Question about Ahead Software AHEAD NERO 6.0 SUITE 3 CD/DVD BURNING (CD ONLY) (NERO60SUITE3)
Glary utilities pro v2.49.0.1600 registration code
Problem signature: Problem Event Name: APPCRASH Application Name: integrator.exe Application Version: 12.0.2110.8 Application Timestamp: 4ec65a41 Fault Module Name: MainControls.bpl Fault
If this is causing you to have crashes, the .exe is probably corrupt. It belongs to booster and certain tuneup utility programs ("Dachshund Integrator or TuneUp Utilities (version 2006, 2009) or Glary Utilities (version 3) or Glary Utilities PRO or Auslogics BoostSpeed"). If you have any of these programs installed I'd uninstall it and restart your computer. Then reinstall if you want to use the program still, though preferably after an update. I'd also clean your computer with CCleaner and remove junk files before reinstalling. This will clear corrupted files that might not have been removed with the uninstallation of the program. If you continue to experience this issue, install sandbox and make sure the program runs within sandbox. This will prevent any faults or issues with the program from interfering with your OS.
Sep 07, 2014 | Microsoft Windows Vista Home Premium with...
Tip
2 portable registry cleaners
Hi there and welcome at Fixya, the support team tip (lfete)
I will review 2 portable programs I use to clean computers:
  • Glary Utilities
  • Wise Registry Cleaner
Glary Utilities
At first I thought Glary Utilities is the same as Ccleaner, but after studying the suggestions of Glary Utilities, in terms of cleaning the registry, I could see that Glary Utilities finds different errors than CCleaner but is also safe to use. Because Glary Utilties is portable it was easy to test it on other machines without leaving any trace on the computer that the program has been there, and that is a thing I like very much. Remember, you do not want to spend time to install and then uninstall a registry cleaner.
Glary Utilities main window
Glary U. description of chosen entry
Glary Utilities after cleaning
Initially I used the installer version, not portable verison, of Wise Registry Cleaner, because at the time I did not know there is a portable version of Wise Registry Cleaner. However I am glad I used Wise Registry Cleaner, even though I had to install it, because it found around 400 entries to delete (safely) the first time I ran it, and it had a good explanation for what each entry is, what it is for, and what category it belongs to. If you do not know many things about registry try to scan your computer with this software, highlight individual entries, and see on the bottom of the window what it is for a file and why you can delete it; this way you can learn a lot about registry and registry cleaners. Of course if you scanned your computer for learning purposes only, you can always choose to not delete anything, closing the program after you read all the info. With Wise Registry Cleaner, only the registry entries which are "safe" to delete are checked for deleting by default; however you can always manually check the other entries there are a lot of possibilities here if you want to go further.
Wise Registry Cleaner after scan
Wise Registry Cleaner backup of registry
Wise registry Cleaner info on entry
Wise Registry Cleaner after cleaning the registry
I use these programs I just mentioned to clean my computer and others. One of the biggest reasons I find them all so useful is all three have portable versions so you can have them on a USB stick and clean computer after computer without having to install anything. The other main reason I have used these to is because I havent had any problems after cleaning computers with them if I use the safe/default mode of course.
You can use them separately or together. Together they clean better, because in one way or another they each find different errors on the computer as they search in different ways.
Personally, I categorize them in the following 2 steps:
  1. Middle phase cleaning - Glary Utilities (at default settings)
  2. Deep cleaning - Wise Registry Cleaner (delete the safe ones (they are marked safe) registry files)
You can download the programs from the following links:
( For more tips to computers I can recommend this site :
http://dottech.org/ )
Glary Utilities homepage [direct download to portable version]
Wise Registry Cleaner homepage [direct download to portable version]
Have a nice time over there
on Mar 20, 2010 | Computers & Internet
Kim komando website
There are many out there you can choose.
If this is a windows machine you will find these utilities easy and quick.
CCleaner
CCleaner PC Optimization and Cleaning Free Download
Glary utilities
Glary Utilities Glarysoft
Did I mention I also like Free. :)
Good luck hope this helps!
Mar 27, 2014 | Computers & Internet
How can i delete myjobsradar account
A widely used and respected Windows Utility is Glary Utilities program that is great at cleaning up your PC and removing unwanted programs.
