Question about Bushnell Pro 1600 Tournament Edition Laser Rangefinder With Pinseeker
Battery door latch broke on my bushnell 1600 pro rangefinder. I have replacement and need to know how to take it apart?
How do i access mounting screws on battery cover.
SOURCE: bushnell 400 rangefinder won't show yardage
does anyone have the same problem? How do you fix it?
Posted on Nov 30, 2007
SOURCE: Bushnell Yardage Pro Compact 600
Mine broke too. Called busnell Customer Service and they sent me one.
Posted on Nov 03, 2008
  • 115 Answers
SOURCE: need an instruction manual for a bushnell pro 500
this can be obtained by calling bushnell customer service at 1-800-423-3537.
Posted on Feb 04, 2009
  • 133 Answers
SOURCE: Bushnell Pinseeker 1500 Laser Rangefinder
All these units need an alignment....Vibration and dropping are slow death to Pinseekers.
Posted on Apr 24, 2009
  • 133 Answers
SOURCE: Nedd battery cover for Bushnell Medalist
call Bushnell at 800.423.3537
ask them for one...about 7-8 bucks
mtg
Posted on Oct 08, 2009
The heater blower stopped working and the fuse is not blown?
Blower Motor Removal & Installation W/O Air Conditioning Blower Motor (W/O Air Conditioning) gm-10-00-634.gif
To Remove:
  1. Remove the PCM.
  2. Remove the coolant reservoir.
  3. Remove the rear coolant recovery reservoir mounting stud.
  4. Disconnect the cooling tube from the blower motor.
  5. Disconnect the electrical connector from the blower motor.
  6. Remove the blower motor mounting bolts.
  7. Remove the blower motor insulating cover.
  8. Remove the blower motor.
To Install:
  1. Install the blower motor.
  2. Install the blower motor mounting bolts.
  3. Connect the electrical connector to the blower motor.
  4. Connect the cooling tube to the blower motor.
  5. Install the rear coolant recovery reservoir mounting stud.
  6. Install the coolant reservoir.
  7. Install the PCM.
W/ Air Conditioning Blower Motor (W/ Air Conditioning) gm-10-00-633.gif
To Remove:
  1. Remove the PCM.
  4. Disconnect the electrical connector from the blower motor.
  5. Move the PCM connectors out of the way.
  6. Remove the blower motor access cover screws. CAUTION
    Do not cut any deeper than necessary in order to remove the access cover.
  7. Cut through the access cover on the cut line using a sharp utility knife.
  8. Disconnect the cooling tube from the blower motor.
  9. Remove the blower motor mounting bolts.
  10. Remove the blower motor.
To Install:
  3. Connect the cooling tube to the blower motor.
  4. Install the blower motor access cover.
  5. Install the blower motor access cover retaining screws.
  6. Using black weather-strip adhesive, seal the cut line.
  7. Connect the blower motor electrical connector.
  8. Reposition the PCM connectors.
  9. Install the rear coolant recovery reservoir mounting stud.
  10. Install the coolant reservoir.
  11. Install the PCM.
Feb 08, 2011 | 1996 Chevrolet Blazer
Can't open the battery door
Yes, I just got a new 3.5 model today and had the same problem. There is a black plastic attachment on the back of the device that covers up the screw to the battery compartment. You can slide it off the device by depressing a little tab at the top of this attachment between the two sliding tracks that mount the attachment to the device. Once you remove the attachment, you can access the battery door screw either with a screwdriver or by hand (using the semicircular wire mounted on the screw). Hope that solves it! -- Paul in Boston
Dec 25, 2010 | SkyCaddie SG 3.5 Handheld GPS Receiver
How to change blowermotor on 2001 gmc jimmy
To Remove:
  1. Remove the PCM.
To Install:
  7. Install the PCM.
To Remove:
  1. Remove the PCM.
To Install:
Dec 08, 2010 | 2001 GMC Jimmy
How do i reinstall a computer on a 1997 nissan maxima?
The first thing you always do is disconnect the negative battery cable. Now locate the ECM or computer. It should be right beside the accelerator pedal on that model. There is usually an access panel there that covers it unless soneone has removed it and discarded it. there is one plastic screw holding the panel on but it also hooks on the right side as well. remove the EMC mounting screws and pull the unit out. Now remove the multi wired plug from the rear of the ECM and install your new ECM. Reinstall into the mounting and replace the cover. Reconnect the negative battery cable. now the car should start and run normally if there are no other problems. Thank you for asking at Fixya.com
Nov 24, 2010 | 1997 Nissan Maxima
How do i install a new dash for 83 mazda rx7
Instrument Panel and Pad REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. If so equipped, unfasten the inside hood release handle.
  3. Remove the steering wheel and the lower steering column cover.
  4. Remove the glove box, switch panel and console. Fig. 1: Loosen the retaining nut to unfasten the inside hood release handle 85810013.jpg
    Fig. 2: If necessary, remove the dash mounted speaker covers to access hidden instrument panel bolts 85810003.jpg
    Fig. 3: Due to space limitations, some bolts are best removed with an open end or box wrench 85810004.jpg
    Fig. 4: Other bolts are easily removed with a socket 85810005.jpg
  5. Remove the meter (gauge) hood, heater control panel mounting screws and separate the heater controls from the instrument panel frame. Remove the combination meter.
