Question about Kodak B40 Stack Loader For A Carousel Slide Projector Vintage No. B40
Kodak Carousel Stack Loader - Kodak B40 Stack Loader For A Carousel Slide Projector Vintage No. B40
I replaced the bulb but it still won't work
Hi Ssss
Check the thermal fuse.
Normally located at the lamp compartment.
Oct 26, 2015 | Kodak Carousel 750h Slide Projector no...
Kodak carousel 750H slide projector power cord missing
Detatchable power cords for KODAK Carousel Slide Projectors can be purchased from: www.micro-tools.com
or: www.vinevalleyimaging.com
Good Luck!! jim
Sep 13, 2013 | Kodak Carousel 4600 Slide Projector
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
Our Kodak projector 4400 advances the slides too rapidly (1 second or less each slide). This model does not have a variable automatic timer. Any way to slow it down?
The continuous cycle condition is caused by out-of-position cycle contacts. See the attached illustration for the correct position of the cycle contacts.
Jul 01, 2012 | Kodak Carousel 4400 Slide Projector
I am trying to locate an instruction manual for a Kodak 5600 carousel slide projector. Will pay a reasonable price!
Kodak has an e-copy of the manual on their website:
http://support.en.kodak.com/app/answers/detail/a_id/19709
I hope this helps !!
May 13, 2011 | Kodak Carousel 5600 Slide Projector
What is the correct carousel for a kodak 760 H projector?
A KODAK Carousel 760H is designed to be used with either KODAK 140 or KODAK 80 Slide Trays. The KODAK 80 Slide Tray has wider slide compartments, which tend to be more forgiving for older, slightly warped slides.
Oct 02, 2010 | Kodak Office Equipment & Supplies
Trying to find a carousel that will fit Navitar model CP-300AF
I am pretty sure that the projectors modified, marketed & sold by Navitar were Kodak projector bodies & slide transports. Assuming this is the case, a Kodak 80 Tray should work just fine!
Aug 03, 2009 | Navitar 750-AF 35mm 80 Slides Rotary...
Kodak Carousel 760H wont advance or reverse
What's happened is what happens to all that style eventually. There is a small nylon link that has aged and broken in the heart of the mechanism. A very skilled amateur can repair this but it may take a professional. If you are in the USA, start at http://www.kodakparts.com/Pre_1981.html or http://www.fargo-ent.com/kodak.html if you want to try it yourself. It's the same company, basically. If youa re in Canada, go to Doug Banks http://www.photographicrepairs.com/
Dec 04, 2008 | Office Equipment & Supplies
Kodak B40 Stack Loader For A Carousel Slide Projector Vintage No. B40 Logo
64 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
