Question about Polaroid Spectra 1200si Instant Camera
Top camera will not close down - Polaroid Spectra 1200si Instant Camera
Display screen not light up
Are yo using a stock Nikon battery or an aftermarket brand?? Nikons cameras are all famous for their batteries not staying in their compartments tight which means your battery in not getting a good, solid connection. Open the battery compartment and put a tiny piece of folded paper on top of the battery (on the end where you close the door, not the side with the contacts) and then carefully close the lid, this will create more pressure on top of the battery making a stronger contact. Hope that helps.
Oct 13, 2013 | Nikon D Cameras
How to close a polaroid camera
HELLO,
JUST PUSH FORWARD ON THE TOP OF THE FLASH UNIT AND IT WILL PIVOT DOWNWARD.
May 15, 2010 | Polaroid OneStep Express Instant Camera
Tape insertion problem
Now It needs mechanical adjustment, and your camera work fine again.
Thanks
Mar 03, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
The lens wont close and it keeps saying on screen "lens error restat camera" but when i turn it back on it doesnt do anything
Your lens frame - that which moves out when the camera opens is probable bent. Looking down at it from the top and sides, does it look bent? By grasping is firmly but not hard try softly to bend the lens frame in the opposite direction, carefully.
Feb 19, 2009 | Canon PowerShot A430 Digital Camera
Close Flash On Xti
Turn off the camera and remove the batteries. Then try to close the flash by pushing it down lightly. If it still won't remain closed, your camera is faulty and you should bring it back for a repair/replace.
Hope this helps,
/Chris
Jan 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Close up pics with canon S3 IS
To get the sharpest possible pictures always mount your camera on a tripod.
Step 1 set your S3 camera to Program mode using the wheel control on top of the camera to P position.
Step 2 Press the function button on the rear of the camera, you will see a list of settings appear on the left side of the screen, you can scroll down through each of those settings using the up/down buttons of the up/down/left/right control on the back of the camera.
You can change the settings using the left/right buttons of that same up/down/left/right control. If you change a setting press the SET button to implement the change.
Set those settings as follows.
The top one set it to Zero
2nd one set it to AWB
3rd one set it to OFF
4th one set it to AEB (the center setting) then press SET button. your camera will now take 3 pictures each time you press the shutter, each at a different exposure setting so you can choose the best one.
5th one set it to Zero
6th one set it to Evaluative
7th one is video mode it is not neccessary to change this for taking stll pictures.
8th and last one, set it to L then press the SET button it takes you to a second option set this to S then press SET button again, now the display for that setting should show SL ( this sets your camera to use the highest resolution settings)
Now you have your camera set up you can get ready to take your pictures, press the function button again to close out the settings list.
Keep your camera in Program mode (P on the wheel control)
If you want to take close up pictures,
Press the macro button located on the left side of the lens close to the body of the camera it has a flower icon above it.
On your camera screen you will see it say macro, this is for close ups.
If you hold that same button down for about half a second it will change to super macro mode for extreme close ups. This allows your camera to focus on objects very close to the camera lens.
Position your camera as close to the subject as neccessary to make it fill the screen.
Now if you are using a tripoid, press the shooting mode selection button located just behind the shutter release button, each time you press this button you will see a different shooting mode appear on the screen. Press it repeatedly untill it says Self Timer. This mode allows you to press the shutter release then let go of the camera altogether so you will not cause camera shake. the camera will beep and take the picture several seconds later.
I would strongly recommend you use a tripod but f you are not using one ignore that last step and try to hold the camera as still as possible while you take the picture. If you follow those instructions you should get good sharp pictures.
Nov 04, 2008 | Canon PowerShot S3 IS Digital Camera
My motov3i
hi...ur motorola v3i selects camera when u havnt closed the application fully earlier or when u press the side button accidently...the other applications shud have not been closed properly before you flipped the top....try shutting down and use ur mobile along with a case...that will help
Thanks for using Fixya..tc
Aug 19, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Turn on the camera, cover lens is closed even though i already pull it down
if you open up your casing you will find that almost dead center on the front PCB, just to the right of the battery at the top of the empty battery area there is a box. possibly with some plastic fragment that is broken off. if you touch inside this box w/ something conductive it will think the lens is open. You can either fix this area or permanently solder it so it thinks it is always open. You can still turn it off using the button on the side of the camera
Sep 07, 2006 | Sony DSC-T7 Digital Camera
Polaroid Spectra 1200si Instant Camera Logo
29 people viewed this question
Top Polaroid Photography Experts
Joseph Coppeto
Joseph Coppeto
Duke Mcadams
Duke Mcadams
Level 1 Expert
Are you a Polaroid Photography Expert? Answer questions, earn points and help others
