Question about Husky Pressure Switch
Husky Pressure Switch 9063138
9063138
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
May 14, 2014 | Homelite For Husky - Pressure Washer Pump...
Husky deckmate
Looks like it might be a faulty/sticking pressure sensor/switch on the pressure side of the unit.
Mar 10, 2014 | Garden
How to adjust cut in pressure on husky 60 gallon
what is the pressure switch model number, most of them have a nut with a spring under them, just turn the nut to adjust the pressure
Oct 21, 2012 | Husky Electric Air Compressor: 60-Gallon...
Motor cuts off before reaching 125 psi
Im guessing this is a recip (piston Compressor) Sounds like your pressure switch may have adjusted itself by vibration. Take the cover off the pressure switch, there should be 1 or 2 screws on the top, one adjusts the pressure, the other adjusts the differential pressure (There may just be one) turn the pressure screw in the direction of the +, you need to do trial and error on this, turn it 1/4 of a turn, then switch on, see what the pressure gets to, then switch off, drain some air off, then adjust as necessary until you get your required pressure. Hope that helps
Aug 31, 2012 | Husky Air Tools & Compressors
Compressor reaches 125 psi but does not shut down
Depending on how old your compressor is, usually inside the pressure regulator cover are instructions on how to adjust the turn-on and shut-off pressures. If not, it usually invloves turning a nut or screw to lessen the pressure on the spring that keeps the contacts closed. Try adjusting the pressure down. If it won't come down to a safe level you will be better off replacing the pressure switch. The number you give above is the Campbell-Hausfeld (they are Husky) part number for the pump and motor assembly so I don't know which CH pressure regulator you need. They are easy to find and easy to replace.
Jun 21, 2012 | Square D 9013FHG14J52M1X Air Compressor...
Can I adjust the tank pressure on a Husky 1506 compressor. pop off keeps engageing, so I need to adjust so that compressor shut off automatically
Before you change any parts, check that the pop valve is not faulty. Look closely at the pop valve to read set release pressure. If the valve is releasing before marked reading, replace valve instead to one slightly higher. The pressure may or may not be adjustable at the switch (need to replace the switch) depending on switch installed at the factory (parts list does not give enough information). If your switch has a remove-abel cap with adjustment screws/nuts, post again with model number of switch for info on adjustment. Good luck
Oct 06, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
May 27, 2010 | Air Tools & Compressors
Husky 25 gallon air compressor turns on and off Y6020-WK
Pressure switch setting is off. Readjust to Mfg. spec. (on @ 60/off @ 8o...)
Sep 03, 2009 | Air Tools & Compressors
Husky 17gal 5hp compressor will not cut off when it builds up pressure. Pressure valve will pop open and then I cut it off buy hand
bad pressure switch or it is wired incorrectly replace switch and check the wiring or could be out of adjustment you compressor is made for max 125psi should be a screw to adjust on the pressure switch near where the wires are connected back out counter clockwise to lower and see if that turns it off
Feb 20, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky Pressure Switch Logo
107 people viewed this question
Top Husky Air Tools & Compressors Experts
Lawrence Oravetz
Gil Shultz
ray gallant
Are you a Husky Air Tool and Compressor Expert? Answer questions, earn points and help others
