Question about Hitachi 53UDX10B 53" Rear Projection Television
Model 53uox1ob my grandchild had the remote and some how got spanish on wife took the remote and was pushig buttons trying to get it off.she did finally. but next morning tv would not come on.I TRIED unplugging it for ten minutes still did not come on.I tried channel up no again.I took the back off their is 4 green lights on and one red.I saw a fuse like the old cars had 125 watt it said. the metal strip inside was not melted.because that fuse was not melted inside could the fuse still be bad.any help I would apperciate.Bo
  • 4,402 Answers
Re: model 53uox1ob
I thought there should be are 5 green LED's and one RED one. All of them should be on if the TV is working properly.
There are PICO fuses that blow when a circuit is not working and the assosiated LED will not lite. If a LED is missing it means there is a problem in the circuit and should be fixed prior to replacing the PICO fuse.
A common problem is with CONVERGENCE IC's that go bad. Your set has a MAGIC FOCUS FEATURE that when pressed on the front panel of the TV could be quite entertaining for a youngster. Pressed repeatly
might damage the circuit. The inside LED, lit or not, would point you in this direction.
If you decide to investigate by taking the back off be warned that there are voltages that may cause injury. I would suggest calling a serviceman to determine why your set will not power up and display a picture.
Posted on Jan 04, 2008
0 characters
3 Points
Please provide the English language for entering the code to get a universal remote to work with my tv
Since you did not provide the model number, unfortunately I cannot give you the exact information, but check this page out and see if it has information that will be useful for you:
Dec 27, 2014 | Philips Magnavox 51MP392H Rear Projection...
Audio in spanish
What make and model television? Is there an SAP (Secondary Audio Program) button on the TV or remote?
Mar 29, 2014 | Projection Televisions
I have Sony Grand Wega KDF-55E2000. While my 3 year grandchild was visiting she was playing with remote and now I have System Status and Path A Status screen displayed that I can't remove. Please help!!!!
The easiest way is by resetting the tv itself back to the factory setting.Just unplug,replug the tv back like about an hour later.This should remove itself.
Nov 22, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Channel trouble
In ur remote have a button said Audio push it make sure it not on Audio2 that why u getting some mute channels and Spanish languages.
Mar 17, 2010 | Panasonic PT-56DLX25 56" HDTV
Sound goes out for certain programs or commercials on different channels, but not all of them
Check your tv's audio settings. If there is an "SAP" button on your remote try hitting that. It stands for secondary audio program. Most manufacturers put it near the corners of the remote leaving it prone to getting hit without knowing. Most shows are broadcast with a spanish version of the audio. Hitting that button should allow you to hear it, but some tv networks do not broadcast the SAP audio making it seem like there is no audio. It usually affects more than one channel, and commercials do not broadcast SAP either.
Jan 20, 2010 | JVC AV-56P575 56" Rear Projection...
No sound on some channels
your tv has audio setting called SAP that is for channels that are broadcasting on a second language like spanish, on the channels that do not have this SAP capabilitie you will not hear anything unless you put your tv on stereo mode, so you need to go out of the Sap mode by a button on the remote, check for mts, button , or audio thank you
Jun 21, 2009 | RCA R52WM24 52" HDTV Projection Television
Need remote codes for Ilo TV.
Turn on TV and press the TV button by aiming it to TV, the red LED light will blink once. Press the MUTE/SEARCH button. The LED will shut off first then light up. When the TV turns off, press the OK button to store this code.
Please do rate this solution as FixYa and revert for further assistance.
May 10, 2009 | Projection Televisions
My tv is on spanish how do i take it off
Spanish on the screen or Spanish through the speakers on some channels? If its the on-screen display that's in Spanish, you pick the language using the setup menu with the remote control. If you're getting Spanish through the speakers, you probably have turned on the SAP (second audio program) function. In some areas with a large enough population, SAP is often used to broadcast program audio in a different language. On channels with no SAP broadcast you don't hear any problems. The SAP function is usually controlled by a button on the remote and probably got pressed by accident.
Dec 01, 2008 | Hitachi 51F500 51" Rear Projection...
My tv is stuck on spanish and i don't have the manual and the remote want work anymore all this happened last night please help
It sounds like your SAP (secondary audio program) is on. Can you go into menu by pressing a certain button or buttons on the set? If not, try unplugging overnight or for a few days to see if it will reset.
Jul 25, 2008 | Projection Televisions
Hitachi inspire projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Dec 02, 2007 | Projection Televisions
Hitachi 53UDX10B 53" Rear Projection Television Logo
41 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
