Question about Ruud UBHC Air Conditioner
My central air conditioner is putting out cool(weak) air, not cold air
    President:
  • 2,692 Answers
Number one problem is lack of air flow usually due to dirty filter or dirty evaporarator or condensor. Clean and service both , first before anything else.
Posted on Jun 19, 2009
Not blowing cold air
Hello, make sure the filter, blower wheel, and evaporator coil is clean as this can reduce air flow. If the airflow appears ok then the unit may be low on refrigerant, sometimes leaks develop on the schreader valves and they just need to be replaced.
Jul 15, 2012 | Haier HC48C1VAR Central Air Conditioner
I have central air and I was wondering how do you put freon in it because its not blowing out cool air
Is the compressor starting? On the outdoor unit you will see a large copper pipe and a small copper pipe. Is the larger of the two cold to the touch? wet? Just because a central air system is not blowing cool air does not mean it needs freon. If you have clogged filters it cannot do an air exchange. So, I would recommend checking the easiest things first before adding Freon.Most people make the mistake of adding Freon and overcharge their system. In a low load situation you can slug the compressor with liquid and your system is ruined. If you do have to add Freon it indicates that you have a leak. An AC System is a closed system and if it is working properly you should not have to add Freon.
Aug 03, 2011 | Whirlwind FH-778 Air Conditioner
The air is cold, but even when the fan is on high, the air conditioner of my 2004 mpv blows very weak and won't cool van very well.
hello l..... Begin by replacing the air conditioner relay. That should solve the weak fan volume. If the AC still is not as cold as it should be get the AC system charged [add more refrigerant]. The charging requires special tools so most folks leave that to the pros at the garage. Joe
Jul 17, 2011 | 2004 Mazda MPV
THE AIR CONDITIONER IS NOT BLOWING COLD AIR AND THE AIR IS VERY WEAK
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 29, 2011 | Heating & Cooling
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
My central air conditioner is not working properly. It doesn't get cold. All it does is cool air comes out and the house doesn't get cold. What do I do?
well how cool is cool check temp at one of the register should be around 54 degrees. if so you other problems
Jun 26, 2009 | Heating & Cooling
Central heat/air unit for home blows cold air
could just be heat trapped in ductwork for attic temp or from not running for more than a few hours.
Jan 13, 2009 | Haier HC48C1VAR Central Air Conditioner
No cold air on a/c
1. check the fan
2. maybe some place leak
3. Do you still have the warranty?
My central AC had the same problem, lost the freon R-22
Jun 29, 2008 | Haier hwr10xc6 Air Conditioner
Ruud UBHC Air Conditioner Logo
165 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
