Question about Hayward H Series Millivolt 250,000 Btu Pool Heater H2501
Hayward heater not staying lit
I have a h series millivolt hayward heater. i have bypassed the high temp limit switch and the pressure switch due to a fault and need replacing.
the igniter sparks and the heater fires up but shuts down after a few seconds.
will wire brushing the igniter get the burners to stay lit .
my yellow system ok light is on.
  • 139 Answers
Possibly poor pilot adjustment or insuficient mv output from thermopile
Posted on Jun 19, 2009
My Hayward h250 Millivolt heater won't stay on. If I jump the "TH" connections I can get the main burners to come on, once I remove the jumper, the main flame goes out. I replaced the pilot assembly and...
you prolly have an electrical short somewhere. follow the circuit and if any safety is getting around 200-250 dc millivolts then theres the problem. otherwise you have an open safety switch, or tsta controls
Aug 07, 2013 | Hayward H Series Millivolt 250,000 Btu...
Pilot stays lit but heater will not fire up
so it is a millivolt .and the answer is yes there is a water pressure switch inside the heater, but also there is a internal flow control valve in right side of the heater,check by removing the 2 bolts, and look inside if there sand left ,by brucken laterals inside filter, also check for gas pressure ,the pilot stay lit ?
Jun 15, 2013 | Pentair Minimax Ch 250,000 Btu Natural Gas...
My hayward h series minivolt heater works for about 1hour then shuts down and when started again shuts down after 1to 2 minutes
This is a fault in the control system...prob the high limit switch or pressure valve
http://www.laarsman.co.uk
Miles
Jun 05, 2010 | Hayward H-Series 200k BTU Millivolt Heater...
MY HYWOOD h SERIES POOL HEATER DOES NOT LIGHT. IT
are you sure the code isnt FO , which would indicate flame sensor failure.usually can be solved by removing and cleaning fl sensor with fine emory cloth.since htr is calling for heat ,pressure switch does not need adjusting
Jul 04, 2009 | Hayward H-Series 200k BTU Millivolt Heater...
Hayward 250 heater won't fire up
Check the control circuit, specifically the pressure switch, for continuity with an ohm meter....any reading over 2 ohms needs to be investigated
Jun 27, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
My Hayward H series main burner will not ignite. The pilot light is lit and seems to be fine, but the main burner will not ignite. Any ideas? Thanks.
There could be several problems here if the main gas valve is ok which can be determined by shorting the TH and TH TP wires the gas valve will ignite. Now you have the chore of determining which safety sensor/switch is bad. Start with the pressure switch then high limits, thermostat, on/off switch. On millivolt heaters dirty contacts are primary suspects as contact resistance degrades the low voltage to activate the gas valve. If you follow the schematic you can isolate the bad part.
Jun 12, 2009 | Hayward H Series
Have pilot light lit but unit willnot come on hayward h350 heater
check millivolt output,if it is in normal range(400-600)check for continuity on pressure switch,flame rollout and high limits.
Jun 06, 2009 | Hayward H Series Pool & Spa Heater...
Hayward H250 (millivolt) pilot won't stay lit
make sure the flame hits the thermo couple if so then replace it lows has them in the water heater section thermo couple gets hot makes millivolt signal then opens gas valve
May 08, 2009 | Hayward H Series Millivolt 250,000 Btu...
Hayward H Series Millivolt 250,000 Btu Pool Heater  H2501 Logo
651 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
