Question about U-Line Icemaker
Water does not pump into reservour - U-Line Icemaker
Ticking noise from under my hood
ticking noise can be a lifter /push rod /or rocker that needs adjusting or has been damaged from overheating [oil turns to sludge and can block oil passages in upper valve train ]or damaged from being out of time bent pushrod,flattened -collapsed lifter
Feb 09, 2012 | 2000 Chrysler 300M
How can i determine if the water pump is working? i replaced the radiator and the thermostat. The car continues to over heat. any ideas? Also how can i bleed the air out of the system? could the water...
If you squeeze the upper radiator hose and it feels like the coolant is running thru it, your pump is working. The system should bleed itself within a few minutes if you keep the radiator and reservoir full. If it continues to bubble, you have a blown head gasket. :-(
Let us know if you need more help.
Sep 12, 2010 | Dodge Intrepid Cars & Trucks
Where is the power steering pump on a 1993 cadillac eldorado
it is actually a rack and pinoin system so what is called the pump is just a reservour and it should be located on the back left side of the motor looking back at the car
Feb 25, 2010 | Cadillac Eldorado Cars & Trucks
My washer window washer stopping out om 99 toyota. the reservoir
on the bottom of the reservour is a hose which is attached to a little pump which makes the washer fluid shoot out on to your windshield.it also has an electrical plug connected to it.sometimes by wiggling the plug it will start to work again,if not,make sure that there is power going to the pump.if there is power,your washer pump will have to be replaced.if there is no power,check your fuses. hope this information helps you with your problem. take care, manny
Jan 31, 2010 | 1999 Toyota Tacoma PreRunner
The ice maker in my whirlpool has water in reservour and water freezes quickly enough, but does not dump ice.
change out the ice maker,the heater on it could be broke or one of the theeth that move are stuck holding it up or you might have a bad motor
Dec 25, 2009 | Refrigerators
What symptoms does a Dodge Caravan have when it needs steering fluid repair of some type?
Hi sandav,
In response to your question, fluid can be low and more may need to be added. Any repair would be on the way it got low, fix the leak.
If it is low, steering at slower speeds will be difficult. An upper body workout. .
If you are having difficulties, post the symptoms you are experiencing. Might be able to help
Mike
Oct 29, 2009 | 2001 Dodge Grand Caravan
Water will not dispense, the ice is working fine. The filter is installed fine, and checked everything. What else to try
only 3 things could be wrong 1 frozen line inside door 2 water valve not working 3 frozen reservour inside refrigerator section
Oct 31, 2008 | Samsung RS2630SH Side by Side Refrigerator
Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
1987 Chevy G20 van replace power steering pump
Does your van have the serpentine belt? If so maybe I can help, I replaced the Power steering pump on my 90 G20 a couple of weeks ago. The trick is that you need to pull the pump pulley which is pressed on to access the mounting bolts which attach the pump to the engine. Harbor Freight tools sells a great tool designed for this job for $20.00. Once you have the correct tools, remove the serpentine drive belt. You may also need to remove the fan shroud. the pump shaft looks like it has an allen socket in the center, but this is for use in the manufacturing process, and will not come out. Place the puller tool on the pulley following tthe instruction that come with the tool, and remove the pulley. loosen, but do not remove the nut on the high pressure hose connection. use a pair of **** pliers to cut and remove the crimp clamp on the low pressure hose. If your pump has the remote reservour loosen the clamp on the reservour hose also. Remove the three mounting bolts, place a large pan under the pump to catch drips, and remove the prevously loosened hoses. there will be fluid leaking all over and the pump should come free, There are two types of replacement pump sold. With and without reservour. This reservour is a metal cover that fits over the back of the pump, and should not be confused with the reomte revervour found on some newer models which is next to the battery. This reservour is held in place be two throught the pump bolts which are removed at the back of the pump. If your new pump has a reservour you will probably still need to remove these bolts and put them in the replacement pump as most are shiped without these bolts. If you replacement pump comes without a reservour pull the bolts, the reservour should pull off of the old pump and slide onto the new one. check the o rings and replace the through the pump bolts. Installation is the reverse of removal execpt that 1/2" hose clamps replace the crimp clamps on the low pressure hose, and the puller tool is set up differently to replace the pulley. Finally if you don't flush contaminants out of the system your repair will last maybe a week. www.cardone.com has a great article about power steering flushing, read it before you start Good luck.
May 15, 2008 | 1987 Chevrolet G20
U-Line Icemaker Logo
37 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
