Question about Mastercool 67680 Evaporative Cooler Air Conditioner
Mastercool only runs on low speed
Hi, hope I can get some help. the cooler only works on low speed. is their a way we can check the thermostat or is their something else we can check? we already replaced the motor we still got the same results. please help. Thanks Monica
  • 659 Answers
SOURCE: mastercool swamp cooler fan doesnt come on.
Are the relays perment on the board or are they seperate from the main board? If they are mounted to the board, you will need to replace the board. Sounds like you are getting a call to the relay but none leaving so this would indicate that you have a bad relay switch.
Posted on Mar 21, 2009
  • 4 Answers
SOURCE: I have a Mastercool 2 speed 1Hp 220 volt cooler
Go manual turn switch, sounds like an overload problem. I have a Mastercool unit and going on 12 years with same motor.
Posted on May 10, 2010
  • 587 Answers
SOURCE: high speed does not work but low speed does
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
Posted on May 30, 2010
Testimonial: "great answer - I'll check it today"
shastalaker7
  • 1515 Answers
SOURCE: we have a champion mastercool
Hi, I am surprised Home Depot didn't have one as this is a very common motor. I don't know where you are from, but if you look on lone for Grangers supply, or Motion industries, they will have this motor for sure. They both are large suppliers of anything you need in this line of parts. This is a very common motor, totally sealed bearings and body with adjustable sheave, ( pulley ). Please let me know what you find. I will be here to help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Aug 14, 2010
alpug
  • 1961 Answers
SOURCE: Mastercool evaporative cooler unit.
check this web site for spareparts of your evaporative cooler
http://www.indoorcomfortsupply.com/Evaporative-Cooler-Parts.htm
let me know!l
Posted on Apr 03, 2011
Why evap 2speed motor now only works on low speed no hi ?
Not an expert just a home owner. There is a separate wire connections for hi and lo you may have something as simple as a lose wire connections. This happened to us.
May 17, 2014 | Mastercool 67471 Evaporative Cooler Air...
I have a MasterCool II MC63/64B and the thermostat has gone out. Since MasterCool is out of business, what model/brand would I replace it with.
If you are just running the evaporative cooler any single stage thermostat will suffice. You can buy them at OSH, Home Depot or Lowe's and probably Ace Hardware.
Aug 03, 2011 | Mastercool 67680 Evaporative Cooler Air...
I noticed a smell coming from the mastercool and now the low speed and low cool does not work.
is it a burning rubber smell or a burning eletric smell. burning rubber smell will be a slipping belt. replace the belt and pullys. tighten belt. electic smell will be a bad thing. have tested by technition
Aug 12, 2010 | Mastercool 67680 Evaporative Cooler Air...
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
Motor does not go from low speed to high speed If the motor is set to low speed it does not turn on until the high speed range is hit then it tries to go from stop to high speed and throws thw belt
MOST OF THE TIME IT IS THE DIGITAL THERMOSTAT OR LOOSE TERMINAL AT THERM. THESE STATS ARE TRICKY TO CHECK. LIKE WHITE ROGERS 4 WIRES CONTROL WITH A RED WIRE TO GREEN YOU GET PUMP WHITE YOU GET LOW YELLOW YOU GET HIGH AND SO FORTH. MASTER COOL DOES IT DIFFERENT SO YOU BUY THEIR TSTAT
Apr 21, 2010 | Mastercool 67680 Evaporative Cooler Air...
The Mastercool cooler is not cooling. It is only
Can you see if water is on the pad?If it is the humidity level outside might be too high,above 15-20%. the dont work too well.good luck.
Jul 11, 2009 | Speed Port-A-Cool 16" Evaporative Cooler...
No low speed on my mobile master cooler module no mmb12c
Could be as simple as the switch, could be as complex as a pole burned out on the motor. If you reverse the connections on the speed selector switch and you end up with low speed and no high speed then you know it's just an inexpensive switch.
May 30, 2009 | Cfm 2000 Swamp Air Cooler MMB10 MasterCool...
Frequent short cycles of the Mastercool swamp cooler
Short cycling can also occur in a thermally protected motor if it is overheating. If the other solution did not work, make sure the belt on the motor is not too tight or too loose. A handy person can check the amperage with an amp probe to make sure it is in limits. The adjust the pulley to put it into specs.
May 27, 2009 | Mastercool 67680 Evaporative Cooler Air...
Vibration noise
unbalanced mounting or unbalanced fan. check how it stands and make adjustments.
May 12, 2009 | Mastercool 67680 Evaporative Cooler Air...
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
18 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
