Enter setup code DKQTHK - Computers & Internet
Digitron dvd
Sony remote control have no setup code to this "Digitron" brand. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 18, 2014 | Sony (RM-V301) Remote Control
ETec RE7 code for Sony tv & dvd player
This brand remote control have no setup code to Sony TV/DVD combo. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, and buy that one according to availability. The first thing you have to do is, to confirm the number of digits in the setup codes to your TV brand. There are 4 digit, 5 digit, 3 digit and even 2 digit codes. You can make it sure by entering '0s' at the code enter window the TV dispays, and asks codes. Enter 'Zeros', and count how many zeros can be enterd. That number will be the number of digit of setup code, the TV/Device need. If you can enter 5 zeros, the number of digit in the set-up code to your TV is a '5' digit one, if only 2 zeros can be enterd, the number of digits in the set-up code to your TV should be a 2 digit one, and so on.. If you wish to get more details about this, try the sites linked here. http://electrohelponline.blogspot.com/
Jan 14, 2014 | Televison & Video
Ke32ts2e without remote control
Jan 11, 2014 | Televison & Video
Epson projector remote 151944200
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy. Electro help
Jan 08, 2014 | Televison & Video
How to we get fring setup in our mobile?..and how to we instal that setup?
Hi
Just open the www.fring.com and get the fring setup. if u have any problem for download please let me know.
May 11, 2011 | Samsung B3410 Cell Phone
What is this tv's setup code? Needed for Comcast cable box opera
are you sure that your comcast remote requires xxxxx 5 digits for the TV code ?
10054 ?
most remotes use 4 digit codes and in my book, the philips codes are:
0054
1454
0690
1154
try these
and if you are sure that the comcast remote uses 5 digit codes then try these
10054
11454
10690
11154
make sure you get the Red LED code entered Confirmation Blink after entering the code digits.
its either a double blink or a Long Solid blink
if you have 4 digit codes it will blink before can enter the 5th, so you will know
Ed
Jun 16, 2009 | Philips 13PT30L 13" TV
What remote control code does the Onkyo TX-SR304 use?
1) Tap AUX
2) Press & Hold Setup (1 then 2 blinks)
3) Enter 30842 or 0842 (The remote should blink twice)
4) Press & Hold Setup (1 then 2 blinks)
5) Enter 994 (2 blinks)
6) Tap Setup (1 blink)
7) Enter "00051" (1 blink per number)
8) Tap Power (not All On, just "power") (The remote should blink twice)
9) Tap AUX
10) Press & Hold Setup (1 then 2 blinks)
11) Enter 30135 or 0135
Aug 27, 2008 | Onkyo TX-SR304 Receiver
Romote control not working
1. The owner's manual is available online:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-ES35VS
Download the manual under Operating Instructions.
2. To remedy "SET1" problem, Press 1 & Enter at the same time.
Hope this helps
Aug 10, 2008 | Panasonic DMR-ES35VS
Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Feb 08, 2008 | HP Officejet 9110 All-In-One InkJet...
Honeywell VisionPro USER SETUP CODES OR INSTALLER CODE FOR TEMP RESTRICTION
You need to get into the installer setup. Download the installer manual from Honeywell or an on-line vendor and it has the installer codes to alter the maximum heat setting. Press the system button and then buttons 2 & 4 at the same time for 5 sec to enter the installer mode. I believe the code is 0600 and then you enter the max temp for heat setting. Press done and your done!. Try this link for the installers manual http://www.alpinehomeair.com/related/Honeywell_VisionPro_8000_%20Install_%20Instructions.pdf
Jan 21, 2008 | Honeywell Programmable Thermostat Heater
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
