hole into the burners and is mixed with air on the way in so that it combusts out of the holes on the burner
If none of them are lighting I would do the upside down bit first , if that does not fix it then start looking at the gas inlets
Posted on Jun 19, 2009
Barbecue won't stay lit
make sure the propaine is not to low and the burner orafice is clean
Oct 13, 2014 | Char-Broil CharBroil Master Flame Gas...
Tip
How To Keep Barbecue Grill Grate Clean and Rust Free
<utube src="qFo0unxnSHQ"></utube>This video will show you how to clean and keep your barbecue grill grate clean and rust free.
on Aug 04, 2013 | Grilling
Gas grill no flow of gas
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 14, 2014 | Kenmore 700 sq. in. Cooking Area Gas Grill...
I am looking for an owner's manual for a Napoleon Prestige 1 natural gas barbecue. Also, could you please tell me what purpose is served by the middle of the three knobs that control the gas flow....
Peter, the center control knob of the cluster of 3 in the middle of the control panel, is for the rear rotisserie burner.
To help you further, I have included a link to your discontinued model, that you can download and print for future reference. It covers both Propane & Natural Gas Models.
http://www.napoleongrills.com/Care/manuals/PT600RBI.pdf
I hope this helped you and Happy Grilling!!
Jun 29, 2011 | Napoleon Prestige I P600RB Propane Grill
My Char Broil gas grills flame is taller than it should be( not blue at all anymore) and make the food smokey?
You need to clean the burners/pathways, its not getting enough oxygen and the flame is starved.
Sep 05, 2009 | Char-Broil CharBroil Master Flame Gas...
Should I clean the ashes out of my grill
yes. To do this just be sure that the ashes are completely cold and use a vacuum cleaner.
Aug 28, 2009 | Char-Broil CharBroil Master Flame Gas...
Yes, if you have gas flow from your cylinder, then nothing when you turn on the valve on the grill..(You should hear...and smell the gas), then the problem is either in the regulator assembly or in the valve. Both items are cheap and easy to replace and parts are abundent at most hardware stores.
Jun 19, 2009 | Char-Broil CharBroil Big Easy 8000...
Gas grill prob.
Barbecue Repair Parts Don't let spiders crawl into your venturis, yearly maintenance part are available. 27897.jpg?qlt=80&cell=325,325&cvt=jpeg If you notice that your Barbecue is getting hard to light or that the flame isn't as strong as it should be, take the time to check and clean the VENTURIS. 27898.jpg?qlt=80&cell=325,325&cvt=jpeg In some areas of the country, spiders or small inserts have been known to create "flashback" problems. The spiders spin webs, build nests, and lay eggs in the BARBECUE VENTURI TUBE (s)obstructing the flow of gas to the BURNER. The backed-up gas can ignite in the venturis behind the control panel. This is known as a flashback, and it can damage your Barbecue and even cause injury. To prevent flashbacks and ensure good performance the BARBECUE BURNER and VENTURI assembly should be removed from the grill and cleaned before use whenever the BARBECUE has been idle for an extended period of time.
Also, when you lite the BBQ, make sure that you turn the gas on at the tank, wait a couple of minutes and then turn the knob on and light the burner. This is to make sure that the pressure is regulated and sufficient prior to lighting.
Hope this helps!
Sep 01, 2008 | Grilling
Bunners do not get hot
Hope this helps!
Apr 20, 2008 | Coleman LG40811E Grill
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
Grilling Logo
449 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Jim Thurston
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
