Question about Samsung Dryers
Just bought a DV50F9A7E dryer. Work fine for a month, but now when we start it, it will only run for a couple of mintues and then shut off. Any idea what's wrong?
  • 10 Answers
SOURCE: Kenmore dryer doesnt heat
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Posted on Dec 19, 2008
  • 19 Answers
SOURCE: Whilpool Dryer Won't Run
you have a bad saftey swith inside te dryer this cost anyware for $8.00 to $ 15.00 for the part
Posted on Feb 01, 2009
  • 686 Answers
SOURCE: Kenmore dryer shuts off
do you store clothes on top of it while it's running? If yes take that stuff off of there and NEVER use it for anything i mean anything. I know it makes a good table top but you are killing it by not letting your sensors do there job correctly.Believe this i know from trials.
Good Luck
Posted on Feb 26, 2009
  • 55 Answers
SOURCE: dryer rune for a bit then shuts off - won't start
clean link from bottom of dyer and exhaust vent
Posted on Aug 07, 2009
caroldon
  • 17130 Answers
SOURCE: dryer does not run has power front panel lights
Can be that the door switch had been damaged and it could be a reason that the safety circuit is not contacting to give the control board an OK to proceed.
So check at the lock point for the switch and test with a multimeter in Ohms to see if this contacts.
Posted on Sep 29, 2010
Samsung dryer DV218AEB shuts off in middle of dry cycle - "dead" mode
This is a sign of a bad motor. There is an overload protector on the motor that when the motor overheats it shuts the motor down.
May 01, 2012 | Samsung Dryers
We bought a Samsung DV419AV dryer less than a year a go. tonight my wife went down to dry a load of work close for tomorrow and set the drying cycle and pushed the start button. you can hear a hum but the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Dryers
Running just fine then just stop but starts back up after a few mintues
With the little bit of information I have two ideas.
1) fuel filter
2) fuel pump
Feb 09, 2010 | 1991 Buick Park Avenue
Won't start
maybe a short that's causin it not to start
May 27, 2009 | 1995 Chevrolet Blazer
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
I have a 93 altima that will crank but will not start...about a couple months ago i went to my work and shut off my car. it was running fine when i shut it off.. when i came back out and started my car...
this year model is notorious for fuel related probs...check the remainder of the fuel system, injectors, and the fuel pressure regulator also verify that the fuel pump is actually running and getting the correct amount of power to the pump itself..... it may not be bad just not getting enough power
Jan 24, 2009 | 1993 Nissan Altima
1993 altima will crank but will not start..
replace the distributor oil is leaking into the electronics of the distributor and shorting out pull cap back off and look and see if oil is leaking out
Kenmore dryer
ok im still with you ,,,,now what i need you to do is start dryer and listen to the gas vavle ,,it will click once than a couple of seconds it will click again,,than you should hear the gas light,,now your at left corner listing,,if you have no clothe in dryer the flame should stay on about 3-5 mintues..after the dryer heats up and shuts of it should come back on in about the same time 3-5 mintues,,listen for rattling or not clicking open the second time around,,if this is the case replace dryer vavle coils,,keep me posted,,onthejob..if the ignitor sensor were bad it would not light at all.they rearly go bad...
Jan 10, 2009 | Kenmore 63942 Dryer
Dryer shuts off after a few minutes
THE KENMORE DRYER I HAVE... IF REN IN THE COTTON CYCLE IT WILL RUN FOR 50 MINUTES AND SHUT OFF. ITS BOLWING HOT AIR AND THE OTHER CYCLES SEEM TO WORK FINE WITH OUT SHUTING DOWN SO ID APPRECIATE A TIP ON WHAT THIS PROBLEM COULD BE
May 17, 2008 | Dryers
Zanussi TC484W
There may be a capacitor in the motor circuit which has shorted out. The capacitor helps the motor start. If the capacitor is shorted, the motor won't start by itself, but will run fine if urged by hand. Good luck.
Feb 06, 2008 | Zanussi TD4212W Electric Dryer
Dryers Logo
48 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
