Question about Euro-Pro Dressmaker 998B
Tension Thread coming out after sewing
2 Suggested Answers
SOURCE: tHE TOP THREAD IS NOT LOOPED AS IT SHOULD BE FOR STRAIGHT SEWING
is it the right needle for the fabric?
is the needle inserted into the needle holder correctly?
is the machine set correctly for straight stitch?
it's possible that the machine could be out of time.
Posted on Apr 24, 2012
Why does bobbin make thread bunch up
Thread tension is incorrect. See the links
Incorrect thread tension - Brother Solutions Center
support.brother.com/g/b/faqend.aspx?c=au&lang=en&prod=hf_ns55eas...
Jul 30, 2014 - Turn the thread tension dial to select an appropriate thread tension. The appropriate thread tension differs according to the type of fabric and thread being used. ... If the upper threading and lower threading are incorrect, the thread tension cannot be adjusted correctly, even by turning the thread tension dial.
Sewing Lesson 10: How to Fix Tension on Your Sewing Machine - Oh ...
ohyoucraftygal.blogspot.com/2013/10/sewing-lesson-10-how-to-fix-tension-on.html Incorrectly threaded machine: Did you use all thread guides? Did you thread with the presser foot down,which would keep the thread from slipping fully between tension discs? Is thread unwinding freely from the spool, or catching on the spool's slash? Are you using a bobbin as a spool (which can interfere with the thread ...
Understanding Thread Tension on Your Sewing Machine - Threads
www.threadsmagazine.com/2008/11/02/understanding-thread-tension Nov 2, 2008 - When the bobbin thread shows on the right side, the needle tension is too tight or the bobbin thread, too loose, as shown in the middle drawing at right. When the needle thread shows on the wrong side, the needle tension is too loose or the bobbin thread, too tight, as shown in the bottom drawing at right.
Correct vs Incorrect Tension: Your Tension Troubleshooting Guide
www.sewingreviews.org/correct-vs-incorrect-tension-your-tension-troubleshooting-gu... I've seen many sewers make the mistake of using the same tension setting for all their sewing projects and then they wonder why the finish isn't perfect. The fact is, the wrong tension is a sewing disaster. It can ruin your sewing project and literally give you a tension headache. Knowing how to troubleshoot your tension ...
Sewing Machine Thread Tension - Updated - YouTube
? 8:51
https://www.youtube.com/watch?v=sf6oPMbLPzo Jul 12, 2016 - Uploaded by Professor Pincushion
Learn how to correct thread tension so that your stitches come out perfect no matter the type of fabric you're ...
Thread Tension - The Sewing Directory
https://www.thesewingdirectory.co.uk/thread-tension/ When sewing fabrics together problems can occur when the thread tension is not correct, the needle or bobbin is not inserted properly, or the machine is not threaded correctly. Threading instructions for sewing machines and overlockers are included in the machine's manual and should be consulted before you start sewing ...
Incorrect thread tension ' Brother CE1100PRW User Manual ' Page 89 ...
www.manualsdir.com > Brands > Brother manuals > Sewing machines > CE1100PRW Brother CE1100PRW User Manual • Incorrect thread tension • Brother Sewing machines.
images for Thread tension is incorrect.
More images for Thread tension is incorrect.Report images
How to Adjust the Tension on a Sewing Machine: 13 Steps
https://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
Apr 08, 2018 | Sewing Machines
How to adjust tension
Find your manual as it identifies specific parts related to adjusting tension. Here are some pictures of problematic stitches and suggestions on fixing sewing machine tension:
How to Adjust Sewing Machine Tension on Craftsy
Sometimes you adjust something other than the tension:
Adjusting Sewing Machine Tension to Prevent Problems
How to Achieve Ideal Sewing Machine Thread Tension Threads
Dec 04, 2017 | Sewing Machines
I notice the thread from the bobbin is loser than the one coming directly from the spool. Also, one side of the stitching seems normal and the other side seems like a long single stitch
That is tension. Sounds like you need to tighten the upper tension slightly to bring the bobbin thread up. The tension is correct when the upper and bobbin threads meet in the middle of the fabric. Also, tension will not always be constant. It may need to change as you change fabrics, thread, and as your machine ages, so it is best to get comfortable with adjusting the tension for each project.
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Understanding Thread Tension Threads
How to Adjust the Tension on Sewing Machine
Jan 13, 2017 | Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
Bobbin thread is coming out on top stitch.
Check your tension. Rethreading the machine making sure the top thread is well between the disks. Then sample sew. If still present adjust the thread tension lower/looser.
Oct 10, 2014 | Sewing Machines
Singer 5050c top thread coming out of tension control during sewing
What if you get a thread stand? does it happen when stitching vigorously or normal stitching? Thread stands helps keep tension and avoid thread jumps etc...
Nov 15, 2013 | Singer 5050 Mechanical Sewing Machine
How do i adjust the bobbin thread tension?
Refer to page 15 of the manual - http://www.singerco.com/accessories/manuals.html
Before changing the tension settings, be sure to thead the machine with the presser foot up as this also has a tremendous effect on the tension and formation of the stitch.
Apr 29, 2010 | Singer 1120 Mechanical Sewing Machine
Unable to get bobbin to pick up thread from needle.
Check the thread coming out from the bobbins maybe on reverse side,also check the bobbins tension adjust it there is a small adjusting screw.Check also the needle alignment lastly check the upper tension from the tension regulator knob,tension adjustment is depend on the fabrics that you sew.
Mar 06, 2009 | Necchi 3102 Mechanical Sewing Machine
Euro-Pro Dressmaker 998B Logo
20 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
