Question about Hayward Pool & Spa
Swimming pool heater not getting hot
Not igiting
    Top Expert:
  • Hayward Master
  • 6,465 Answers
If power going in and transformer has voltage check safety circuit also check ignitor
Posted on Mar 19, 2016
  • 11 Answers
SOURCE: Swimming pool cleaning robot doesn't move
Sound like your filter is dirty. Try backwashing if you have a sand filter, or clean your cartridges if that's what you have. A dirty filter will reduce water flow, which in turn affects the Nav.
Posted on Jan 02, 2009
john224
  • 1378 Answers
SOURCE: Pool heater cabinet gets so hot it burned the wires
That condition is from rollout of the burner flames. Check the underside of the heater top for a buildup of debris. Clean it if necessary. You may notice your heat echanger looks like a BBQ pit. If so it is sooted over and needs to be thoughouly cleaned before further use.
If you find this condition, you should also look at your burner tubes once the exchanger is cleaned and the heater is operating. Be sure the flames are nice and blue and 3 or 4 inches tall. If they are not, and especially if they are mostly yellow/orange, you need to do some more inspecting for what is messing up your combustion, which would have led to the soot.
Finally, if none of the previously mentioned conditions exist, consider wind pressure over the top of the heater. In windy areas and in certain installation conditions, you may needa high wind stack to provide positive drafting of exaust gas.
Posted on Jun 26, 2009
greenspan
  • 1734 Answers
SOURCE: i need the electronic schematicfor swimming pools
Ask the schematic finding experts -
They will get it for you.
http://manualfox.com
Posted on Jun 30, 2009
johnsonr1
  • 91 Answers
SOURCE: I have a versa gas heater for my above ground
I have often found spiders or other **** nesting in the pilot tubes of these boilers which blocks the flow of gas. You will either need to have it professionally serviced or you can attempt to do it yourself, which I do not recommend.
Posted on Aug 22, 2009
  • 112 Answers
SOURCE: swimming pool heater
You have to circulate the water or it shuts down.
Posted on Sep 03, 2009
Water in the air lines
Swimming Pool and Hot Tub Spa Heater Operation ...
www.poolandspa.com/page811.htm
In a pool and spa heater, the burner is typically located in a heater's ... Heat loss, The natural drop in water temperature as heat is transferred to the surrounding air. ....Terminals 1 and 2 are the neutral and positive lines from the pilot generator ...
[PDF]SERVICE & INSTALLATION MANUAL - Hayward
https://www.hayward-pool.com/.../UniversalH-seriesLowNOx-HxxxFDS...
heater and to all metal parts of swimming pool or spa, and to all electrical equipment,... stream of water (not air or air and water) is discharged. ...... Unplug the in-line quick connect on the red wire in the heater wire harness, and connect the.
Jan 13, 2016 | Pool & Spa
It tries to fire once and fails. heater service lite then comes on. The LED red lite on the Fenwl Box blinks 3 times indicating ignition lock out. What do we do to fix this problem?
Hot Tub Spa - Heater Troubleshooting Guide - PoolAndSpa ...
www.poolandspa.com/page596.htm
The World's Oldest & Largest Web Site For Swimming Pool & Hot Tub Spa .... close to the element, and the pump suddenly quits - it's dry fire time in just a minute or two. ...We think it's a safe bet to say that one of the major causes of heater failure ... It's much easier to describe what doesn't cause it than to attempt to explain ...
Spa and Pool Heating Problems - Swimming Pool Information
Jan 05, 2016 | Pool & Spa
Pool heater not igiting
if voltage at gas valve bad valve replace if no voltage to gas valve check safety circuit
Apr 20, 2014 | Hayward Pool & Spa
How long does it take to heat a spa pool?
All depends on the amount of water in the spa or pool, and the size of the heater in BTU's. The time for "Heat Rise" will vary and the answer you are looking for can't be provided with amount of info you provided. But if a general rule of thumb - the closest answer: Spa with a gas heater, 1 degree about every 90 - 120 seconds. Electric heater (vary's by KW) on average: cold to hot = 8-13 hours. Swimming pool with gas heater (no suggestion for electric) about 1 degree temp rise every 90 minutes.
Dec 27, 2013 | Pool & Spa
Hello I have a tankless water heater I was wondering if you could use it for a swimming pool or hot tub
For a hot tub....meaby, You have to add a pump and a couple thermostatic switches for minimum and maximum temp. For a swimming pool will be easy .Bunch of water will not really need thermostatic switches but you also need a pump and probably a timer so you will not run it more then 20 minute at a time so you will not kill it quick.by self destruction !
Feb 02, 2013 | Water Heaters
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
try removing and cleaning flame sensor with fine steel wool.its located in lower end of burner box,usually opposite side of ignitor
Sep 02, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a versa gas heater for my above ground swimming pool. This year the pilot will not light. It gets hot but will not ignite. Any ideas what could be wrong?
Jul 11, 2009 | Raypak Versa 130,000 Btu Above Ground...
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Pool & Spa Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
