Question about Sony STR-DE915
I have a Sony STR DE915 amp. It will not power up. I checked the internal fuse (it's OK). Power button has dislodged and may be broken. Am looking for disassembly instructions (not schematic diagr
Worked a week ago. I've got it partially disassembled, but don't want to make it worse by pulling boards off in the wrong order. Want to get to power button board.
  • 586 Answers
SOURCE: sony str-da50es. Does not power when power button is pushed.
This problem is very common in this model the solution is to replace the fuse with improved one 10A 125V of type CES710A having part No.1-576-695-11. Remember that this fuse would be larger in size of earlier one so that you have to drill it first in the holder and adjust the fuse to a proper space of 1.4 drill bit.
Do the changes and your product work fine.
Thanks.
Posted on Nov 24, 2009
SOURCE: Sony STR-V333ES repeatedly clicks
You most likely have a short in one of your speaker wires (+ and - are touching somewhere) causing the receiver to enter a protect mode "Click!". Disconnect all speaker wires then connect and test each one at a time to find the culprit. I've seen this happen with speaker wire or a subwoofer cable that is too small of a gauge. Hope that helps.
Posted on Jan 07, 2010
SOURCE: No power on my Sony STR-DA555ES
i went to sony's webite and called direct and got a power supply for just under 200 dollars to my door better than paying 1500 for a new one i over loaded mine and plug to may things in the back of it but the part is available
Posted on Feb 11, 2010
  • 105 Answers
SOURCE: I got change the fuses of a Sony receiver Sound
500ma 120v
Posted on Jun 04, 2010
  • 222 Answers
SOURCE: How to know Amp and volts Fuses of a volume board RECEIVER SET-DE
Power output divide it by 110
example 600 / 100 + 5.45
you need to replace it with 6 Amperes or the closest as long as it is not lower than 6
Posted on Jun 06, 2010
Simple, if you are not confident in your ablility to fix the problem by dissasembling the boards then by all means, take it to a repair facility.
Apr 20, 2014 | Sony STR-DE915
No audio. Checked all the basics. Internal fuses are ok. Is this worth fixing?
Check power supply transformer, that could be last thing before deciding to throw it away.
-SS.
Oct 27, 2013 | Sony Stereo Am Fm Receiver Tuner Amplifier...
I have a SONY STR DE915 receiver home theater amp. After 14 years, it decides not to power up! Are there internal fuses? Can i replace the power supply myself?
There are internal fuses that you can check. This model was notoriously bad for amp problems. These amps would burn up a lot of components when they go out.
Oct 11, 2013 | Sony STR-DE915
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Jan 07, 2010 | Sony STR-DA555ES
Hello, I need help with my sony str-de197 receiver. Then I hit power on button, there is a click sound inside the box, but nothing happens, there is nothing on display too. I have checked 2 fuse's, it's...
It sounds like the switch might be OK mechanically but not electrically. Have a look to see if you can check the connections on the switch. Perhaps there is a broken or loose or bad solder joint.
Oct 28, 2009 | Sony STR-DE197 Receiver
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
Sony STR-DE915 Receover, flashing "Protector" when power on
Serious problem either in the power supply or output stages of receiver.
Sep 16, 2017 | Sony STR-DE915
Sony Receiver Won't Power On
Did you have any Rca Cables running to a Tv or anything by accident cuz it could run thru those, Lighting is a powerfull substance, if it hit the house then it could of ran into the cable to the tv an went out, thats wierd this is the 1st time ever hearing this, try looking in side to see any burn markings, an take a wiff cuz you can tell if somthings fried by the smell of it, if it is then its most likly dead
Oct 20, 2008 | Sony STR-DE915
STR-DE915
if your preferring to protect light your either, pushing to much power, or a wire could be touching along the line. Check all your wiring even the ones behind the receiver that could be your problem
Mar 10, 2008 | Sony STR-DE915
24 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
