Admiral capacity plus washer lint filter
Where is the lint filter
  • 12 Answers
SOURCE: My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Posted on Oct 26, 2008
SOURCE: can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Posted on Nov 01, 2008
SOURCE: Cannot find lint filter in washing machine. Is there one?
I called Home Depot where I purchased the washing machine and they told me newer washers do not have filters any longer.
Thanks for your response.
Posted on Apr 16, 2009
SOURCE: My admiral capacity plus washer
I had this happen last year to mine. Check the hose that goes to water level adjustment switch. It may have a hole or crack in it. It may be small and hard to find but if there are any leaks in this hose the switch cannot sense the water level because it works on pressure through the hose to the diaphragm on the switch. You will need to remove the top panel of the washer to access this. I was able to replace the hose with some I had on hand. Saved me big $$$!
Posted on Jun 07, 2009
SOURCE: I have an admiral heavy duty super capacity plus 2
load lite, and if the problem still is there let run empty a couple of times, if there is still a problem it is off track and a professional needs to go inside of it you can do it yourself but not recommended so call a pro!!!
Posted on Apr 21, 2010
Admiral washer atw4470tq0 lint issues on clothes
clean the lint filter in the machine
remove any tissues and papers from pockets before washing
Nov 07, 2017 | Admiral Washing Machines
Location of lint trap
under the fabric conditioner cup in the centre of the agitator.
How do you locate the lint filter in a washing machine? ' Reference.com
https://www.reference.com > Home & Garden > Appliances > Washers & Dryers
  1. Cached
The location of the lint filter in a washing machine depends on the brand and model of the machine, and the owner's manual states where it is located. For instance, model RAX7245JQ0 of the Roper washing machine by Whirlpool has a lint filter located under the washer's agitator ...
Lint Filter - - 426451P - Fisher & Paykel
https://secure.fisherpaykel.com/us/Catalog/ItemContent.aspx?ItemNumber...
  1. Cached
  2. Similar
Description: Suitable for topload washers that use agitator part number 425025P. The lint filter is inserted into the agitator by removing the fabric dispenser cup.
Nov 10, 2016 | Washing Machines
Agitator comes off during cycle in my admiral capacity plus washer. How do I fix it?
If the bolt is still on top. it was probably screwed too tight and wore through. then you need a new agitator
Sep 22, 2011 | Admiral 32 cu. ft. Washer
I have lots of lint that gets trapped under and all around lint filter and it is very hard to get out - why is it not being contained? GE Dryer DBVH512EFOWW front load.
Hi rstebly...
Sometimes the problem is with the lint filter itself...
If you use "dryer sheets" they can plug up the holes in the lint filter with a kind of waxy substance and that will impair the air getting thru the filter causing the lint and air to find another way out, not thru the filter but thru the machine.
I would suggest you take the filter out and wash/scrub, lightly it in hot soapy water, let dry, then reinstall the filter.
You should also check the blower /blower tube and the inside of your dryer for lint buildup also, as lint buildup can cause dryer fires.
Hopefully this will solve your problem
Free Answer...Please rate me
Apr 28, 2011 | GE DBVH512EFWW Dryer
Dryer "clean lint filter" message
Hello. Begin by unplugging the plug on the dryer. Then pull out the filter and thoroughly examine the space that the filter slides into looking for any lint. Remove any lint that you find. Put the filter back and lastly plug the dryer back in.
These steps should solve the problem. If not, then the lint sensor has gone bad and should be replaced. If you wish to do that yourself you can go to searspartsdirect.com. Enter the model number of the dryer and then you will see the parts diagrams allowing you to locate that lint sensor, and even order a new one. Joe
Thanks for choosing Fixya!
Mar 07, 2011 | Dryers
Admiral Capacity Plus LNC8764A71 stopped heating up, Otherswise fine. Cleaned lint out of front and back. What next?
If this is a gas dryer, you might want to check your thermal fuse. If it's not glowing on start up, replcae it.
Feb 06, 2011 | Admiral AAV7000A
Ijwant to dry my cloth but when i turn on it appear check filter how i am going to fix
You should empty the lint filter. The lint filter catches all the lint from your clothes and will need cleaned occassionally. I clean my lint filter after every load. Towels usually clog the filter faster than other clothes.
Aug 07, 2010 | LG DLG5932W Gas Dryer
I need a part number for the lint screen fora 9200l series dryer i lost the manual please help
Hello there:
Whirlpool recommends
8557884 Whirlpool Kenmore Lint Filter (screen)
This Genuine Whirlpool dryer lint filter is used on Whirlpool, Kenmore, KitchenAid and Roper dryers.
Special Note ***** Does your filter have a black spacer below the handle?.
************ If so you may need the Whirlpool Dryer Filter 8557857
The 8557884 Whirlpool Kenmore Lint Filter (lint catcher) is about 17 and 1/2 inches long and has a white handle
Hope this is helpful for you
best regards Michael
Nov 30, 2009 | Whirlpool GEW9200L Electric Dryer
Open Questions:
Samsung Washer WT1101cw will not drain. Originally had a OE error. Running "Spin" or "Rinse Spin" cycles but pump cycles on for less than 1 second and goes into spin with water in it. _Laundry loaded with a OE error and water not draining. _I manually drained the system, took apart the drain and did not find a clog or anything to prevent the motor from turning. _Pump motor reads continuity. _Ran multiple SPIN cycles and then a RINSE and SPIN cycle and actually had the pump run for a few seconds and even for a minute or so one time but could not repeat and hasn't since. _checked the Pressure Switch and see continuity between common and outside contact. Tried to increase pressure by blowing into the tube using a straw on the end of tube but saw no change. Not sure how the pressure is created inside the bowl. _There was no overfill condition originally and I have not tried to run a normal cycle because the washer is in an upstairs location and draining is difficult and messy. ___I believe that something is preventing the voltage from being sent to the pump motor but I have am not sure what logic conditions need to be satisfied for this to happen.I keep looking at the pressure switch because the drum will perform a load sense and then go into a spin cycle with water in it which sloshes around. Questions: --Shouldn't the drain pump normally be running prior to the spin? --what causes the change in the pressure switch? Does the switch only change at a "full" level? Please only answer if you have a clear understanding of the system. I am trying to avoid excessive expense in this repair and swapping parts unnecessarily. I am beginning to think that it is the control board and do not want to spend hundreds of dollars if it is not. Thanks.
Apr 23, 2018 | Samsung Washing Machines
Washing Machines Logo
Top Washing Machines Experts
