Question about Onkyo DV-SP502 DVD Player
Secret seting dv-sp502 - Onkyo DV-SP502 DVD Player
Doesn't recognize replacement hard drive
What is the type of IC regulator voltage on power supply board Onkyo DV-SP502?
Jan 17, 2014 | Philips DVDR3575H/37
I'm looking for a sofa bed but one with a comfortable mattress
The key rule for this is to actually try ityourself. Have a sale representative in the store help you pulling the bed andyou should try it before buying. It is no secret that, usually, the more youpay, the more comfortable you are. This is usually the case with mattresses. Ifyou are planning to shop online, this website might help you: http://www.apartmenttherapy.com/top-10-sleeper-17868
May 29, 2012 | Furniture
I OWN AN ONKYO DVD- DV SP 502. I AM HAVING PROBLEM WITH THE PICK UP, AND THE SERVICE CENTRE TELLS ME TO REPLACE THE PICK UP ASSY,( 03 SD Pickup Assy-S part no.OXX8005). I HAVR TRIED CLEANING THE LENS BY...
The someone that told you to try cleaning the lens with a cotton swab (q-tip) was right.
if that doesn't work, check all the cables that go to or are in the pickup assembly.
If all that seems OK, then you very well may need to replace the assembly.
Mar 27, 2011 | Onkyo DV-SP502 DVD Player
Sony ericsson w800i reset setings code
Ericsson Ericson T65 *#05# Fake Insert puk screen Press no to exit ... *#311# Reset PhoneCode - [ Also reset Security Codes ! ] ... Sony CMD Z5/J5 Vers. SW : Without SIM , switch on phone and type l *#7353273# ...
Nov 28, 2010 | Ericsson K700i Cell Phone
Zebra 140XiII - cannot print via Ethernet cable - Windows status monitor shows status as offline. I Installed correct drivers? what is the secret for connectivity!? Greg
check if IP adress, subnet mask and the gateway are correct on the printer setings.
Try to ping the IP address from the START-Run...(write CMD) and write ping IP adress.???.???.???.???
check if had responce.
Sep 15, 2010 | Zebra 140Xi II Thermal Printer
How do I play USA region DVDs on my Asian region Onkyo DV-SP502 player?
To make region-free: Hold enter on the remote until the player turns off.
Oct 03, 2009 | Onkyo DV-SP502 DVD Player
Does not recognize a disk perviously watched
hi! i think you have problem on the pick-up lens assembly, here in our country we do try to replace the spindle motor before attempting to change the pick-up lens.
Aug 17, 2009 | Televison & Video
How do I unlock my Pioneer DV-310-s so it will accept all dvds, thanks.
Here is how to Make your Pioneer DV-310 regionfree.
Use this link and go there.
http://www.pioneerfaq.info/index.php?question=Firmwares
Search for file YJA8703A almost in the bottom under DV-310.
Download and burn on CD with nero,make sure the CD is being closed after burning.
The just mount the CD in your DVD player and press play.
#1. Press upgrade.
#2. Wait,don´t touch anything now.
#3. The tray will open after about 5-10 sec,take out CD.
#4. Player will uppgrade under about 1-2 minut,then the tray will close by it self,and the player says "CLEAR".
#5. And now here is the secret. When player says "CLEAR" ,push and HOLD the "enter button on THE PLAYER until it turns off(about 5 sec).
And there you go,standing infront of your brand new Multi regional Pioneer DV-310.
At least this worked great for me.
Good Luck!
/Jiinsen
Aug 08, 2009 | Pioneer DV-310 DVD Player
Onkyo DV-SP502 DVD Player Logo
16 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
