Question about Cell Phones
Battery S788 for hitel mobile phone - Cell Phones
Tip
Recharging of mobile phone battery
its very adviceable to make your mobile phone battery in charge for just 2 hour and 30 mins.
try to avoid recharging battery without low battery idication.
use only original charger.
use only original battery for long life..
dont place mobile phone near any other electrical or electronic goods.
on Mar 20, 2010 | Cell Phones
Tip
IS YOUR MOBILE PHONE IS SAFE TO USE ?
Mobile have become a part in our life as mobile technology is developing day by day new mobiles are arriving in the market day by day
Have you ever checked that is it safe to use ?
Beacuse their are incidents like exploding mobile phone
mobile phone emits radiation etc
a simple mobile phone does not make such severe problems
All the problems are coming from the Battery of the mobile phone
they are responsible for emitting radiation and exploding and also over heating
and not mobile device or not the tower of service provider is emmiting radiation
If you wants to remain healthy Keep the mobile phone away from you and reduce the usage of it
when you talk or send SMS or using internet the mobile will take power from battery and
the battery produce charge with some chemical reaction
so when this chemical reaction takes place it emits radiation which cause cancer etc
Tips to make your phone safe to use
1) Dont talk or use mobile phone when the phone is charging its battery
2) Hold Your phone in hands or keep it inside bag don't put any where else
3) Only Charge your mobile when it shows " LOW BATTERY "
4) dont use mobile if any water particals get inside the phone
5) use only orginal battery
6) Dont over charge your mobile
7) Dont talk more than five mintues in your mobile phone
8) Use the mobile to talk only when the network signal is high else use sms facility to communicate
9) Change the mobile battery as soon as possible if it damaged
10) Use only original charger to charge the battery
11) when you try to remove battery make sure that the phone off
12) if the phone is not using in long time remove battery and keep it safe
13) Dispose the battery safely if its life is over
on Feb 02, 2010 | Cell Phones
My phone switch on and white display and restart it why this problem solution
If you see white screen for a long time and after that your mobile get switch off then I think this is a battery problem. This problem also occurred when your mobile don't have charge and you try to switch on your mobile phone. make sure your mobile phone is properly charged. If you charged your mobile phone regularly and you still not able to switch on your mobile, then try to place new battery in your mobile and then try to start your mobile phone. hope it works for you. Or there may be chance of virus, but I'm not sure. Better you check for it. if your mobile don't support any antivirus then try to scan your mobile with connecting pc. You can connect your mobile phone to pc. And then scan your mobile for virus. If you found any virus then remove it from your mobile. If not found, then definitely its not a virus.Then it is the problem of battery. thanks
May 15, 2011 | Computers & Internet
BATTERY
I am using the same mobile.This mobiles have this bateery problem. Even my mobile has it.I tried changing the battery also but the problem presists. Nothing can be done.
thanx
Jul 21, 2010 | Nokia 6300 Cellular Phone
New cell phone battery trouble
Dont talk or use mobile phone when the phone is charging its battery and charge your mbbile battery for 10 hrs continusly before intinal use Only Charge your mobile when it shows " LOW BATTERY " Dont over charge your mobile Use the mobile to talk only when the network signal is high else use sms facility to communicate Use only original charger to charge the battery
Oct 22, 2009 | Sony Ericsson TM506 Cell Phone
Nokia E71 power on / off issue
i think that you might have not properly charged your batterry before first use it is being noted that all mobile manufacture recommends at least 10- 15 hrs of continus charging of the battery with the phone swtiched off is needed to work effectively in the future if you do so life of the battery will incress and you can incresse the back up of the battery and it is proven also so charge the battery well and try and remeber only recharge the battery agin when a battery low signal is shown
these are some tips :
Dont talk or use mobile phone when the phone is charging its battery,
Only Charge your mobile when it shows " LOW BATTERY ",
dont use mobile if any water particals get inside the phone ,
use only orginal battery ,
Dont over charge your mobile,
Use the mobile to talk only when the network signal is high else use sms facility to communicate,
Change the mobile battery as soon as possible if it damaged,
Use only original charger to charge the battery,
when you try to remove battery make sure that the phone off,
if the phone is not using in long time remove battery and keep it safe,
Oct 20, 2009 | Nokia E71 Smartphone
Poweron the lg shine
Seem you mobile phone battery is not working well try to get some one with the same mobile phone and change the battery and see if this works or else if you mobile phone has a warrenty go and claim it .if your that battery thing dosn't work then it mighy be the serious problem with your mobile phone
Sep 14, 2007 | LG Shine KE970 Cellular Phone
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
