Question about Refrigerators
Norcold 6182 burner/orifice - Refrigerators
2 Suggested Answers
rickead1
  • 1998 Answers
SOURCE: Norcold Model 6182 Operates on lp ok Replaced ac
click this link http://bryantrv.com/docs2/docs/600.pdf this is the repair guid to your norcold includes the 6100 models on page 25 starts the Dc operation testing as well as a Dc Trouble shooting guide I would suggest you go through this troubleshooting section as it will help you greatly to diagnose what the issue is with your unit. After you complete the tests mentioned if you have any further questions message me back I await your reply Thanks again Rick
Posted on Jul 24, 2011
Where do I find the orface and air intake on the GE Range
Sealed burner ranges the orifice is in the center of each burner, down inside(brass color). Open style burners the orifice should be under the lift off burner or in some case where the burner tube goes back to the control panel at the control knob. Almost all will be brass color. Oven orifices are at the end of the burner tube where the gas would come into the burner. Air adjustments are usually right near the orifices. A small sliding window with 1 screw holding the adjustment in place.
Mar 23, 2015 | GE 30" Self-Cleaning Freestanding Gas...
Jul 24, 2011 | Refrigerators
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
I bought a Char Broil 2 burner model 463243911 with the natural gas conversion kit. This kit provide just one orifice, thus my question is: where I need change the orifice considered that this model has...
The conversion kit has one orifice for the side burner. The two maim burners are sized for natural gas once the LP orifices are removed. Joe
May 01, 2011 | Garden
Front burner won't get hot
The burner and the orifice may be clogged. To check this, remove the offending burner and tap it lightly on a firm surface. Turn the burner on end, open side down and shake it. If debris falls out that's part of the problem. While the burner is out, check the burner orifice by looking in the brill toward the front control panel, where the burner slides over the orifice. Remove the orifice with a nut driver or appropriately sized sock wrench and check the orifice hole for clogs. If it's clogged, take a sewing needle the same size as the hole or smaller and clean it out.
Reassemble everything and give it a try.
Jan 31, 2011 | Weber Genesis E-310 Gas Grill
I have a Norcold n300 3 way it works on 110 but
try blowing through the gas orifice with compressed air only.
Jul 08, 2010 | Thetford Norcold DE0051 Refrigerator
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
