Question about FAN-TASTIC VENT Fantastic 6000rbta 12 volt ceiling fan 3 speed thermostat dome
Fantastic vent 3000
Crank broken
My 01 katana been sitting up it will crank idle for a few than die out and wont crank until it sit awhile
Hi, Kevin and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Bike dies when you give it throttle
Suzuki GSX600F Service Manual
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Oct 04, 2016 | Suzuki GSX 600 F (Katana Motorcycles
I have a 1989 sportser. I can crank the bike up and ride it for a little while but then when it get hots it shuts off.
Hi Anonymous, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Davidson Sportster error codes and how to access them
Jan 03, 2014 | Harley Davidson Motorcycles
1999 r1 flat spot at 3000 r p m
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for leakage in the dark.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
18. Check for engine trouble codes
1999 Yamaha R1 Flatspot Biker ie Forums
http://www.r1-forum.com/forums/101-98-99-r1-mechanical-help/474929-99-r1-3000-rpm-flat-spot.html
1998 1999 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 03, 2013 | 1999 Yamaha YZF-R1
06 road glide will start, run for approx 5 sec. then shut down. It will not continue to run. I have replaced the crank shaft position sensor, drained and replaced the premium gas, replaced my spark plugs....
Hi Jamesgreenjr, and the usual suspects are:
9. Fuel tank empty.
For a prime suspect please visit website below. Good luck and have nice day.Harley Diagnostic Codes 04 to Present
Sep 02, 2011 | Harley Davidson FLTR Road Glide...
The oil dip-stick is blown out of its seat when the compressor runs
Without knowing what make or model you have, check the following:
1. Some, not all, compressor dip sticks have venting holes for the crankcase. If the vent holes are plugged or the check ball is stuck the dip stick will get forced out when the piston comes down.
2. Make sure the oil level is where it's supposed to be. Too much oil in the crankcase will cause the motor to work harder and the excess oil being splashed around the crank case can overwhelm the vents in the case or dip stick and again blow the dip stick out.
3. Worst case, you have worn or broken rings on the piston(s), a hole in a piston or a badly scored cylinder(s) and air is leaking past the piston and creating pressure in the crank case and blowing the dip stick out.
Jan 26, 2011 | Campbell Hausfeld Air Tools & Compressors
Have a 2000 Ultra that will stall out at 2500-3000 rpm. Bike will idle fine. When it stalls have to turn the ignition switch off and wait for the ECM relay to click and the the bike will start and idle....
Hi Fordtech2010, and the usual suspects are:
9. Fuel tank empty.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Sep 27, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
Getting a lot of condensation at wall where the dryer vent attaches, we have moved and the new house has a smaller laundry room. The first time we used the dryer I noticed a puddle of water, checked washer...
My suspicion is that the damper on the dryer vent is not completely closing, allowing the cold air to pass into the house. Also check to see if the vent hose is sealed to the vent with duct tape or steel tape.
Feb 22, 2010 | GE WSXH208A Front Load Washer
A/c blows from floor
sounds like two problems. the ticking sound is probably a broken blend door stop. the wet floor is probably a bad heater core, both require dash removal.
May 20, 2009 | 2001 Cadillac DeVille
98 dodge neon won't start
CHECK FOR CRANK AND CAM TURNING SOUNDS LIKE TIMING BELT.
May 08, 2009 | 1998 Dodge Neon
Crank case overflow is pulling oil out of motor and into airbox
It almost sounds like a ring is broken and you are looking at a motor teardown if you have excessive suction in the crankcase.
Ken S.
Mar 23, 2009 | 2005 Honda CRF 450 R
FAN-TASTIC VENT Fantastic 6000rbta 12 volt ceiling fan 3 speed thermostat dome Logo
Top FAN-TASTIC VENT Dryers Experts
Dan Webster
Dan Webster
Are you a FAN-TASTIC VENT Dryer Expert? Answer questions, earn points and help others
