Question about Cub Cadet Garden
Mower runs good and fast on level ground just about comes to a complete stop on incline.Why?
The tractor runs what appears to be full speed on level ground however when I went to go up an incline /hill the tractor just about came to a complete stop. This particular incline is the same one this tractor has been handling just fine since i bought it 3 years ago . What would the problem be ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Dirty oil in trans replace it with new filter to
Posted on Dec 17, 2014
  • 40 Answers
SOURCE: My 550 series motor won't run except on the prime.
one of your fuel lines are bad and it is losing its prime
Posted on Sep 05, 2009
bbreton
  • 437 Answers
SOURCE: troy built lawn mower (riding) won't go full
I did not know riding mower had a gas pedal. I know if you leave the throttle control up all the way the engine will choke out. The pedal you are pushing, I think, is the forward/reverse hydrostatic transmission. You may need a new drive belt. The one you have now may be stretched out.
Good Day.
Posted on Oct 07, 2009
  • 885 Answers
SOURCE: My 22" MTD Yardman push
These inexpensive mowers are not made for large scale mowing. They're set to run as fast as they do and have low compression (read that as low power also) to make them easy to start and operate. About the only thing you can do to make it work better is keep the air cleaner clean, use fresh gas and keep the blade sharp so it cuts the grass easier. Mowing more often also means less cuttings under the deck so it works more efficently.
Posted on Aug 31, 2010
SOURCE: Poulan 550 Series push mower won't pull start
Poulan 550 series self propeeled mower. Mower starts and stops running after 10 seconds. Gas tank full. Filter cleaned.
Posted on Sep 17, 2010
SOURCE: Toro 6.5 hp Mower Model
The linkage on the top of the carb should go to a spring loaded arm that goes into the side of the motor. Work the lever back and forth and see if it works the carb. If it does and everything is in place your governor mechanism inside the engine might be damaged.
If the arm isnt working the carb it is probably bound up or attached to the wrong hole in the carbs throttle lever. There should be two holes and one of them would force the throttle wide open everytime reguardless of what the governor arm tries to do.
Posted on Oct 11, 2010
John Deere 430, Sundstrand series 15-U hydrostatic transmission. The tractor, at low ground speed, surges as it moves, in both forward and reverse, at any engine speed. At full ground speed, the surging...
you sure your engine isn't surging... you would see it at lower speeds... my motorcycle surges at a certain rpm due to fuel ratio's at the one speed ( running lean )... so what i am saying is, could it be that the engine surge only shows itself at a certain ground speed.
or is it because of a hydro system pressure relief valve ???
Oct 08, 2013 | Garden
Lawn tractor loses pull going downhill & then grabs and continues on. Works fine uphill.
it's a safety feature to keep the mower from getting going to fast downhill and out of control
Jul 19, 2012 | Garden
Speed of tractor slows when I run for more than 10 minutes. It will not climb a small incline after it gets hot. I can let it cool for a half hour, then it runs fine untill it gets hot ,and eventuall will...
you need to call a dealer and get a price to replace the transmission. perhaps you can swap yours for a rebuilt tranny. If you are at all mechanical, you can change the transmission yourself in an afternoon, so some cost could be saved on labor.
Apr 24, 2011 | John Deere 22HP VTwin 48" Riding Mower
When engaging mower blades speed drops or stops
Check throttle cable at carb and make sure you have full travel. Sounds like rpm is little to low. Throttle cables are usually held in place with 1 screw and a washer. Put cable at full throttle loosen screwand pull back until throttle at carb in at full then tighten screw.
Mar 07, 2010 | Garden
I have a yardman 46 in cut riding mower, it is leaving grass in the middle. I have put new blades, change the belts, put on a new tention spring, so what is my problem?
Well one of the spindle assemblies, could be running a little slower on one side then the other. But I would take a guess that you are trying to cut grass, way too fast for the mower. Try running a ground speed a liitle slower and see what happens.
Good Day.
Oct 07, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 19hp craftsman 42 deck. It has two blades. It does not cut the grass in the center. It leaves a strip uncut. What adjustment should I do
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 2005 husqvarna lawn tractor. 24 hp, 48 in deck, the transmission runs fine on level ground but when i go to an incline the tranny slips and i hear a clunking sound, and if i travel farther up hill...
sorry. I don't have an ansewer for you however I might have some helpful hints. Your mower should be going dam near 5 MPH. But yes can't cut in reverse. you have a belt going from the trans axle to the motor. It could be slapping against the frame. The idler puller or the tension pulley could be wobaly where the bearings are gone out. If you remove the 4 bolts on the back of the mower under the seat and gas tank it should visable tell you the story. My question is mine hits gears real hard as if trans mission needs oil or internal damage.
May 09, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
90 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
