Question about Toys
I need to know how to rebind my Walkera VD450D03 to Devolution 7
Had a minor crash and although the Rx flashes red it wont bind with transmitter
4 Suggested Answers
SOURCE: I have a new Walkera 5#10. The Tx binds with the
Hi, well I indeed love my Chopper, and have had a few problems with it too...Usually though it has been connections, or the battery, or a jammed motor/servo/gears... I haven't yet found an actual faulty electronics, per sa.
So what you need to do is inspect ALL plugs clips switches & joints, if any are suspect, or the wires broken off then simply resolder, or even tightly wrap the wire around the terminal in a pinch.
See if you can swap over the servos/motors over to see if the motor/servo is faulty? If you swap and the problem "Follows" then that servo/motor is the faulty one.
basically the receiver sees the data stream that tells the servos what to do and how long to do it for.. So it can only be one of a few things to work through.
Posted on Dec 17, 2010
  • 234 Answers
SOURCE: My Honeywell CM921 wireless thermostat is showing
Take the cover off and see if there is a reset button (usually recessed so you need a pencil or wire to push it. If that doesn't work check on the circuit board for a blown fuse. It might be like a car fuse 3-5 amps.
Posted on Sep 20, 2014
MrARCADIAN
  • 284 Answers
SOURCE: My tqi transmitter blinks red with new batteries and will not bind with any receivers
you might have to reset the unit, IP possibly got changed, if you changed the battery. check IP address on the unit.
Posted on May 24, 2015
My tmaxx goes out of control full open throttle and i'm standing 15 feet away. i don't think it's the batteries in the receiver.
Hello try to rebind your transmitter and esc, check your antenna to see if it's broke ,double check and make sure your batteries are fully charged on truck and transmitter,if that all checks out you may have a bad esc or transmitter. let me know what your results are thanks M.B. 2ce7b37f-06d5-47b8-bf19-47612dc686ad.jpg
Jun 17, 2014 | Traxxas T Maxx 3.3 Monster Truck
DV04 not recording video
I have the same problem. The video records on the SD Card (Kingston). It records for only 1-2 seconds then stops. The transmitter to the radio unit is fine as I can see it on the screen at all times. It is the recording function that is the problem.
Apr 03, 2014 | Walkera DV04 FPV Recording Video Camera
I have a new walkera uflys (rx-2435) when i get it up off the ground it spinnes round and round how do i fix this problem
sir jeremydylan2
you have a problem with your rear rotor assembly.
if your rear rotor shaft is broken or the gear is the copter will spin around and around.
or, if these parts are not broken then your trim needs adjustment or, you need to learn to fly and control the rear tail rotor so it does not spin around. Thats your answer. thundermounts@gustywinds.com
Feb 18, 2011 | Walkera Toys
My upper rotor does not always power up when i throttle up on my walkera 5#10. i have replaced motors with new factory motors thinking that was the problem but same problem
Hi, I had this same problem but its my bottom rotor that wont throttle up. Before you bind put the throttle in full. After it binds return the throttle to min. and its ready to go. I hope this helps, although its not a fix. It a cheap one $$$.
Sep 16, 2010 | Walkera HM5#10 RC Helicopter
Changed battery and still does not work - hear pinging in computer
There are buttons on the transmitter/receiver and the mouse(small red on bottom). Turn off the mouse. Plug in the USB Tx/Rx and hold down the button. Then press the red button on the mouse and hold for one second. Do this until the rapidly flashing light on the Tx/Rx slows down. The unit's frequencies are then encoded/decode and can communicate.
Jun 13, 2009 | Targus PAWM001U Mouse
Receiver problems right out of the box!!
You may have to "bind" the receiver to the transmitter again. See the instructions that came with the transmitter on how to do this. If this not the problem the hobby shop is obliged to make sure it works so take it back before it get damaged.
Mar 16, 2009 | Walkera HM5#10 RC Helicopter
Remote not workin
what's happened here is the cm61 ng and the reciver box have lost there connection you will have to "rebind" them then it will be fine -
THE BINDING OPERATION DESCRIBED BELOW IS REQUIRED IF:
· Any of the system components (room unit or relay box) are replaced
· HC60NG has incorrect or no binding data stored (e.g. when pre-bound system pack components have been mismatched)
· Interference with the RF signal has caused a communication failure
During the binding procedure keep approximately 1m distance between the room unit and the HC60NG
1 Turn off mains supply to HC60NG for 10 seconds. Re-connect supply.
2 Press and hold the HC60NG push button for 15 seconds to reset previously stored data. The red LED will start to flash at 0.1 s on/0.9 s off. Release the push button.
3 Press and hold the HC60NG push button for 5 seconds to enter the binding mode. Red LED flashing at 0.5 s on/0.5 off confirms the binding mode has been entered.
4 Move the CM67NG slider to the OFF position (CM61 push the OFF button) and press the TEMP , TEMP and PROG 1 buttons together. The CM61/67NG will display InSt.
5 Press the i button to send the binding signal. The red LED is switched off on the receiver box to confirm the successful binding operation. If the red light still flashes push the repeat steps 1-3 and press the the i button until binding is successful.
hope this is helpful
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Toys Logo
50 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
