Question about Northern Tool 12 Room Purple Martin House
Replace water pump impeller 1985 evinrude 6hp outboard
Have an Evinrude 6hp model 6502 that has been in dry storage for 25 years. Motor won't turn. Any suggestions on how to fix? Before it was stored the outboard was cared for
it is a very old unit and the problems will make it very costly to repair
outboards run in water and so there is moisture that gets to the engine and bearings which would probably have rusted up
water pump impeller will be stuck to the hosing and will tear apart if you get it to turn
rings will be rusted in the bore
you could pull it all down and do a list of items to replace
it may be best to use it as an anchor
Apr 04, 2017 | Boating
1977 6hp evinrude water pump direction
The drive shaft going to the lower unit through the water pump turns clock wise. If installing a new impeller, put a little liquid dish soap on it to lube it. While pushing the pump housing down, turn the drive shaft clock wise and this will seat the impeller in the right direction. Hope this helps.
Nov 04, 2016 | Boating
Evinrudeomc 6hp what year
Evinrude OMC Model#E6REIA. Year please.
Alice, 1991. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1991 Evinrude E6REIA 6hp Outboard Motor Parts by Engine Section
1991 Evinrude Parts
Mar 24, 2016 | Boating
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
Jul 31, 2012 | Light Outboard Motor Boat Bass Fishing...
Johnson 6hp outboard engine fuel pump diagram
Here is where you can get a service manual, they have a lot of info you might need...
Johnson Evinrude Manuals 1917 2007
Jun 11, 2012 | Johnson Boating
Cooling system outboard
Sounds like you burned up the impeller on the water pump. You will need a replacement part and when you install it, do not run the motor out of the water. You will be lucky no other damage was done.
May 10, 2009 | Boating
CHANGE WATER PUMP IMPELLER FOR EVINRUDE OUTBOARD MOD# E28ESLETD
Crowley Marine Boat Parts & Diagrams have diagrams of all the components, and the catalog is easy to go through to pull them up, OEM and other brands, no cost for the images.
Mar 19, 2009 | Boating
Northern Tool 12 Room Purple Martin House Logo
48 people viewed this question
Top Northern Tool Garden Experts
Vernon Taylor
jeff chenault
jeff chenault
Are you a Northern Tool Garden Expert? Answer questions, earn points and help others
