Question about Aurora World Aurora Fantasy Stick Horse White
Batteries hoe do I change batteries in aurora stick horse
Bella sara horse codes
One Bella Sara horse code is BSC#CLASSICS which gives you Bella, Jewel, Fiona and Nike. I'm pretty sure that nmckqstkg5 gives you Aurora.
Nov 24, 2013 | Video Game Consoles & Games
Does a 1999 4.0 liter 8 cylinder aurora engine need premium gas
Absolutely NOT! There are not many vehicles on the road that actually require premium fuel. Typically only high end vehicles due. Although the Aurora was Oldsmobile's finest, it does not rank with BMW, Lexus, Mercedes, Uppercrust Cadillacs. Save your money and stick with midgrade.
Apr 29, 2011 | 1999 Oldsmobile Aurora
2001 aurora idling high and low act like it wants to cut off. put it in drive goes with out pressing the gas
if you dont get an engine light on the iddle control valve(its on the intake manifold)is to blame for this kind of problem, do a resistance check using a Fluke Meter(you can get a cheap digital muntimeter at Harbor Freight set it to the horse shoe then do the reading) if you get an "OUT OF LIMIT" reading it needs to be replaced.
Dec 22, 2009 | 2001 Oldsmobile Aurora
My 2001 Olds Aurora heater sticks Converts to the position of vent and floor and you can't get it out. When this happens, you can not adjust the position, turn off the air conditioning, turn on the rear...
Could be the "auto" button for the control sticks in. You should be able to feel this when you press it. If it feels like it doesn't have the same feel at the fan speed, this might be it. You could try removing the knob and using some 90% isopropyl alcohol to clean it.
If that doesn't work, I would try a used heater control module and see if that fixed it. SHould be able to get one off eBay. It's fairly easy to put in.
Oct 30, 2009 | 2001 Oldsmobile Aurora
Where is the battery located on an 01 aurora?
Believe it or not, it is UNDER your BACKSEAT! Just pull up the bottom of the back seat and the whole seat pulls up, and the battery is just sitting there out of the elements. Do NOT jumper the battery there in the car, as there are terminals set-aside in the engine compartment for that. Make sure you write down your car radio code if you are going to change the battery. Good luck!
Jul 29, 2009 | 2001 Oldsmobile Aurora
Aurora World Aurora Fantasy Stick Horse White Logo
60 people viewed this question
Top Aurora World Toys Experts
ray gallant
Are you an Aurora World Toy Expert? Answer questions, earn points and help others
