Question about Boating
Lowrance x45 replacement - Boating
My Lowrance 5500c powers up gets to aquired satelites and then stops on that page.No buttons work and the power has to be disconnected to turn off.
It is an old unit, it has been discontinued, there are no software updates for it.
Technology has moved on with larger High Definition displays, colour and side imaging. Time to retire it and look at Humminbird. I have the 998 HD Si. That replaced a 798 before it. Lowrance have the Chirp equivalents if you want to stick with Lowrance.
Or you could return it and see if they can fix it
http://www.lowrance.com/en-US/Products/Chartplotter/GlobalMap-5500C.aspx
I did find your manual :>)
http://www.lowrance.com/Root/Lowrance-Documents/GlobalMap5500C_0151-271_012105.pdf
Oct 03, 2016 | Lowrance GlobalMap GPS
5150c demo lowrance
This is a common problem with Lowrance products. Unfortunately they only service their product for seven years after prduction date. You might check with lowrance to see if you can get the unit serviced but most likely you will need to replace the unit.
Jul 16, 2013 | GPS
WS-X45-SUP6L-E Led is not coming to green
If you have two SUP's this one will be in standby mode.
Mar 10, 2012 | Cisco Computers & Internet
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
Mar 01, 2010 | Lowrance Lms 525c Df 5" Df Sonar...
Broken wire between saitek x45 joystick and throttle boxes
ditto hapend to me, call there support line or go to there webpage and get a replacement if under warranty if not the cord is around 5$ CAN.
Dec 31, 2009 | Saitek X45 Flight Control System (J24C)...
GPS Does not work
If you have a memory card inserted, remove it...if the problem goes away, try replacing that card. If the problem occurs with any card then...
Try installing the latest update from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
even if you already had the latest...try installing it again.
If the problem occurs with any card, and after updating or attempting to update, there is a probably a malfunction with the XOG and it will need to be repaired/replaced. The Lowrance contact by phone is 800-324-1356 and go to http://www.lowrance.com/en/Support/Product-Support/Contact/ to email them.
Apr 11, 2009 | Lowrance XOG GPS Receiver
Lowrance 330c screen says '' boot failed''
Try a hard reset:
1. Turn the LMS-330 off
2. Press and hold the ZIN, ZOUT, and PWR buttons
3. Release the three buttons once you see the "warning, do not rely..." message appear
If you get that far, the problem is solved. If you get boot failed again, try installing the latest update which can be downloaded from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If you still get boot failed, you will need to get the LMS-330 repaired/replaced. You can contact Lowrance support at 800-324-1356 or email them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
Mar 22, 2009 | Lowrance LMS-330C GPS Receiver
Saitek x45 throttle gameport connector needs to be rewired
Sorry to say this so vaguely, but Google it. I am positive that Google will have the answer. Type in the model number, name, and what you need for it and you will be satisfied.
Feb 16, 2009 | Saitek X45 Mouse, Joystick
Need manual to download
You're in luck! Visit => http://www.lowrance.com/en/Downloads/Manuals/
There are 3 manuals (pdfs). The first is the manual, the next two are addendums.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-15MT_0133-49.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-70_add_031402.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-71_add_032802.pdf
Please leave feedback. Thanks in advance.
Jan 03, 2009 | Lowrance GPS
Boating Logo
27 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
