Question about Maytag MDE308DAYW Electric Dryer
How to clean lint out of a maytag dryer model # mde308dayw
dididsaythat
  • 291 Answers
SOURCE: Maytag Dryer not working properly after cleaning lint trap.
where does the noise sound like its coming from??
Posted on Oct 08, 2007
SOURCE: how to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Posted on Dec 04, 2008
SOURCE: How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Posted on Feb 11, 2009
SolutionGuy
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
hiltonjug
  • 612 Answers
SOURCE: My Maytag MDE308DAYW needs a new belt. Belt was
If you go from the top. The belt goes down the drum, between the drum and idler pulloy,under the idler then pull it over to the top of the motor pully and loop over it. When it comes out from under the motor pully it goes under the drum and over to the other side of the drum, and back up to the top of the drum. I hope this makes since.
Please rate solution if helpful
Posted on Aug 28, 2009
Testimonial: "Thank you for the advice. "
My maytage dryer mde308dayw drys the clothes, but it takes a longtime. The dryer heats, but water builds up around the inside of the door of the dryer.
You will need to clean the vent system on your dryer. Lint buildup restricts the airflow and will keep the clothes from drying.
Oct 17, 2011 | Maytag MDE308DAYW Electric Dryer
Maytag dryer mde308dayw won't turn on
The most probable thing thats wrong causing the dryer to not start is going to be a blown thermal fuse,when it goes out it cuts power to the motor circuit...do you have a display on the front yet it wont start???? or no display??
If you do have a display yet the dryer wont start it very likely will be the thermal fuse,it fits into the blower housing below where the lint filter fits into inside of the door,or depending on your model it will be in the rear but in any case it will be in the blower housing below where the lint filter fits all be it in the front or rear, To access it to check it remove the small lower front panel or the rear panel if it comes off(if not its going to be in the front) and it will be on the top of the blower housing,to check it measure it for continuity (ohm it out) with zero ohms resistiance.
This is what it looks like in the pictures below,either one of these two styles.
If that turns out to be the problem be sure to take apart the blower asm. and clean all lint from it and also check the venting from the back of the dryer all the way to where it exits the house....since the usual reason the thermal fuse goes out is because of poor airflow because of built up lint/blocked vent.
GENE
Ads by Google' + // // '' + // '' + // makeBoldAdWords(google_ads[0].line1) + '' + // // '' + // makeBoldAdWords(google_ads[0].line2) + ' ' + // makeBoldAdWords(google_ads[0].line3) + // '
' + // google_ads[0].visible_url + ' ' + // '
' + // ''; // } // else if (google_ads.length > 1) if (google_ads.length > 0) { s += 'Ads by Google'; /* * For text ads, append each ad to the string. */ for(i = 0; i ' + makeBoldAdWords(google_ads[i].line1) + '' + '' + '' + google_ads[i].visible_url + ' ' + makeBoldAdWords(google_ads[i].line2) + ' ' + makeBoldAdWords(google_ads[i].line3) + '
' + ''; // '' + // makeBoldAdWords(google_ads[i].line2) + ' ' + // makeBoldAdWords(google_ads[i].line3) + // '
' + // google_ads[i].visible_url + ' ' + // '
' + // ''; } } } document.write(s); G_GGL_SKIP += Math.min(google_ads.length,G_MAX_ADS_AT); return; } var G_MAX_ADS_AT = 4; //var G_MAX_ADS_AT = 3; google_ad_client = "pub-8183356113384228"; // substitute your client_id (pub-#) google_ad_channel = "4447185069+3033438690"; google_ad_output = 'js'; google_max_num_ads = '4'; google_ad_type = 'text'; google_feedback = 'on'; if(typeof G_GGL_SKIP == 'undefined') { G_GGL_SKIP = 0; } google_skip = G_GGL_SKIP; // -->
Sep 24, 2011 | Maytag Dryers
Please in very careful detail exsplain how to attach four prong plug wires to my maytag model no mde308dayw please help?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2011 | Maytag MDE308DAYW Electric Dryer
My Maytag model MDE308DAYW squeaks and grinds when turned on.
i would assume that either the rear roller(located directly atop your heater, or yout idler pulley has gone bad , parts are probly about $40.. not a bad repair, you can probly find a how to on you tube
Oct 09, 2010 | Maytag MDE308DAYW Electric Dryer
Maytag dryer model MDE308DAYW will not start. Why?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
I have a May Tag dryer which blows the Thermal Fuse.
I am not 100% sure, but I think that the model that maytag had with that dryer. When I was working for my local dealer I had to change several of those, and it about 2 weeks time they blew.
Aug 09, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag Electric Dryer MDE308DAYW doesn't turn on at all when pressing the button
Since the vent was filled with lint I would check the High Limit termal fuse located on the front of the heater asm. It is best to replace the fuse and thermostat. These parts are part of a kit that can be purchased from your local supplier. The heater asm is located in trhe bottom left of the dryer. and looks like this
Jan 16, 2008 | Dryers
Maytag MDE308DAYW Electric Dryer Logo
63 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