  6. Remove the air duct(s) and the steering shaft mounting bracket bolts. Allow the column to lower.
  7. Disconnect and label the meter wiring. Unfasten the mounting bolts and remove the crash pad and instrument panel. Fig. 5: Some of the instrument panel attaching bolts are hidden behind removable trim covers or plugs. Carefully pry off the cover . . . 85810006.jpg
    Fig. 6: . . . then remove the bolts with a socket 85810007.jpg
    Fig. 7: The glove box must be removed to unfasten some of the instrument panel retaining bolts 85810008.jpg
    Fig. 8: Other retaining bolts are accessible with the meter hood and combination meter removed 85810009.jpg
    To install:
  8. Position and fasten the crash pad and instrument panel, being careful to route the wiring correctly. Attach the meter wiring to its appropriate connections.
  9. Raise the steering column to its normal operating position and install the steering shaft mounting bracket bolts. Connect the air ducts.
  10. Install the combination meter. Install the heater controls into the instrument panel frame with the mounting screws. Attach the meter hood.
  11. Install the console, switch panel and glove box.
  12. Install the steering wheel column cover and steering wheel.
  13. If applicable, attach the inside hood release handle.
  14. Connect the negative battery cable.
Nov 05, 2010 | 1983 Mazda RX-7
How do I replace third brakelight in 2005 Escalade
High-Mount Brake Light Removal & Installation Except Avalanche and Cadillac To Remove:
  1. Disconnect or remove the following:
    • Negative battery cable
    • Open the hatchback door
    • Pry open the center high-mounted stop lamp (CHMSL) access cover with a trim removal tool
    • Electrical connector
    • Screws and the CHMSL
To Install:
  1. Install or connect the following:
    • CHMSL with the screws. Tighten to 17 in lbs (2 Nm)
    • The CHMSL access cover
Cadillac except Escalade EXT To Remove:
    • CHMSL retainers
    • Lower the hatchback door
    • Raise the CHMSL
    • Electrical connector and CHMSL
To Install:
    • Mounting screws into holes. Tighten to 10 in lbs (1.2 Nm)
Avalanche, Escalade EXT To Remove:
    • Rear compartment cover
    • Cargo box bridge center mounting screws
    • Panel assembly from the vehicle
    • Electrical connector.
    • CHMSL fasteners.
    • Remove the CHMSL from the cargo box bridge center bar.
To Install:
    • CHMSL to the cargo box bridge center bar with fasteners
    • Electrical connector to the CHMSL
    • Panel assembly to the vehicle. Tighten to 62 in lbs (7 Nm)
Oct 15, 2010 | 2005 Cadillac Escalade
Where is the blower motor resistor in a 2001 dodge caravan se. I do not see it behind the glove box. I do see soemthing similar under the hood on the passenger side aginst the firewall but it is not...
Caravan, Grand Voyager, Town and Country, Voyager, 2000-2004
Blower Motor - Removal & Installation
  1. Disconnect and isolate the negative battery cable, then wait 2 minutes before proceeding with the removal. This will effectively disable the air bag system preventing possible personal injury.
  2. Remove the glove box from the instrument panel.
    Fig. The blower motor is located behind the glovebox, behind the blower motor cover
  3. Remove the A/C-heater blower motor cover.
  4. Disconnect the blower motor wiring connector.
  5. Remove the blower motor wiring grommet and feed the wiring through the blower motor housing.
  6. Remove the blower motor mounting screws.
    Fig. Once the cover is removed, unplug the electrical connector and push it through the opening in the housing
    Fig. The blower motor is secured to the housing with three small screws
  7. Allow the blower motor assembly to drop downward to clear the instrument panel and remove from vehicle.
To install:
  1. Place the blower motor assembly into position on the A/C-heater unit and tighten the mounting screws.
  2. Route the blower motor wiring through the blower motor housing and seat the wiring grommet in the hole of the blower motor housing.
  3. Reconnect the blower motor electrical connector.
  4. Install the A/C-heater blower motor cover.
  5. Install the glove box into the instrument panel.
  6. Reconnect the negative battery cable. Check blower motor operation.
Auxiliary Heater and Air Conditioner
  1. Disconnect and isolate the negative battery cable.
  2. Remove the right quarter trim panel as follows:
    1. Remove first rear seat. Remove the second rear seat, if equipped.
    2. Remove the sliding door sill plate.
    3. Remove the quarter trim bolster.
    4. Remove the upper C-pillar trim and D-pillar trim panel.
    5. Remove the first and second rear seat belt anchors.
    6. Remove the screws securing the quarter trim to quarter panel from the bolster area.
    7. Remove the screws securing the rear edge of the quarter trim to the support bracket.
    8. Carefully disengage the hidden clips securing the front of the quarter trim to the quarter panel just rearward of the sliding door opening.
