Question about Thermador Kitchen Ranges
Hood can not turn on
All lights are ok but can not turn on then air
Unit has no power. Circuit breaker OK. Is there a fuse somewhere in the hood?
Very likely the power supply unit is faulty or the controller itself. The parts list shows no fuse internally. The power is directly going to the control board (item 3). Make sure you turn power to the rangehood off at circuit breaker before working on it.
JENN AIR Vent Hood Hood components complete Parts Model JXT5830ADS
Sep 06, 2014 | Jenn-Air JXT5830AD Kitchen Hood
Turns over but will not start
No start:
Check ignition: verify with timing light. The old practice of holding the live end of the secondary a short distance away from the block is forbidden.
Check fuel system: (ensure you have gas - gauge can always be suspect!) key to KPII listen for a two-second buzz from the gas tank area. N.G., check the fuse. OK, check the relay (under the hood). OK, possibly faulty pump or electrical connections.
Check Air intake - key to KPII, listen for a hum near the throttle body. This indicates your air valve is at least getting a signal from the ECU.
Oct 13, 2013 | Volvo 850 Cars & Trucks
My car air bag light comes on and my turn signal short circuits
check battery volts should be 12.6 volts. alternator faulty.check under hood see if alternator drive belt tight not too loose.with engine running alternator out put at battery should be 13.5 - 14 .5 volts.
Nov 11, 2011 | Cars & Trucks
I have no brake lights. I checked at the fuse box under the hood and found it OK. Then I went to the foot peddle switch and found the switch OK but when I checked for power going into the switch none could...
Do you have turn signals ok?
Is your rear turn signal bolb the same one used for brakes?
Some turn signals are amber and some are red using the same bulb as the brakes. In that case the brake lights go through the turn signal switch.
But you would have power at the pedal switch.
No relay but there should be a fuse in the dash anel or under the hood if you have a battery box under the hood. Your owner manual will tell you where the fuses are and which one is hte brake. Usually a 15 amp.
Mar 21, 2011 | 1994 Honda Accord
97 Pontiac Trans Sport. Turn signal problem
verify the ground wire is good, black wire, its down on the frame rail, opposite of the air filter housing, if thats OK, it, could be the turn signal switch. but the wires go from the turn signal switch, through the Daytime Running Lights Module, through the fuse panel under the hood, then to the light socket. wire is light blue / white coming out of turn signal switch to DRL module, then its light blue all the way to the socket.
Oct 19, 2009 | 1997 Pontiac Trans Sport
Would i lose a freon charge in that time period what odds it needs more than a ch
does the AC compressor run under the hood? if not u have lost the charge out of the system and u have a leak..
Jun 01, 2009 | 1998 Toyota Camry
I cant get it to turn on
Hi lillady909,
I'm Harvey the Master Plumber.
Your problem is: you cant get the lights or fan to turn on anymore is there a reset switch
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 23, 2008 | Jenn-Air ® 48" Professional Over The...
Kitchen Ranges Logo
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
