Question about Maytag MDB7100AWB Dishwasher
Lighted "3" shows, dishwasher won't start
A panel light marked "3" is lit, flashes when start button pressed, then after few seconds, steady again.
    Problem Solver:
  • 6 Answers
PRESS AND HOLD THE BUTTON NEXT THE LOCK3 LIGHT FOR 3 SECONDS TO UNLOCK THE CONTROL PANEL. TO RELOCK THE CONTROL PANEL PRESS THE SAME BUTTON FOR 3 SECONDS. THANKS AGAIN
Posted on Jul 01, 2014
  • 18 Answers
SOURCE: I can't get my dishwasher to start
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Posted on Feb 04, 2007
SOURCE: "3 second" light flashing
The 3 second flashing light is a lock that locks out all other functions. To disable, depress the 3 second light for 3 seconds and all the functions will be released. This feature is to use to keep little kids from starting the appliance.
Posted on Jul 04, 2007
SOURCE: My dishwasher control panel does not light-up
This is a common problem. I am about to replace my second control panel in two years. First time was under warranty and I hope this time will also e under warranty.
Posted on Apr 25, 2008
SOURCE: Maytag MDBH950AWS Dishwasher won't start
We have a Maytag Dishwasher that won't start. The only button that lights up is the "Heavy Wash" cyle. When this button is pressed, the "Heated Dry", "Sanatize" and "Extra Rinse" lights up. The dishwasher doesn't start. Eventually all of the lights go out. the buttons start/cancel do not light up.could you in some way help?
Thank you.
Posted on Dec 28, 2008
SOURCE: control panel lights blinking
I have the same dishwasher with the same problem, try pushing the delay/resume button, then the drain/off button. When the lights go off start your wash cycle.
Posted on Sep 21, 2009
Maytag dishwasher MDB-8 shows "3", won't start.
click this link for the service manual, check page 5 for error codes, http://servicematters.com/maytag_library/docs/16026393.pdf this also tells you how to put this in diagnostic mode. hope this helps.
Apr 20, 2014 | Maytag 24 in. MDBH970AWS Built-in...
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Inspiron 1521 will not power up
I'd say that you have exhausted your options. You can try to isolate the power on problem by removing your your memory modules, hard disk drive and see if it at least stays powered on. Here is a link from Dell for your laptop's manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1521_Owner%27s%20Manual_en-us.pdf
Feb 09, 2013 | Dell Inspiron 1521 Notebook
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
We have a dishwasher that flashes clean light on front panel and will not allow a new cleaning cycle. Mod GU3200XTPS3 TYPE 577-0
Make sure the control panel is not locked. If you press any pad while your dishwasher is locked, the light flashes 3 times and the selection is ignored. If the lock symbol is lit, press and hold HEATED DRY for 4 seconds. The light turns off.
If the control panel is not locked and the problem still occurs press the Cancel/Drain button to drain all water and clear all indicators. (It might take 2 minutes to complete this action.)
Jul 08, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Pard, does your serial number end with either WS or WU? If so, Maytag had a issue with the main board, triac shorting and possibley damaging the motor windings. If your serial numbers fall under this, you are probably covered under the service flash. Im not really sure what you mean by the 3 second button flashing. Check the numbers first and post back. Catriver.
Apr 21, 2007 | Maytag MDB7100AWB Dishwasher
Maytag MDB7100AWB Dishwasher Logo
160 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
