We have two computers connected to an ethernet hub and the hub connected to the modem. One computer internet works and the other gets and error 678 message we have interchanged the cables on the ethernet hub and it did not change any thing.
ERROR 678 is usually a physical connection problem, either between that computer and the modem, or on the provider of the telephone lines side. There can also be a software network addressing problem for the Local Area Connection inside Network Connections inside the control panel, which can cause a physical connection problem in a way, so to speak. Try to ping the router and log in to router interface via internet explorer. If cannot login check the ethernet 1 or 2 or 3 or 4 lights on switch and modem/router, which need to be stable green. Try bypassing the hub/switch and connect the pc directly to the router. Restart everything including pc. Reset router. Try assign the LAN ip addresses and DNS addresses manually instead of automatic - if there's still no LAN connection. Investigate disabling anti-virus or uninstalling it completely, then its probably a port problem at the exchange of the telephone company and a fault needs to be logged with them.
Posted on Aug 18, 2009
  • 121 Answers
Hiiii
Since internet is working in one of the computer then it seems that the other modem is not working correctly so you must reset your modem.
For further help you can visit http://techbuddies-robin.blogspot.com/2009/06/free-computer-related-technical-support.html
Posted on Jun 19, 2009
I am having trouble connecting my RCA dcm425 with a dynex 10base-t ethernet hub to two devices at once. Comcast said I should be able to connect two devices at once but I can only connect one at a time. ...
The RCA DCM425 is a cable modem. You need an Ethernet router to connect two devices to the wide area network provided by the modem. A router assigns I.P. (internet protocol) addresses. Your Dynex Ethernet hub is a switch which will enable you to share files between computers. It doesn't support directing traffic to and from the internet.
I wish that I had better news for you. You can get a router from many sources.
Feb 19, 2018 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How can I connect two ethernet cables to this modem?
If your Internet Cable Provider allows it,you will need :
1. Crossover-wired, or "null," category 5 Ethernet cable for the cable modem to be connected.
2. 10BaseT or 100BaseT Hub or Switch.
3. Straight through, or standard, category 5 Ethernet cable (one for each computer to be connected).
Be sure to check with your Internet Provider first.
Dec 23, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I wasnt able to connect using my modem, then this appears error 679. What does 679 error means?
Error 678 and Error 679 Connection Errors
Error 678 The remote computer did not respond (No dial tone)
Error 679 The Specified destination is not reachable
Both errors are very closely related as they both suffer from the same causes
Causes
ISP (internet service provider) problem.
You have a phone line problem.
Router / Modem is disabled, this can be due to.
The LAN or Phone cable is disconnected.
Your firewall is blocking the connection.
The Winsock file needs to be repaired.
A phone line does not have a line filter installed.
The modem drivers are corrupt.
Spyware.
Your modem is faulty.
Your username, password is wrong.
Incorrect ISP or Router / Modem Configuration
Hope it helps.
Oct 09, 2010 | Computers & Internet
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
Can't connect to laptop
You need to connect a cable from your modem into an internet port on your router and than a cable from an ethernet port of a router into an ethernet port of your hub and than a cable from hub to the computer.
Modem --> Router --> Hub --> Computer
May 08, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
How do you hook up a Dynex Ethernet Hub
If your hub has 4 or 5 connectors, connect one port to your router. This device will NOT work when connected to your cable modem, as the hub does not manage IP addresses like a router does. Hope this helps ... the remaining ports will feed internet, but not provide Internet addresses to a computer.
Nov 08, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
DES-1008D connectivity issues.
Is the modem a DSL or cable model?
Does the router have one ethernet port and a WAN port?
Normally the broadband modem is connected to the WAN port on the router and the ethernet port on the router is then connected to the hub/switch and the computers are then connected to the hub/switch.
The modem gets an unique IP address from your Internet Service Provider and then the router then issues Class "C" IP addresses to each computer that is connected to the switch/hub.
Jul 31, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
How can i connect an additional pc to my rca dcm245 cable modem? i have an ethernet hub.
Hi there.
What you have to do is plug in the Ethernet hub, run the Ethernet cable (RJ45) from the modem to the "internet in" or "internet" socket on the hub, it will the one which is separated from the others.
Then connect an ethernet cable in port 1 to your first computer and a cable from port 2 to your second computer and so on.
If you experience connection problems just pull power from the modem for 30 seconds, plug it back in wait a minute and reconnect.
If you would need further assistance please post back.
Good luck and thanks for using FixYa!!
May 25, 2009 | Thomson RCA DCM245R Modem
Error [678]
Hi, Step 1: Make sure the network cable is connectedMake sure that the network cable is connected to the computer and to the modem. If your computer connects to a hub or to a router, make sure the cable that connects the hub or the router to the modem is connected. Step 2: Make sure that the network adapter is enabled
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Right-click the Local Area Connection icon. Click Enable if the option is available.
Step 3: Reset the modem
  1. Disconnect the cable that goes from the computer to the modem.
  2. Turn off the modem. If the modem does not have a power switch, disconnect the power supply from the modem.
  3. Wait two minutes.
  4. Turn on the modem, and then connect the cable that goes from the computer to the modem.
Step 4: Uninstall and then reinstall the modem and the drivers by using Device Manager
Before you follow these steps, you may have to download the latest driver for your network adapter from the hardware manufacturer.
  1. Click Start, click Run, type sysdm.cpl, and then click OK.
  2. Click the Hardware tab, click Device Manager, and then locate Network Adapters.
  3. Expand Network Adapters, and then right-click the icon for your network adapter.
  4. Click Uninstall, and then click OK. In the dialog box that prompts you to remove the files that are associated with this device, click Yes.
  5. Restart the computer. Or, click Action, and then click Scan for hardware changes.
  6. If Windows finds the device but does not recognize it, you must install the latest driver for your network adapter.
If you have a Realtek 8139 network adapter, updating the driver seems to resolve this issue. For more information, visit the following Realtek Web site: http://www.realtek.com.tw/downloads/Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information. Step 5: Create a new DSL or cable connection
  2. Click Create a new connection under Network Tasks. Click Next when the wizard starts.
  3. Click Connect to the Internet, and then click Next.
  4. Click Set up my connection manually, and then click Next.
  5. Select Connect using a broadband connection that requires a user name and password, and then click Next.
  6. Follow the remaining steps. Use the connection information from your Internet service provider (ISP) to complete the wizard.
Note You may have to use software that is supplied by your ISP to create the new connection.
Mar 02, 2009 | Microsoft Windows Vista Ultimate Edition
I just instaled a new pc tower , my modem doesnt conect
Make sure u have the usb drivers installed for this new modem on the computer..
Jan 25, 2009 | Computers & Internet
Computers & Internet Logo
219 people viewed this question
Alun Cox
David Payne
David Payne
