Question about Hampton Bay Ceiling Fan Wall Control 9050H
How to install a Model:175-776, if I have 3 switches
I would like to mount my ceiling fan (just bought) with a wall mount contol Model NO: 175-776, but i have 3 light swithes available for the same existing light.
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
Cerfer39
  • 709 Answers
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Posted on Oct 29, 2007
SOURCE: reversing direction on remote controlled fan
There is no switch. Put the fan on high then hit the reverse button. Your fan should stop, reverse and you'll bet all set.
Posted on Nov 30, 2008
  • 10865 Answers
SOURCE: i bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Posted on Jun 20, 2009
davea9952
  • 1617 Answers
SOURCE: Hampton Bay Classic Collection 52" remote ceiling light/fan
The wall switch has to be on for the remote to work. You should only be using the remote.
Posted on Jun 20, 2016
Harbor breeze ceiling fans
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Aug 29, 2017 | Hunter 27185 Remote Control
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
Don't have a manual - bought the floor model. Can we adapt the ceiling fan that is designed to be suspended into a flush mount? Have Westinghouse 52SGD or 72458 is also noted on the fan. Thanks for your...
Floor model of a ceiling fan ... think about that for a minute!
I have to say no, you cannot do this. It may be possible but not without a lot of pain and extra expense. I have installed hundreds of fans. You may possibly be able to shorten the pipe that holds the fan but to actually mount it to the ceiling? You will have to have the ceiling hardware to do this. There goes the price benefit even if you can find the proper adapter/ceiling hardware.
Try shortening the pipe that suspends. You may find joy there.
Thanks for your question today. And thanks for the smile ... floor model ceiling fan :-)
Mar 13, 2011 | Westinghouse Fans Indoor Ceiling Fans
I have a two wire (black white) ceiling wiring and the surveyor fan has four - black white blue and green. How can I connect so that the wall unit can control speeds and light turns off and on without...
When you only have two wires in the ceiling , that means that you have only one switch for this fan. The green connects to all green and bare wires and to the mounting bracket .. the white to white .. and the ceiling black connects to the fan black and blue wires .. In this installation the fan and light can be controlled independently with the pull chains
In order to have indipendent control at the wall you would need two switches and another wire going from the switch to the fan/light
Please Vote !
May 13, 2010 | Casa Vieja Casa Surveyor Ceiling Fan
Light does not come on in the ceiling fan
"from the ceiling fan we have black, blue, and white. On the mounting bracket is green. We installed black and blue from the fan motor to the black in the ceiling."
If your fan is working and the light isn't and they are tied to the same wire (black wire), then you might have a bad pull chain switch or bulb.
Feb 18, 2010 | Hampton Bay 56 In. Florentine IV, Brushed...
I just purchased and installed a Hampton Bay palm beach 48' ceiling fan (close to ceiling mount)Problem is when turned on I hear an annoying hummmmmmmmmmmm, more of a hum at high speed and it graduates...
You have a rotating dimmer switch on the wall to control speed right? If so, it is the wrong type switch. The missed matched switch will cause the humming. Use a regular on/off switch and control speed with the pull string
Apr 29, 2009 | Madison Avenue 04317 Hampton Bay Ceiling...
I currently have 2 switches on the wall for a ceiling fan(this was pre-installed when I bought my new home, but my Minka
The red and white should be hot all the time for the fan to run even when the light is not in use. The black and white wires are used for the switch on the wall to turn the light on. Hope this helps.
Apr 25, 2009 | Minka -Aire Brushed Nickel Remote Control...
Installation
I assume that you're talking about a remote-controlled ceiling fan.
There are two parts to a remote-control setup -- the transmitter (the switch which you use to operate the fan and/or light), and the receiver (which receives the signals sent by the transmitter, and directly controls the fan and/or light).
The receiver -- which should look like a plastic rectangle, usually white, grey, or orange-brown in color -- can be identified by the fact that it has several colored wires coming out of it, and doesn't have any buttons. This is mounted in the ceiling fan itself. On nearly all setups, it goes inside the canopy (the decorative part of the ceiling fan, up by the ceiling, which hides the fan's electrical wires).
The transmitter may be either hand-held like a television remote control, or in-wall mounted like a light switch. If you have the hand-held variety, there is nothing to install in a wall box. The wall-box wires should be appropriately connected up, and a blank cover plate should be put on top of the gang box.
If, on the other hand, you have the in-wall variety of transmitter, then yes -- it gets mounted in the wall, in a gang box, like a normal light switch or outlet.
If you need any further clarification, please feel free to ask!
Jun 17, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ceiling Fan Wall Control 9050H Logo
60 people viewed this question
Top Hampton Bay Televison & Video Experts
Jerry Kramer
Jerry Kramer
Tom Chichester
Are you a Hampton Bay Televison and Video Expert? Answer questions, earn points and help others
