Question about Dacor Epicure EOG52 Grill
Igniter keep ticking - Dacor Epicure EOG52 Grill
I have a loud ticking in the passenger side of the dashboard as you turn the ignition on
HVAC controls and possible flapper door not engageing and/or broken.
try keeping HVAC controls off while starting car. its prob heater related.
Dec 05, 2014 | Cars & Trucks
Gas cooktop: one of the the units that provides the spark to light the gas keeps ticking. we had to turn off the electricity to the cooktop.
Good Morning Friend,
I understand that you are having trouble with one of the igniters on your Frigidaire gas cooktop. I see that the igniter kept ticking, which led you to turn off the power to your cooktop. Now that you have had the power off, I suggest turning the power back on to see if it continues to tick. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Cooktops
My refrigerator keeps ticking
Blow through the jet and heater gauze to make sure the flame is reaching the end of the thermocouple. If the flame is going out all the time suspect the thermocouple is at fault
Apr 22, 2014 | Dometic Refrigerators
In my 2001 Chevrolet S-10 truck the gauges on the dash are ticking(moving) when the truck is off and the key is not in the ignition. Then the battery is dead the next morning.(Just bought a brand new...
What is happening is that you have electrical problem have you installed an after market radio? or it can be your ignition switch that has gone faulty and is keeping something on. there needs to be some diagnosing done i suggest find an electrician for this. since it is electrical.
Nov 21, 2017 | Chevrolet Blazer Cars & Trucks
The igniter keeps ticking when burners are turned off.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jul 25, 2011 | Microwave Ovens
After spraying stainless steel cleaner on the cooktop, with the knobs removed, the igniter won't stop ticking as if it's trying to ignite. All the knobs are securely in the off position. Could this be...
Yes, the moisture is probably the problem...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
heatman101
Jan 21, 2011 | GE 30 in. Profile JGP933 Gas Cooktop
2 of 4 burners ignite, all tick?
The two front burners are used most often. On the side of the burners are tiny holes that become plugged and keep the burner from lighting. If all the burners are the same size try swapping the heads around. If they are not all the same size be sure they are in the correct position and fully seated on the top. Sometimes the heads have to be replaced when cleaning no longer works.
Jun 08, 2009 | Kitchen Ranges
Gas burners are ticking
The ticking sound you hear is the electronic ignition which is located by each burner. When you turn a burner on the electronic ignition creates a spark which ignites the gas. Once the burner is ignited. turn the knob a bit further and the ticking will stop.
Feb 05, 2009 | DCS RGS-486GD Gas Kitchen Range
Dacor Epicure EOG52 Grill Logo
Top Dacor Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Dacor Grilling Expert? Answer questions, earn points and help others
