Question about Shoprider Health & Beauty
Need wiring diagram for shoprider 889sl se
The high low switch does not work on low ,the lights also do not work when the switch is on low .Seems something is not is not connected right in the wiring harness,
WeListen2You
  • 538 Answers
SOURCE: need wire diagram for shoprider echo 3
looked high and low, and no go...do you have the old switch still installed?
Posted on Oct 17, 2008
  • 88 Answers
SOURCE: need wiring shematic for fog lights 2005 toyota corolla
im pretty sure these cars were already prewired for fog lights .there should be some plugs behind the bumper to fit them.if not get back i will explain how to wire them up.best of luck.
j_del
  • 1586 Answers
SOURCE: INOP low beam and high beams
The problem is the headlight switch itself - it's one of the most common failures on these cars. The part, brand-new, is about $158 from ECSTuning.com. Replacing it involves removing the airbag and steering wheel - not difficult but a little nerve-wracking due to the power of the airbag.
If this is something you want to tackle on your own, reply back here and I can give you a step-by-step on doing the work yourself. Or you can go to a shop/dealer and just have them do it. They'll probably charge you at least two hours' labor, even though it's a 40 minute job. Let me know what you would like to do.
Posted on Dec 11, 2008
  • 50 Answers
SOURCE: need wire diagram to hook up trailer lights, truck not factory equipped w/harness,
I'm assuming you're just going to splice into the tail light wiring so that's what these wire colors are:
at the tail lamp 3 way connector:
black and yellow = park lamp
dark green and brown = left turn signal
there should be another connector with violet and black wire for reverse lights.
the stop lights are turned on through the turn signal circuits.
Posted on Apr 12, 2009
  • 580 Answers
SOURCE: trailer wiring harness diagrams W/o internet goose chase
Try this Link www.dodgeram.org/tech/mods/electric/trailer_wire.htm
Posted on Jul 10, 2009
Location of the headlight relay.
Has no headlight relay ! your headlamps not working ? high or low ? You have a headlamp switch an a dimmer switch for low or high beams ! The main light switch should have battery + voltage all the time .You can go to http://bbbind.com/free_tsb.html free wiring diagrams ! Shows fuse's , connectors an wires at main light switch an dimmer switch ! Suggest you go on youtube an watch a few videos on electrical circuit testing an how to read a wiring diagram ! Pull the main light switch out of the dash an test for B+ voltage an test at the dimmer switch too. Test the whole circuit !
Aug 14, 2016 | 1995 Ford Taurus
Need wire diagram for shoprider echo 3
Oct 17, 2008 | Health & Beauty
Where can I get a wiring diagram for the shoprider traveso
Nothing is safe, the scooter i had before the one now.Was also stolen.I bought a motorbike chain with lock. You should be able to download as a PDF File the wiring diagram by visiting Shoprider, I am sure they will help you. Hope this helped and good luck
Sep 13, 2015 | Shoprider Health & Beauty
High beam do not work at all low beam works fine when switched to high beam no lights at all
I suggest you first check the bulbs. It isn't unusual that both bulbs fail together.
If the bulbs are ok refer to the vehicle handbook and check the fuse(s).
If those are ok it is time to move onto the supply and check it through with the aid of a wiring diagram. The fault could be a relay or the dipswitch, wiring, connections...
It is worth noting on later vehicles electrical equipment is not switched on with the light, wiper, heater switches but these merely instruct a local black box to send a signal to other black boxes to perform the desired function. In the case of problems a dedicated scan tool will be required for diagnosis.
Aug 10, 2015 | Cars & Trucks
2002 Grand Prix SE console parkling light stays on and highbeams inop.
  • You may have a short to another hot wire. Try removing other fuses to see if any of them affect the dash lights.This will help you to identify which circuits are affected and locate where the short or cross wiring may be. Look under your dash for any melted wiring.
  • Obtain a manual for your car that has a wiring diagram. Haynes or Chilton's are good repair manuals.
Jan 12, 2014 | Cars & Trucks
Shopriders wiring diagram
Hi, what model shoprider is this ?
Regards
Rob
www.gewizrepairs.co.uk
Jan 12, 2014 | Shoprider Health & Beauty
2 speed switch wiring dieagram
The motor will have wiring diagram and voltage on nameplate.
You can re-post question with information that shows on nameplate for more exact information, or keep reading below:
If motor is rated for 240Volts, then it will not work with 120V.
If motor is rated for both 120V and 240V, then either Low voltage or high voltage will work, and one wire will be common, and 1 wire will for 120 and other wire for 240.
If motor is rated 120Volt two speed, then one wire will be neutral, and 1 wire low speed, and other wire high speed. You can connect your wire to either low of high, and cap other wire.
If motor is 240volt two speed, then one wire will be common, and 1 wire low speed, and other wire high speed.
If motor is rated 3-phase, then all three wires are connected to the voltage shown on nameplate.
If motor is rated 3-phase two speed, you may need electrician to wire the motor correctly.
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Jun 08, 2012 | Westinghouse Electric Westinghouse...
1996 vw jetta problem with the headlights. The daytime running lights work fine the high beams work fine, but when you turn on the lights from the switch the driver side headlight turns off. I've checked...
I don't have a wiring diagram ,but on most cars I would say your low beam bulb is bad. Try swapping sides to see if the problem goes with it, or just replace the bulb. You can always keep the new one until needed someday... shadetree mech by necessity.
Dec 09, 2010 | 1996 Volkswagen Jetta
HIGH /LOW BEAM SWITCH NOT WORKING NEED WIREING DIAGRAM
Hi and welcome to FixYa,
On the headlight / switch wiring diagram:
  • 40 - headlight;
  • 41 - HI beam indicator;
  • 42 - HI/LO dimmer switch;
  • 43 - PASS switch;
  • 44 - LIGHTS switch
Good luck and thank you for asking FixYa.
Mar 19, 2010 | 1991 Yamaha TZR 250 R
Ford 2003, F250 Desel, 7.3 Liter Head lights
first thing i would check is the wiring were the plow wiring is spliced in at this is most likly the culprate. or you may have a bad multi function switch in the steering column
Jan 02, 2010 | 2003 Ford F250 Super Duty Crew Cab
Health & Beauty Logo
61 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
