Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
My photo and copy quality is ****
The yellow on my 5500aio is not working and the yellow on the new ink cartridger is full of the other colors. This was the same with my old cartridge when i changed it. So when i make a photo print or basically any thing in color the yellow is not there
  • Kodak Master
  • 365 Answers
It seems that the yellow nozzle is clogged.
Can you run a nozzle check and see if yellow is represented?
If not you can try to run several cleaning cycles.This does use ink though.
Posted on Jun 19, 2009
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
All my ink cartridges are full, yet anything that needs black ink that is sent from the computer doesn't work. It feeds through and prints everything else but black even with new full cartridges. It copies...
You might try changing preferences in control panel. The defualt for most photo printers is color since that is the most used feature (and sells the most expensive ink!). I finally bought an HP 1000 to use for everyday printing of documents and business items becuase it only needed black and white ink.
Mar 21, 2011 | Canon MP610 Photo All-In-One Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
No color from the ink cartridge
hi this is kamal...
pls purchase a color cartridge new... coz ur color catridge is not working properly...
so pls go through this advice... n let me know...
best regards
kamal singh
Oct 08, 2009 | Canon i860 InkJet Photo Printer
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Lee
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
New yellow ink cartridge not being recognized
check to see if you removed the tape and that its seated all the way down
Nov 14, 2008 | Brother DCP-110C All-In-One InkJet Printer
The yellow ink doesn't print although the ink shows full
Hi there! are you using original canon ink cartridges? if so, your cartridge might have defects, try to replace your cartridge with a new one. If you're using compatible ink cartridges try to replace it with an original canon ink cartridge. Have a good day!
Apr 09, 2008 | Canon i860 InkJet Photo Printer
Photo printing
this might be due to the ink. Try to clean the cartridges and check for the color copy from the front panel of the printer. If the issue is same, try with the power cycle and semi-full steps as follows
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Semi-full steps:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Jan 13, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Problem with the color - Canon Pixma ip 3000 Ink Jet printer
go 2 printing preferances and make shore all your setting are on normal or higher and try again
Nov 28, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