      Fig. Removing the trim panel to access the rear blower motor
    9. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
    10. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
    11. Pull first rear seat belt through the access hole.
    12. Remove the quarter trim panel from the vehicle.
  3. Remove the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  4. Twist the blower motor out of scroll housing.
  5. Disconnect the blower motor wiring connector.
  6. Remove the blower motor from vehicle.
    Fig. The rear blower motor is held in place by four screws
To install:
  1. Install the blower motor unit into the vehicle.
  2. Reconnect the blower motor wiring connector.
  3. Secure the blower motor into scroll housing.
  4. Install and tighten the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  5. Install the right quarter trim panel as follows:
    1. Install the quarter trim panel in position in the vehicle.
    2. Insert and pull the first rear seat belt through the access hole in quarter trim panel.
    3. On long wheelbase wagons only, insert and pull the second rear seat belt through access hole in quarter trim panel.
    4. Reconnect the wiring harness connector to the accessory power outlet, if equipped.
    5. Engage the hidden clips to secure the front of quarter trim to quarter panel rearward of sliding door opening.
    6. Install the retaining screws that secure the rear edge of quarter trim to support bracket.
    7. Install the retaining screws that secure the quarter trim to the quarter panel in bolster area.
    8. Install the second rear seat belt anchor (if equipped), and the first rear seat belt anchor.
    9. Install the D-pillar trim panel and upper C-pillar trim.
    10. Install the quarter trim bolster.
    11. Install the sliding door sill plate.
    12. Install the second rear seat, if equipped, and install the first rear seat.
Hope helps (remember rated this).
Jul 11, 2010 | 2001 Dodge Grand Caravan
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
Need to replace the ignation switch in my 2000 chrysler LHS
  1. Disconnect negative cable from battery.
  2. Remove the Instrument Panel Center Bezel, Chrysler and Dodge.
  3. Remove side trim panel to steering column cover.
  4. Remove the screws that secure the steering column cover to the instrument panel and relocate panel.
  5. Pull the steering column cover rearward at the top and right side of the cover to release the snap retainers from the instrument panel.
  6. Remove the screws that secure the instrument panel steering column cover reinforcement to bracket and remove reinforcement from the vehicle. Remove the 2 front mounting nuts.
  7. Remove the lower mounting nut.
  8. Slide the assembly rearward into the instrument panel and down to gain access to switch.
  9. Disconnect the electrical connector from the ignition Switch and SKREEM Module.
  10. Remove the interlock cable by depressing the locking tab and pulling straight.
  11. Remove ignition switch mounting screw.
  12. Squeeze the 2 locking tabs to remove ignition switch from the lockhousing .
Removal and installation of the ignition switch
To install:
NOTE A tab on the ignition switch indexes to a notch in the lock cylinder housing. Also, a slot in the end of the ignition switch fits over the shaft in the end of the lock cylinder housing.
  1. Use the ignition key to rotate the lock cylinder to align the ignition switch with lock cylinder housing.
  2. Insert ignition switch into lock housing until locking tabs are seated into openings on lock housing.
  3. Install ignition switch mounting screw.
  4. Install the interlock cable into the switch assembly. Attach electrical connector to SKREEM Module.
  5. Install switch assembly into Instrument Panel.
  6. Attach electrical connector to ignition switch.
  7. Tighten the 2 mounting nuts.
  8. Tighten the lower mounting nut.
  9. Install steering column reinforcement.
  10. Steering column reinforcement installed.
  11. Install the Steering column reinforcement cover.
  12. Install trim panel end.
  13. Install the Bezel cluster.
  14. Install the ignition switch bezel ring.
  15. Connect the negative battery cable.
May 28, 2010 | 2000 Chrysler LHS
Location of cam position senor
Not a bad job to replace the cam position sensor, it took about two hours cost about $150.00 with oem parts. First remove air filter box,remove plastic spark plug cover. Jack up engine about an inch remove engine mount. Now you can access sensor through a convenient cover that mounts around engine mount bracket extending from engine block.( one ten millimeter bolt) Remove accessory drive belt for a little extra room and replace with new one while you are in there. Just between the two cam gears you will see a torx screw that aligns the switch when in installed. DO NOT REMOVE THIS Just above the torx screw is a reverse torx screw (6 millimeter) Put a shop rag in the access hole to catch the screw just in case you drop it ,( so it does not fall into timing belt cover) Put something "sticky" in the 6 millimeter socket such as gasket sealer to keep from losing screw. remove. Pull switch up from inside spark plug cover and install new one through the same. reinstall 6 millimeter bolt. Switch is self aligning. Reinstall belt, engine mount, air box. Doing this myself probably saved me about $150.00 to $200.00 dollars
Jun 06, 2008 | 2004 Suzuki Forenza
Bushnell Pro 1600 Tournament Edition Laser Rangefinder With Pinseeker Logo
257 people viewed this question
Top Bushnell Photography Experts
Tony
Are you a Bushnell Photography Expert? Answer questions, earn points and help others
