Question about Samsung HMX-W300
My camera got a charge but not turn on
Turn the ligth on charge side but not turn on
How do I fix the brake ligths?
Did you check to see if there is a fuse on the brake lights circuit?
If you changed the lamps and the brake switch it is obvious that they are not being energized.
Aug 31, 2015 | Cars & Trucks
96 Jaguar XJ6 No start
need to run a scan on it
Feb 21, 2014 | 1997 Jaguar XJ6
I just bought two flood lamps to fit to the bumper of my 95 jeep wrangler, how would i wire them to a toggle switch?
  1. 2-wires on each fog ligth
  2. toggle switch 2-hook up
  3. okay run hot wire from battery to one side of toggle
  4. on fog ligths one wire migth be white or black
  5. take one of the wire on fog ligth (white)&other fog ligth (white)wire
  6. take a wire hook both white wire from both ligths an hook to this wire an run it to the other side of toggle
  7. black wire on ligths hook them to ground
  8. after you hook the ligths up an they work it best to put a fuse connector between one of the wires on toggle
Dec 06, 2010 | Jeep Wrangler Cars & Trucks
I hav a TFDVD 1973 LCD COMBO TV.THE REMOTE WII NOT OPERATE THE THE TV, BETTERY IS GOOD , THIS IS A NEW REMOTE RC-024
good day! i have read your problem, i teach some simple tips to check whether your remote control is working or not considering you have a good battery. 1st tip is buy checking it through you cellphone camera. turn on your camera and point your remote control on your camera lens the press any button on your remote. if your remot is good you could see some ligth flashing from your cellphone screen witch indicates that the infrared is working. if thereis no ligth at all the remote is deffective. if there is a ligth and still it does not work in your tv maybe the remote you have is no compatible with your unit or the sensor receiver itself of the unit is defective. i hope this will help you.
Sep 29, 2010 | Coby Televison & Video
I have camera samsung L83T it wont charge what happens is when i plug in socket green light comes on on charger then red ligth flashes a couple of timers then goes off any answers thanks
Hello :
It seems that the battery is dead [ can't be recharged anymore ] . Just replace it and problem will be solved .
good luck .
please rate !
Apr 02, 2010 | Samsung L83T Digital Camera
My kodak M1063 digital camera was working great with no problem, my husband started useing it but the batterie was low and needed charging he didnt want to wait so he took out the batterie and put a...
The old used battery was probably not used for a long time and in time, completely discharged and died. It can't be brought back. I don't know why your camera won't turn on with the original battery.
Dec 23, 2009 | Kodak EASYSHARE M1063 Digital Camera
My Canon Camera's lens will not go back into camera when turned off. It goes in, comes out, beeps and the screen is black. It will let me review pictures taken though.
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep theFREE service online ++++ Thank you for using Fixya com
Sep 01, 2009 | Canon PowerShot A75 Digital Camera
Taking the picture
The green ligth means the flash is charged, but it should come out by itself almost as you shoot. There's probably no energy in the battery pack (includded in the film cartridge.)
Feb 25, 2009 | Polaroid OneStep Express Instant Camera
Exilim EX-Z75 dead battery
Has anyone found a solution to this? I have the same issue!
Jul 14, 2008 | Casio Exilim EX-Z750 Digital Camera
Battery
Is the green light you described the 'charge' light or the power light?
Jan 14, 2008 | Dell Latitude C640 Notebook
Samsung HMX-W300 Logo
78 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
