Question about Miele CVA615 Espresso Machine
Miele Coffee Machine CVA615, Other brands of Silicone Grease
After cleaning my Miele Coffee Machine CVA615 I like to re-grease every thing. Is there another type of silicone grease brand that i can use other then the Miele brand and is available anywhere? Right now I order online, San Francisco company, it's a pain. Even to search online, can't find it.
  • Anonymous Mar 12, 2014
    miele coffee machine
  • 132 Answers
The cleaning process intended to degreas the brew unit from the fat contaminated from beans so try to select abeans type with less fat
so the times of cleaning will be less
thanks
Posted on Jun 23, 2009
How do I change the gaskets on the Miele coffee machine CVA615
Good evening
to change the gaskets, screw the things from each other.remove the gasket and put the new one on and screw the pieces together.
kolbrun
Jan 25, 2015 | Miele Coffee Makers & Espresso Machines
Problem with Miele CVA615 Espresso Machine Water
Frankly, there are things wrong that are beyond your scope, mainly because of the domino effect in small espresso machines no matter who makes them. There are multiple thermostats instead of a pressurestat, and on and on trying to replicate what a commercial machine does. In a machine like yours, the slightest failure of a gasket throws off everything. There is better containment of problems in commercial machines, but that too depends on what fails first.
My advice, if you are a home user, would be to get a manual pump machine , such as a Pavoni, (which I have lost respect for since they employed plastic pistons,) or if for a small cafe or bar, something like a semi-automatic job plumbed through a filter. Either way, in all honesty and that has cost me dearly, I warn you about this coffee business, because it is a science and an art.
It is not easy to make a good cup of coffee or espresso, especially.
Oct 10, 2013 | Miele CVA615 Espresso Machine
I need descaling tablets and machine lubricant grease. How can I purchase these items?
Amazon.com sells the descaling tablets as well as the cleaning tablets, Miele brand. Search on "Miele tablets" for example. Third party (non Miele) tablets are available but you might not want to risk using those in your $3K machine. If you search on "food grade grease" you can find a small tube of it that sells for about $8.
Aug 10, 2011 | Miele CVA615 Espresso Machine
I have a Miele CVA615. I think I should replace
Hello Phickok,
It sounds like the perculator may need to be replaced (The entire unit with the 'O' rings on it). As I recall the plunger is an integrated piece that cannot be replaced on the CVA-615/620 models but you may want to contact Miele technical services on this. These first generation coffee systems are very complecated to troubleshoot
Sep 05, 2009 | Miele CVA615 Espresso Machine
Miele cva615 how to make coffee stronger less water
open the door and adjust slide for more grounds, also program prebrewing so it adds a little water to the ground to get them going before the rest of the water is pushed though.
Feb 28, 2009 | Miele CVA615 Espresso Machine
Miele CVA615 remove coffee bean dispenser?
their is a plastic screw below the bean dispenser .once unscrewed you will remove the dispenser
Jul 13, 2008 | Miele CVA615 Espresso Machine
Brew unit in Miele coffee system CVA615 block
It sounds like the connector or wiring that links the LCD display board on the door to the main PCB inside the coffe maker has become loose or damaged.
This would cause the text displayed to become scrambled.
Its a 26 way connector that is labelled JP16 (on the next model up) and is next to a large IC.
Nov 18, 2007 | Miele CVA615 Espresso Machine
Brewunit block
kristijordan,
I had this error message on my machine and was able to take care of it by lubricating the brew unit with silicone. I small tube of silicone grease should have come with your machine. If not I found silicone grease at Aco Hardware (not in a tube) and applied it using a toothpick. Machine has been working great since.
Winesnob
Sep 10, 2007 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
661 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
