Question about JVC KD-AVX33 Car Video Player
Mechanical error ejecting - JVC KD-AVX33 Car Video Player
E-9101 and EJECT
E-9101 error is for Mechanical time out, it means your player can not read the disc within the given time period.
You may have to clean your player, there may be dust, dirt or other particle into insertion slot.
djajay@inbox.com
May 14, 2010 | Pioneer CDJ-800 Turntable
ERROR 03 WHEN PUSH CD BUTTON
Two solution proposed on other forums:
1. Hold 'eject' button for 10 seconds. The system should eject the cd.
2. Slide a credit card back and forth on the cd opening. Push eject, the cd should be ejected.
Hope it works.
Oct 14, 2009 | 2004 Mitsubishi Endeavor
Mechanism error
If your unit is still making noise like it is trying to eject, then give it a little help by using a tweezer to pull the disc out after you pressed eject. Then clean the eject's mechanism rollers by using a couple of Q-tips and alcohol. Stick the slightly wet Q-tip into the center of the disc player slot until you reach the rollers after that slide it against the rollers from side to side, when you do that the sliding switches will trigger the eject mechanism and the rollers will start to roll. After afew times change the Q-tip and repeat. Allow 10-15 minutes for it to dry out completly. It should work after that. But if your unit is making clicking sounds or no sound at all right now and it display mechanical error message, then you have deep mechanical problems. There are services on Ebay for about $100, contact Rick for service. He own SAME DAY AUDIO SERVICES, he is very reliable. You can call me too:801-414-4566. Good luck.
Dec 31, 2008 | Pioneer AVIC-N2 Car DVD Player
Problem with ejecting tape
that is stand for mechanical timing..maybe the mechanical is being missaligned..in some cases also the timig swicth is lost contact to the mainboard of the camera..
Aug 28, 2008 | Sony Handycam DCR-TRV340E Digital...
Samsung vp-d361
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Manual
Apr 18, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Error ....D
  1. Eject the tape.
  2. Set to OFF.
Manual
Mar 13, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Alpine CDM-9803 Cd Player
You need to visit Alpines' site to download the owner's manual for your unit. In the mean time here is some info from the troubleshooting guide for your error code.
• Mechanism error.
1. Press the "eject" button and eject the CD.
If not ejecting, consult your Alpine dealer.
2. When the error indication remains after ejecting,
press the "eject" button again.
If the error indication still does not turn off after
pressing the "eject" button for a few times, consult your
Alpine dealer.
Note
When the "- - - E" is displayed:
In case that the disc cannot be ejected by pressing the "eject"
button, press the RESET switch (refer to page 4) and
Good luck.
Feb 08, 2008 | Alpine CDM-9803 CD Player
MECHANICAL DISC ERROR
There should be an emergency eject button, look in your instructions that came with it to locate it. Also check you book for the suitable DVD's for your machine. Or go to the panasonic web site
Feb 02, 2008 | Panasonic CQ-VD6503U Car DVD Player
Unable to eject cd magizine. Error 2
power off. open the cd changer unit. look for the motor that, when turning, performs the eject mechanism. now turn this motor by hand in the proper direction until cassette is fully ejected.
Jul 22, 2007 | Clarion DC625 6-Disc CD Changer
JVC KD-AVX33 Car Video Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
