Question about Whirlpool AKZ 515 Double Oven
Thermometer failed and stove gave F03 code we bought a new part but the F03 error code still remain? How do I get the oven to work again?
With new thermometer error code F03 still show and oven doesn't work
5 Suggested Answers
vest6
  • 196 Answers
SOURCE: Oven temp indication
Replace the ERC (Electronic Control Unit) This is the diplay/clock assembly and can be expensive. There are a series of relays on the board and one of the secondaries is bad.
Posted on Dec 30, 2007
  • 148 Answers
SOURCE: power failier
beleive it or not set the clock,I work at an apartment complex and the cleaner always unplugs my stoves to clean behind ,everytime I plug back in PF,Just set the clock hours and minutes,Its just telling you you lost power incase you had something cooking in the oven,you wont think that your oven is broken,and also so it doesnt start automatically by it self please rate this solution thanks
Posted on Jul 13, 2008
localwonder
  • 6784 Answers
SOURCE: Oven wont work,stove (burners work fine
HI. this is a self clean latch malfunction code.
1. If door latched:
1. Disconnect power from unit.
2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Replace door switch.
4. Re-apply power.
5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Posted on Sep 22, 2009
  • 4044 Answers
SOURCE: Whirlpool gold electric oven takes
This actually sounds like a bad controller board based on the problem you mentioned with the temp being 25 degrees off. That tells me it is not reading the internal thermometer correctly. as far as the slow warm up is concerned that could be a bad element or voltage issue. This should be set up as a 220v or 240v. This usually requires a double breaker with each one being 120 volts. Sometimes what happens is half of the breaker will trip and the other half doesn't when that happens the stove still works to an extent but doesn't work totally correct or is slow. Check the breakers and if you have the proper tester or purchase a tester test the voltage at the plug. DO NOT USE A REGULAR MULTIMETER. They are not designed to handle that voltage or the amperage in home wiring lines.
Posted on Sep 09, 2011
At work we have molder ge drop in stoves and we are getting error codes f3 f4, then oven turns off
f3 and f4 are temperature sensor faults. check the thermometer sensor in the oven.
Dec 14, 2014 | GE Kitchen Ranges
Hi Top oven only gets warm no matter where you set
I have a 720ef and the top oven is not that good. The wattage rating is low, from memory about 750 watts and it takes a month of Sundays to warm up. I bought an oven thermometer from Lakeland a little while ago and when the top oven is turned on the Lakeland thermometer is showing that the oven thermomostat is running the oven at 20 degrees below what it is set to. If the thermostat neon is clicking off and on, then the thermostat/oven is working, albeit not as we expect.
Oct 30, 2010 | Stoves Premier 720EMa Electric Double Oven
The ovens will work for a short time and then we get the F-2 error (I think). If I unplug the stove it will work for a short time again.
We have seen this error due to failed components on the control board. If the thermistor and connection look ok, it is probably your control board. They can be bought new or rebuilt at www.fixyourboard.com
Apr 22, 2010 | Maytag Gemini 30" Self-Cleaning...
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool range gas model GS445LEMS
i have the same problem oven comes on but goes back off. help
Jun 26, 2008 | Whirlpool SB160PEE Gas Single Oven
Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Oct 17, 2007 | KitchenAid KESC307 Electric Kitchen Range
Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Sep 28, 2007 | Ovens
Whirlpool AKZ 515 Double Oven Logo
13 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
