Question about Sub-Zero 695/O Side by Side Refrigerator
Pan on bottom of refrigerator - Sub-Zero 695/O Side by Side Refrigerator
Kenmore side by side refrigerator 51262103 how to remove drain pan.
Usually, there is a removable grille at the bottom of the refrigerator which provides access to the drain pan. Removal can involve some twists and turns to get the pan clear.
Sep 20, 2014 | Kenmore 51262 / 51264 / 51269 Side by Side...
Water leak at the bottom of the refrigerator
The evaporator pan in the bottom of you refrigerator may be out of place, damaged or missing. there also may be a problem with the drain tube being bent and not dripping into the pan. It is also possible that the drain tube could be clogged and water could be collecting in the bottom of the refrigerator and spilling out too.
Jan 10, 2014 | Samsung RF265AA Bottom Freezer French Door...
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
The drain pan under my refrigerator stinks really bad how can i remove it to clean it
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Aug 06, 2011 | Refrigerators
Our amana bottom freezer refrigerator Model ABB2224DEQ at times leaks onto our kitchen floor. We don't have an ice maker so I am wondering where it would be coming from and what needs to be done to...
This is likely water from the auto defrost operation leaking from the evaporating pan. Sounds like the pan may have a hole in it, or the hose which drains the water into the pan is leaking, The pan is at the very bottom of the unit.
Charlie
Mar 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Where is the drain pan located on the GE Side by Side Refrigerator I have looked everywhere! Thanks in advance for your help.
why are you looking for the pan,you shouldn't have to do anything with it.the pan is at the bottom of the fridge behind the front kick plate and on some models there isn't a pan at all/the water drains to the bottom frame or floor of the fridge where the compressor is in the bottom back,the water collects there and the heat from the compressor and condenser coil evaporates the water.remove the bottom back panel,lok for the drain line or if it just defrosted you'll see the water sitting in the frame.what's happening that you're looking for the pan?
Feb 23, 2011 | GE GSL25JFPBS Side by Side Refrigerator
TOP FREEZER REFRIGERATOR WITHOUT ICEMAKER LEAKS ONTO TOP SHELF AND UNDER BOTTOM DRAWER
the condensate drain hose is blocked.
remove the plastic rear cover in the freezer; locate the drain opening;
it's about 1/2 inch in diameter; it drains into a pan at the bottom of the refrigerator. using a funnel and, a small pan, pour hot water through the blocked hose until water flows into the drain pan again.
remove the condensate pan pour the water out and, reinstall the pan.
Jul 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Dead fish smell from my Kenmore Elite Bottom Mount Refrigerator
dead fish smell ( under the frig there is a cond pan that collects water from the defrost . whirlpool has some tabs that you can put in pan/ it helps .. I would put a cup of bleach in pan every 3 months . and if you can find the drain inside the freezer add it thorugh the drain . algae builds up in drain and plugs it . mm
Dec 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Trickling water noise coming from the bottom of the fridge.
It may be nothing to be concerned about. The water produced during the defrost cycle drains into a pan at the bottom of the refrigerator. This water is then evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan from the tubing that carries it from the inside of the refrigerator.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water collects on the bottom of the refrigerator
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 11, 2009 | Refrigerators
Sub-Zero 695/O Side by Side Refrigerator Logo
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
