Question about GE Profile TPX24PBDCC Side by Side Refrigerator
Water leaking from underneath GE Provile Refrigerator TFX28PB
Water leaking from underneath GE Profile Refrigerator TFX28PB on the refrigerator side of the unit. I have turned off the water valve going to the refrigerator, but it is still leaking.
  • andrea_longf Jun 22, 2009
    The water supply tubing was the issue at the very back where the coils and fan are located at the coupling junction. The polyethelyene tubing gets rigid over time and had cracked beyond repair and being able to reconnect. I had to replace the entire tubing - only about $3 worth and a new coupling - another $3. It should hold.
  • 10,515 Answers
Hi.
Analyzing the likely source ( There might be more than 1 reason for water leaking underneath )
Instructions
STEP 1: Move the refrigerator out from the wall and look for the location of the leak. STEP 2: Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem. STEP 3: Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker. STEP 4: Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Instructions
STEP 1: Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely. STEP 2: Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly). STEP 3: If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls. Fixing a drip-pan problem
Instructions
STEP 1: Pull off the grill that runs along the bottom of your refrigerator. STEP 2: Locate the drip pan, using a flashlight if necessary. The pan should be sitting on top of a set of black condenser coils and directly below a drain tube that carries water from your freezer when it is in defrost mode. STEP 3: Place the drip pan in your sink and fill it with water to test for leaks. If it leaks, order a replacement from your appliance dealer. STEP 4: If the drip pan doesn't leak, clean it with warm, soapy water, then reinstall the pan and the refrigerator grill. Fixing a clogged defrost drain
Instructions
STEP 1: Locate the defrost drain. It should be a round hole or a channel running under the vegetable and fruit bins in the refrigerator or along the floor of the freezer compartment. STEP 2: Inspect the drain for clogs and remove any debris. If necessary, use a small screwdriver to break up debris that's trapped in the drain hole. STEP 3: Fill a meat baster with hot water and force it through the drain to make sure the clog is gone. If the drain is operating properly, the hot water will fill the drip pan. Fixing a leaky ice maker
Instructions
STEP 1: Pull the refrigerator away from the wall and locate the copper water-supply line. It runs from the house water line to the refrigerator water-supply valve. (To get to the supply valve, you may have to use a screwdriver or a nut driver and socket to remove your refrigerator's back access panel.) STEP 2: Inspect the copper supply line, the supply valve, and the plastic supply tube that runs from the other side of the supply valve to the back of the ice maker. STEP 3: If a connection is leaking, tighten it with an adjustable wrench. If either the copper supply line or the plastic supply tube is leaking, you need to replace it. STEP 4: Turn off the water supply. The valve may be under the kitchen sink or connected to a cold-water pipe in your basement. STEP 5: Remove the faulty line and take it to a hardware store to get an exact replacement. STEP 6: Install the new line, tighten the connections with the adjustable wrench and turn the water back on. Overall Things You'll Need
Meat Baster
Adjustable Pliers
Adjustable Wrench
Soap
Nut Driver And Socket
Replacement Parts
Flashlight
Screwdriver
Who Can Help
Find Prescreened Appliance - Repair or Service Contractors at ServiceMagic.com
Overall Tips & Warnings
To keep door gaskets clean and supple, wash them twice a year with warm, soapy water, then coat them with a light film of petroleum jelly.
Some refrigerators have an internal defrost drain that is meant to be serviced by a professional. If you can't find your drain, call a pro.
To prevent possible electrical shock, always unplug your refrigerator before working on it.
Put carpet scraps or another soft material under the front legs before pulling your refrigerator away from the wall. Otherwise, the legs could damage the flooring.
2 Simple steps put by one more expert :-
  1. Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
  2. Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
ONE POPULAR REASON :-
OK, You need to unplug for a hour or so. Remove the rear panel in back of freezer to expose the evaporator coils. At the bottom of the evaporator there is a tray that catches the defrost water to take it through the back and down to the condensate tray located near compressor and condenser fan. Most likely you have ice or something trapped in that drain beginning in the freezer. I have heard some people turn the freezer temperatures so cold ice will form before the water can drain. If you still have problem contact me
Thanks for using "Fixya".
Posted on Jun 23, 2009
    Sergeant:
  • 326 Answers
First, your most pressing issue: the water on the floor.
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from coming out the freezer door and leaking onto your floor.
