Question about Protocol Manta 4-Channel Radio-Controlled Quad-Copter
Quad copter won't lift off ground
It lifts off the ground and flies for a little bit and then slowly descends to the ground. I repeat preflight and it does it every time
  • 6 Answers
Maybe battery is not accepting charge. I would try using a new battery.
Posted on Feb 12, 2015
Spins to left, will not take off/lift?
GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC ...
www.amazon.com/Hercules-Unbreakable.../B00AAOJ...
Amazon.com, Inc.GYRO Nano Hercules Unbreakable 3.5CH Electric RTF RC Helicopter (Color ... you can remove the 8 or so screws that allow you to pull the fairing off, remove .... Also we purchased our helicopter from HobbyTron.com through Amazon and .... won't spin, so the entire helicopter spins, and doesn't generate enough lift to fly.
GYRO Nano Hercules Unbreakable 3.5 CH Electric RTF RC
Amazon.com, Inc.Nano Hercules Unbreakable Glow in the Dark 3.5CH RC Helicopter ... It can go forward, backward, up, down, left, right and hover. .... It worked for a few flights and now the copter will not fly off the ground. ... and ive had it for a year now and everytime I start it up and it takes lift off it starts to fly backwards but otherwise ok toy.
Hercules Unbreakable 3.5CH RC Helicopter - HobbyTron.com
Dec 26, 2015 | HobbyTron Nano Hercules Unbreakable 3.5CH...
Intruder ufo won't lift up
If it lifts steadily but has no height check the battery may be at the end of its life.
HTH
Apr 20, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Nano copter instructions
How do I charge my Nano QX 18 Gram Quad-Copter?It came with a USB cord but I can not get it to charge.Do I have to go to a specific web site?
Jan 16, 2014 | Toys
Estes quadcopter does not fly up; only left, right, back and foward
How old is the quad? Maybe the gear shafts are dragging. (Not spinning at full potential)
Jan 10, 2014 | Estes Dart Quad Copter RTF ESTE4605
Manta Quadcopter will not take off
the instructions that came with the toy are wrong. you have to turn on the remote first, then plug in the quad. Push left throttle up, then down. It should work now.
Jan 04, 2014 | Protocol Manta 4-Channel Radio-Controlled...
Air hogs pocket copter, brand new. Inserted brand new batteries into charger and controller per instructions. Plug the helicopter into charger and led blinks red as stated. About two or three minutes into...
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | Toys
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
My Syma 107 will not lift off the ground. It lifts a little bit and thats it. Its only a week old.
r u charging from the controller? if so put luthium aa batterys in controller the ones you have in there now may not be giving a full charge, you r turning the controller on when charging heli right? wait for the chareer light to turn back to green from red will tell u charge is done. u must have a computer 2 have posted this so charge ur heli from computer wait 4 it 2 light up red (the usb plug) b sure heli is off when charging the little swith should b forward toward nose of heli if it still wont lift off after a good charge b sure the top part of the blades are tight on shaft, its the two screws just under the top blades 1 of the 2 must b tight on the shaft or it wont get enough power if it is slipping, if it still wont lift off u may have a bad li po battery never run it way down!! always stop flying when u c the heli start to not have enough power to hover, always stop and let batt cool dn then charge, then after charge try 2 wait 4 a little bit b 4 flying 2 let batt cool from charging, i know it is very hard 2 wait, hoppfully u have not fryed the battery if u still cant get it e mail me and i will help u get up and flying good luck the s 107 is my main bird i work on them 4 friends all the time if i had it 2 look @ u would b fly n n 5 mintues my e mail is pznuraz@yahoo.com
Jul 29, 2011 | SYMA Toys industrial New Syma S107 Mini...
My helicopter won't take off, it just spins in circles clockwise until it falls over. It's a 4 channel RC helicopter with gyroscope.
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Jun 06, 2011 | RC Remote Control Helicopter Ready To Fly
Protocol Manta 4-Channel Radio-Controlled Quad-Copter Logo
372 people viewed this question
Top Protocol Toys Experts
scamatics777
Level 1 Expert
 Mikey
Mikey
gmduvall
Are you a Protocol Toy Expert? Answer questions, earn points and help others
