Question about Protocol Manta 4-Channel Radio-Controlled Quad-Copter
Intruder ufo won't lift up - Protocol Manta 4-Channel Radio-Controlled Quad-Copter
If it lifts steadily but has no height check the battery may be at the end of its life.
HTH
Apr 20, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Intruder won't start battery gets hot
Could be the stators & regulator/rectifier if its over charging the battery. I'm not a mechanic just saw this video on youtube cause I'm having problems with my electrical system as well and trying to figure out the problem. http://www.youtube.com/watch?v=MWU2TbEePsY
Sep 16, 2012 | 2001 Suzuki VL 1500 Intruder LC
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
Daughter has a micro ufo (blue) and the little remote light keeps flashing what needs to be done so it will fly the way it is suppose to.
I recommend that you take your product back to the place
of purchase for an exchange or refund because it appears
to me that it has a glitch or a mafunction.
Do make sure you have your receipt..
Jul 06, 2010 | UFO Rc Remote Control R C Controlled Ufo...
Removing the seats on a suziki vs800 intruder
there are 2 bolts under the front area of the forward seat each side remove the 2 bolts lift the seat and forward to remove,then you will see 2 more bolts for the rear seat remove them slide the seat forward and remove it.
May 11, 2010 | 2004 Suzuki VS 800 Intruder
Removing the seat on a 2004 suzuki intruder 800 to install saddlebags
Bend the rear sent in the middle while pushing it forward, the back tabs will come loose so you can lift the seat up.
Sep 11, 2009 | 2004 Suzuki VS 800 Intruder
How to remove rear seat on 2004 intruder 800
It has a bolt underneath the seat material at the rear far end of it.You must lift it to see it.It should be in the middle of the seat's width.
Jun 08, 2009 | 2004 Suzuki VS 800 Intruder
How do you remove petrol tank from suzuki 125 v twin i am trying to free the choke cable from carburetta end as it is siezed { won;t budge]
Had the same problem, had to cut the cable and use WD40 and tweezers to free it BUT i'm sure there's a better way.
The Tank is attached to the frame via one bolt under the tank nearest the seat and after you remove the fuel lines the tank lifts up and off, lift seat end up first.
Hope that helped.
Feb 22, 2009 | 2001 Suzuki VL 125 Intruder LC
Protocol Manta 4-Channel Radio-Controlled Quad-Copter Logo
54 people viewed this question
Top Protocol Toys Experts
scamatics777
Level 1 Expert
 Mikey
Mikey
gmduvall
Are you a Protocol Toy Expert? Answer questions, earn points and help others