BUT, If it comes back, Dowload Malwarebytes Anti-Malware and get rid of it.
http://download.cnet.com/Glary-Utilities/3000-2094_4-10508531.html?part=dl-6280556&subj=dl&tag=button
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=mncol;1
Jul 21, 2011 | Computers & Internet
Avira anti virus can't install
Un-install Avira Anti-virus Then Download and Scan By Using Glary Utilities
Optimize, clean and boost the speed of your Windows.
Protect your privacy and security.
Block spyware, trojans, adware, etc.
Fix certain application errors.
Simple, fast and User friendly interface
For only private use One Click A Day For PC Maintenance, Keeps Any PC Problems Away. With millions of worldwide users, the first-rank & free Glary Utilities is an INDISPENSABLE friend for your PC, with its 100% safe, thorough & quick cleaning and worry-free restoration.
Glary Utilities is a freeware with registry and disk cleaning, privacy protection, performance accelerator and amazing multifunctional tools. It can fix dogged registry errors, wipe off clutters, optimize internet speed, safeguard confidential files and maintain maximum performance.
The era of PC vex is dwindling as Glary Utilities comes. It is a freeware with registry and disk cleaning, privacy protection, performance accelerator and amazing multifunctional tools. It can fix dogged registry errors, wipe off clutters, optimize internet speed, safeguard confidential files and maintain maximum performance.
It is designed for both novice and professionals. User-friendly interface shows clear & detailed directions. For novice, all work can be done with just 1 or 2 clicks, while for professionals, abundant options are available.
To call Glary Utilities helpful would drastically understate the situation. It hopes to become your INDISPENSABLE friend with its one-stop-shop utilities for optimizing and maintaining your PC for best performance. My friend, welcome to have a try for Glary Utilities and have your say! To download Glary Utilities Press here http://download.cnet.com/3001-2239_4-10322935.html?spi=b1d949f58a45ea56498a7664cb708430
Download by Using ATF-Cleaner.exe was once upon a time just my personal temp file cleaner. There became a need for a good temp file cleaner that could do the job safely and without removing files that are crucial to windows, so I decided I'd share it with the public.
ATF-Cleaner has recently picked up alot of interested in the various communities online.
ATF-Cleaners options are fairly straight forward and its simplicity is part of its charm.
The general instructions for its use on the forums are as follows:To Download ATF-Cleaners press here http://www.atribune.org/index.php?option...
then Restart you Computer,after you Computer it is open Windows Now Download Again Avira Anti-Virus Press here http://download.cnet.com/3001-2239_4-10322935.html?spi=b1d949f58a45ea56498a7664cb708430
Jan 03, 2011 | Avira AntiVir Personal - Free Antivirus
How do i delete match.com
First, Delete your Match.com account on Match.com, then you right click on Match.com in your Favorites/Bookmarks in your browser, and choose to delete it. Go to: www.download.com and in the search bar type: Glary Utilities <Hit the Enter Key>
Find the Free version of Glary Utilities on the list and click to Download. Run it/Install it and when done, the Glary Utilities pops up. Click on the "1-Click Maintenance" navigation menu, Check the box that says "Tracks Erasor" (Once you do that, all history entries, cookies and passwords to those sites that are remembered are gone till you put them back after the cleaning) and click on "Scan for Issues" button. Once it's finished, Click the "Repair Problems" button. Close Glary Utilities.
One thing left is for you not to go back to Match.com and your fixed! :)
Cheers!
Oct 28, 2010 | Yahoo Mail
When I run the following program free registry fix I get the following message and the program terminates "Access violation at 0x7C90E8E5 (tried to write to 0x00030FA0), program terminated."
Try a new registry utility. I recommend "Glary Utilities" from glarysoft. Free for personal users and I've personally installed it on over 50 different computers and have had it on my computer in many different versions for 8 years now.
http://www.glaryutilities.com/
p.s. the pro version's basically only contains the ability to schedule the utility to run automatically, so go with the free one.
Jul 31, 2010 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
Top Ahead Software Computers & Internet Experts
celos
lemesee
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
