Question about National Little Tikes Hummer Yellow
Battery not holding charge...
Same thing for me. I charge up the Hummer, it runs for about 15 seconds and dies qout quick. Looking on line for a new battery, but this battery I have has hardly any use on it at all. Probably about 5 hours in total. Kind of a hard time believing I need another battery. If I di need one, where can I find a replacement?
YOu may not be charging it long enough, or one of your currents could be off. I just went through this today. Take the battery into a battery store and have them test it. They will tell you what is wrong with it. My battery was fully charged, but the voltage was shot so it didn't matter.
Posted on Jul 19, 2009
Reset my kindle,
Dead battery. If you haven't charged it for several years it dies.
Unreparable although if you call kindle customer support they may give you a discounted price on a new or refurbished current model Kindle. They'll want your old one for parts.
Jul 02, 2015 | Tablets & eReaders
TracFone is charged, but says it is not charged and will not turn on.
Hello':":":":"
PHONE CHARGING:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
2:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 20, 2013 | LG Cell Phones
Solutions c414r can't turn on only charges
5.Wait 10 seconds.
Step
Thanks
Sep 08, 2012 | Cell Phones
Battery dies too quickly
Did you fully charge your battery when you first opened the phone? If not, the battery will never hold a full charge. it tells in the booklet that comes with your phone. Not giving your phone at least 16 hours on the first charge might cause battery trouble later. You may need to replace the battery. I hope this helps.
Mar 21, 2012 | Samsung Behold Cell Phone
1999 Toyota Tacoma battery keeps dying
This is easy to test but you need a multimeter. Connect the multimeter to the battery and run the engine at a fast idle (say 2000 rpm). You should get a voltage reading anywhere from 14 to 15 volts if the battery is fully charged and the alternator is working. If the reading is around 12 volts, then the alternator is not working.
Jul 09, 2017 | Cars & Trucks
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
My Archos 605 will turn on for a second and then turns itself off
Sounds like the battery is fried or that the system has interpreted that the battery is fried.. Have you tried a 15 second reset. Stick a pin in the reset hole along the bottom for 15 secs (or longer) to allow full discharge and reset. Recharge immediately for about 4 hours with the system completely shut down (press on/off button 15 seconds until blank). If there is still a problem try for a long reset again. If it does boot check the battery condition and how long it takes to die. Once a battery decides its had enough they can go quite quickly and die completely. Do you run the Archos whist it is in the dock or while the charger is plugged in it, I have found that running current through the battery like this can shorten the battery life considerably. I tend to charge fully and then discharge fully, for some reason this keeps the battery fit and allows the system that monitors the battery to have an accurate appraisal of it's true condition.
Apr 16, 2010 | Archos 605 WiFi Digital Media Player
I have a 92 Camaro and the problem I'm having is sorta weird.. My car ran fine about 2 months ago, but i haven't driven it for about 2-3 months. When i went to fire it up the battery was dead, so I...
SOUNDS LIKE YOU NEED BOTH THE ALTERNATOR AND THE STARTER TESTED.THE CAR SHOULD STAY RUNNING OFF THE ALTERNATOR ONCE BOOSTED,IT SHOULD START OFF THE BATTERY WHEN FULLY CHARGED.
Oct 18, 2009 | 1992 Chevrolet Camaro
Battery will not fully charge but will run with partial charge
Two things can be wrong, first your batts may be old and need new ones. Have them load tested at an auto part store. Most powerchairs use two 12 volt batts. If you batts are good you should have between 12.5 and 13.5 volts on a surface charge and 11.5 to 12.5 on a load test charge. Second, if you had your chair stored away for a couple of months then your batts died and need to be replaced. If you are luck a "boost charge" might work. If you are planing to keep it stored for months at a time, you must charge the chair once every couple of weeks to keep batts fresh.
Mar 21, 2009 | Jet 3 Ultra Power Chair
National Little Tikes Hummer Yellow Logo
363 people viewed this question
Top National Toys Experts
Joseph Hoffmann
Adam Fjeld
Adam Fjeld
Vernon Taylor
Are you a National Toy Expert? Answer questions, earn points and help others
