Question about Sharp CD-SW340 Shelf System
Set timer on cmtnez30 without remote
Set recoding timer without remote
Need operators manual for Toshiba SE-R0071 remote
I don't know how to recode but you can get the manual by googling Toshiba Toshiba SE-R0071 Manual
Mike
Mar 20, 2016 | Toshiba TheaterWide 52HM84 52" Rear...
Emerson lc407em1 sleep timer without remote
Without its remote control, you can't set the sleep timer. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Mar 16, 2014 | Emerson Used Original LC407EM1 Remote...
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
I got a Sony CMT-NEZ30 from a friend and I don't
Get the manual , which a simple search engine query for "sony CMT-NEZ30 remote" would have led immediately to...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CMTNEZ30
As far as remote failures go...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jul 28, 2011 | Sony CMT-NEZ30 Shelf System
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
Remote won't work even with new battery. Does it
you will yes my dad had this problem with his merc and you will just need it recoding or erhaps a new set of keys and recipors in the car.
Nov 30, 2009 | 2001 Porsche Boxster
I need a manual to recode the remote to work with my Hitachi TV
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
May 25, 2009 | One For All URC4220 Remote Control
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
Aug 19, 2008 | Audio Players & Recorders
Cannot recode new remote
Hmmm, See if you can borrow someone's remote from their set to get back into the swing of things...accordianman
Oct 15, 2007 | Philips Magnavox 27MS343S 27" TV
How to set timer without remote
Nope, Im sorry to say you have to use the original for these functions to work. Go to http://www.remotes.com and get the proper remote.
Sep 27, 2006 | Toshiba MV13P2 13 in. TV/VCR Combo
Sharp CD-SW340 Shelf System Logo
29 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
