Question about Clothing
Remove wax on fabric
Remove candle wax
    Problem Solver:
  • 18 Answers
Place one layer of greaseproof paper on the ironing board, several layers of absorbent paper such as disposable kitchen towel or tissue, then the fabric centring the wax then more absorbent layers and a layer of greaseproof paper - that protects the ironing board and the sole of the iron. Use dry heat, and press gently, gradually increasing the temperature of the iron until the wax melts and moves into the absorbent layers. Change the absorbent layers several times until there is no trace of the wax left in the fabric.
Posted on Oct 31, 2014
  • 3 Answers
Goodjob
Posted on Apr 21, 2017
  • 3 Answers
Newspaper and a iron put the newspaper over wax spot and iron it.
Posted on Apr 20, 2017
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Clothing Master
  • 572 Answers
Use dry heat, and press gently.
How do you recommend getting candle wax out of carpet? It's been there awhile : Cutting it out isn't an option.
Put a piece of clean fabric over the wax and use a warm iron on top of the fabric to melt the wax, rub and repeat if necessary
Jul 09, 2015 | Vacuums
Tip
Cleaning residual candle wax off glass
Believe it or not you can get dried candle wax off of glass with a MISTER CLEAN MAGIC ERASER!! You can use generic erasers , such as Home Depot or your local grocery store. It works !
on May 23, 2015 | Crafts & Hobbies
Tip
Cocktail Candles
1--Blocks of wax--2 Crayon--3-Cocktail glass or Mug--4-Straw or Cocktail umbrella--5-Wick or mop string- --Cut uncolored wax into ice cubes.Put to side-Melt wax and crayon (your choice of color)-Drape wick from pencil into glass-Drop in straw-Fill glass with colored wax- Mash wax ice cubes in to drink before colored wax gets hardLooks very realSet on bar or table
on Apr 13, 2014 | Crafts & Hobbies
HOW DO I GET RID OF RED CANDLE WAX FROM COTTON PLACE MAT THAT HAS BEEN WASHED AND PLACED IN FREEZER. STILL THERE
Candle wax usually melts around 130F, water boils at 212F. Heat the water to 150 or so and the wax will melt, since its lighter than water it floats to the surface, and away from your garment. Let cool, remove wax. Try to make sure the garment stay at the bottom, small weight etc. If the water temp of you hot water is set at 140 you may get away with just letting it sit in that for a while.
Feb 19, 2015 | Crafts & Hobbies
How do i remove candle wax from a carpet
Fold a paper towel into several layers and place over the wax . Use the heat from an iron (dry not steam) to melt the wax so the paper towel can absorb the wax. You may have to do this several times depending on how much wax is in the carpet.
Jun 22, 2014 | Home
Wick problems
Turn the bowl upside down and use a match or much better, a cigarette lighter to melt the wax directly below (normally above) the black wick, moving the flame it back and forward. Watch out for hot wax dripping onto your skin!
Then turn the bown over and use a butter knife to scrape the wax above the wick away and remove the wax above and on either side of the wick. You may have to do this operation a few times, but eventually you should be able to gently get the knife under the buried wick and (gently!) prise it back into an upright position.
Don't do this roughly, or you could snap the wick off at its base, it needs to be pretty much out of the wax and softened by the flame before you try to bend it back up.
Then light the cantle and let it burn for ten minutes, until the wax all around it is clear liquid - then blow it out, and after ensuring that the wick tip is no longer glowing, quickly crush a few absorbent paper towels into the bowl and upturn it again. The aim is to allow the towel to absorb excess molten wax, which should preven the wick from being buried under wax again when the candle cools.
Apr 11, 2014 | Heating & Cooling
How to remove candle wax table cloth
Avoid to wash with the hot or cold water directly. Just remove the wax first with something apart from the water and after the wax is removed the stains of the same can be removed by water and detergent anyhow.
To know more about the dresses do visit: http://www.beautydesires.co.uk/adult-toys.html/.
Feb 17, 2014 | Computers & Internet
What is candle gel wax?
Gel wax is mineral oil (hydrocarbon) that has been thickened. It burns a lot slower than traditional wax and looks clear so it is visually quite flexible.
Feb 07, 2013 | Crafts & Hobbies
Candle wax from clothing
To remove candle wax from clothes you will need a clothes iron and paper towels. Make sure the iron is on low and the steam setting is off. Take several paper towels and place over the wax stains. Gently move the iron from side to side over the paper towels. Replace the towels as the wax is being lifted and absorbed and be Patient
Rate if Helps
Aug 11, 2012 | Dani 100% Soy Wax Candle Red Clover
How do you remove candle wax from clothing
you will need a clothes iron and paper towels to remove the candle wax. Make sure the iron is on low and the steam setting is off. Take several paper towels and place over the wax stains. Gently move the iron from side to side over the paper towels. Replace the towels as the wax is being lifted and absorbed, and Be Patient!
Rate if helps
Aug 11, 2012 | Cell Phones
Clothing Logo
857 people viewed this question
Top Clothing Experts
Erin Wood
Erin Wood
ray gallant
Da Doc
Are you a Clothing Expert? Answer questions, earn points and help others