Now, for issue #2, your water dispenser: If you take the front grill off, you will see a plastic tube going through the hinge. There is a coupler, usually a insta-push type just before that. If you push on the collar of the fitting toward the center of the fitting while pulling (not real hard) on the tubing, the tube will come off. Now, try the water dispenser to see of any water comes out the disconnected tube. If yes, comment back to me to see how to fix this, if no water comes out, you most likely have a bad water valve. Reconnect the water line by just pushing it back into the fitting. Disconnect the outlet side of the water line at the water valve and try the dispenser again. No water out the valve almost always will be a bad valve. (there are rare exceptions) Water out valve now when dispenser is pressed equals a frozen water tank or water filter in the fresh foods compartment. Issue #3, your uncovered foods: All the cooling for a refrigerator takes place in the freezer compartment, and some of the cold air is circulated into the fresh foods compartment to cool it. As the air is circulated throughout the entire refrig / freezer, air picks up and transfers odors to uncovered items, including ice. Cover foods and use an open box of baking soda to help absorb odors
Posted on Jun 19, 2009
My GE Profile refrigerator leaks water from the freezer. I find a puddle under it 2x/week.
Defrost drain tube clogged, drain pan cracked, water tubing near compressor gets brittle and leaks, critters chew on water tubing also.
Oct 29, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile Arctica refrigerator - water is leaking from the punctured plastic hose going up to the water filter (plastic hose from the bottom of the solenoid goes into refrigerator assembly)....
Good day!!!!
Refrigerators with a defrost cycle drain the melted water from the evaporator coils through a tube or a hole into a drip pan underneath the refrigerator. The water usually evaporates, but most times the pan is removable and can be drained. If this path of water is blocked at any point because the drain hole or tube is crimped or clotted with anything, it will back up inside the refrigerator area and try to find a way out, usually under the crisper drawers. To fix this, clear the obstruction in the drain tube. The drain pan at the bottom of the refrigerator can overflow or get old, crack, and develop a leak. Other times, mold can grow in the drain tube and clog it. Most refrigerators have an ice and/or water system built into them. This means that you have a waterline attached to the back of your refrigerator and it comes out as ice or cold water. Anywhere that water travels through the refrigerator and freezer can turn into a leak. To find the leak, you need to follow the tubes that carry the water through the appliance and make sure that all connections are tight.
Leaking containers or spills in the refrigerator can be misdiagnosed as leaks. First make sure that there are no puddles of juice, milk, water, etc. on one of the large capacity shelves.
I hope this solution will be helpful...Thanks for using fixya..
Aug 31, 2011 | GE Profile Arctica 25.4 Cubic Feet...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
GE Profile with water leaking. Does not seem to be a slow leak. More like an intermittant "dump." Water on floor and refrigerator shelves. Thanks!
Look under the refrigerator and locate the defroster water drain pan. There should be a tube running down the back of the refrigerator which drains water into this pan.
If this tube or other parts of the defroster drain system gets blocked, water can get diverted before it reaches the drain pan.
Oct 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Where is drip pan on profile side-by-side
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket.
Sep 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leak under GE Profile refridgerator when using door water
The water dispenser problem may be due to a defective water control valve. But when the refrigerator leaks this needs to be solved. I have a lot of different ways and reasons listed so click on the below link and read over this and use the part that applies to your refrigerators leaking problem. You also can contact me here or by email should I not get any messages here from you. Hope this helps and we will work on the dispenser problem next, Thanks, Sea Breeze
appliancepartsse@yahoo.com
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | GE Profile PCF25PGW Side by Side...
Water leaking from outside bottom
the waterline going in the freezer door may have a hole take the kickplate off while looking underneath use the water in door to see if any water is leaking from that tube
Apr 27, 2009 | GE Profile TPX24PBDCC Side by Side...
GE Profile Refrigerator - Small Leak & Loud Noise
Does water come out of the water dispenser?
I is more likely that the tube that drains the water down from the self defrost mechanism is clogged. Look in the very back of the reefer cabinet, you will see a trough back there, if it is full of ice and water the drain tube is clogged up. If so, a little blast of air from a can of air (like the ones you use to blow off computer key boards will blow it out. Then the water can drain down to the evaporator pan and you will no longer get water on the floor.
Nov 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile TPX24PBDCC Side by Side Refrigerator Logo
1,329 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
