Question about Andis AG 2 Hair Trimmer
I opened the Panasonic ER2031 razor to clean and I do not no how to fix it back as the spring has snapped
Took maytag oven door off to clean cannot get it back on hinges will.not stay open and keep.snapping back fingers r sore took a pipe to pull them back but they wont stay How do I keep them from snapping...
It is a two person job unless you want to pull the whole stove out and take the cover off and then remove the springs. Put the door back on and put the springs back and the put the cover back on.
Oct 10, 2014 | Ovens
I'm on my second Panasonic ES-LA93-K shaver with a flashing "status" light. (This happens on the cleaning unit). Both times, it happened about 3 weeks after purchasing it. At first, I thought...
I've also seen this problem now... In my case re-seating the cartridge helped for a few days, but after that I got continuous flashing status LED. Turns out (after disassembling of the cleaner base) that the cross-shaped arm that checks for cartridge presence activates a micro-switch that is supposed to be open when everything is OK. I seem to have gotten a bit of water in it and therefore now it was recognized as missing all the time. As I have no plan of ever attempting to run the cleaning cycle without cartridge I disconnected the switch and isolated the cable ends - problem solved.
Disassembling of the base wasn't at all complicated when you have removed all the screws. There are three less obvious screws under the rubber feet (just pull the feet straight out), other that that they are all very visible.
Mar 27, 2011 | Panasonic ESLA93k Electric Shaver
I have a new ES-LA93 razor which I love but I have one question. After shaving I press the [SELECT] button to choose Clean/Dry/Charge. The process finishes and all seems fine but the CLEAN and DRY course...
If you clean the razor every day, the CLEAN and DRY lights flash repeatedly to show you that the cleaning has completed. You should be able to confirm that this is correct by NOT cleaning it one day. You should see that those lights don't flash then. I know this because I clean the razor twice a week rather than every day. On the days that I clean it, the lights flash. On the days that I don't clean it, the lights don't flash.
Nov 08, 2010 | Panasonic Health & Beauty
Twist button.
Throttle tube has either become damaged (hidden by the grip) or has been pushed inwards when you fell. Loosen housing bolts on the clamp and slide the whole thing a few mm's outwards..prob just the grip fouling on the end of the bars.
Aug 12, 2009 | Razor MX500 Dirt Rocket
Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
May 20, 2009 | Conair GMT200TD
Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
May 10, 2009 | Razor MX500 Dirt Rocket
THE BLADE HAS COME OUT, AND IAM UNABLE TO REINSERT IT
poor website to get any helpful information, don't waste your time
Jan 29, 2009 | Panasonic ER 203 Beard Trimmer
Springs fell out
I did get it fixed. I kept looking at it and studying it and I finally figured out that the small, gold head is where they had to go. I pushed on it and it finally fell out. I saw two small holes that looked like they were the same size as the springs. I put them in and when I put the piece back in the razor, the spring lined up with 2 small pegs on the inside. I snapped the head in place and the gold bars then moved up and down with a little resistence. I turned the shaver on and it worked just fine.
Sep 10, 2008 | Health & Beauty
Panasonic microwave door is stuck. The door is not opening
If you push in on the open door button and it just goes in and does not open the door, then the problem is that the plastic piece that actually opens the door has broken. You can verify this by removing the cover from the microwave and look inside. If you are handy just buy the part from the panasonic parts store in your city and replace it. If not take it in and they will replace it for you.
Good luck
Tom
Jun 12, 2008 | Panasonic Microwave Ovens
Loose Cutter Block
when you remove the cutter block is there a white nylon fixture atop the vibrating mechanism? this nylon piece snaps on the vibrating rod and the cutter snaps into the nylon fixture.
Sep 02, 2007 | Braun Syncro 7526 Electric Shaver
Andis AG 2 Hair Trimmer Logo
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
