Question about Candy CPL321K Refrigerator
Refrigerator not gettting cold enough - Candy CPL321K Refrigerator
    New Friend:
  • 24 Answers
Check too see if the temperature to your fridge is set to the right temperature. Maybe you have to get the fridge colder.
Posted on Jul 17, 2017
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
Jun 28, 2017 | Refrigerators
My refrigerator is not gettting cold,and it is leaking water out on the floor
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Kenmore Side by Side Refrigerator
Fridge works on gas...but not on AC
Your heater should measure 44 ohms, give or take 10%.
95 Ohms is way off. The RM2310 uses a 92 ohm heating element, perhaps you installed / were sold the wrong heating element?
Jul 15, 2010 | Dometic RM2652 Refrigerator
Refridgerator is not gettting cold
there might be a leak in your condensor did you try cleaning your coils pull the grate off the bottom and clean coils ie vacuume or air compressors work the best blows everything off if that dont work try the reset button its in one of th corners on bottom turn with a screwdriver that might work
Dec 02, 2009 | Refrigerators
The freezer isn't gettting cold enough to freeze solid and the ice maker isn't making ice because of that too. Repairman says we have a freon leak. Is that a valid response...
possible causes: bad door seals or condensate drain plugged causing evaporator coils (in freezer) to ice up, condenser or evaporator fans not on, condenser coils dirty, compressor not working, or a freon leak. if the back wall of your freezer is frosty or super cold, the coils are iced up. remove the back wall and defrost it with a hair dryer. if the water doesn't drain, unclog the drain tube. check the door seals for gaps. replace if necessary. check the fan in the freezer and the fan in the back. both should come on when the compressor is on. if not, check the fuses on the main board. replace if needed. if all that is fine, and there is no frost, you have a slow leak or a bad compressor. call in a pro or get a new fridge.
Nov 12, 2009 | Amana SXD524VW Side by Side Refrigerator
Top fridge not working. Is it upper thermostate
before you go after that make sure your gettting cold air up fom the freezer, check back on the back wall in the center
if you feel cold air it could be the thermostat, but i would suspect the damper or freezer fan first
Oct 12, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Ammonia smell - very strong and frig not gettting cold
UNLES YOUR FRIG IS 50 YEARS OLD THE SMELL IS NOT PART OF THE FRIG
IF IT IS LEAKING AMMONIA DONATE IT TO THE SMITHSONIAN
Jul 09, 2009 | Refrigerators
Amana side by side keeps freezing up.
there is a thermoistat that turns on the fan when the coil get cold enough so that it doies not send hot air into the freezer compartment after the defrost is done. that could be the problem
Mar 30, 2009 | GE GSS25LGM Side by Side Refrigerator
Candy CPL321K Refrigerator Logo
26 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
