Question about Hayward Pool & Spa
Pool heater not igiting
Pool heater not getting any gas
    Top Expert:
  • Hayward Master
  • 4,290 Answers
If voltage at gas valve bad valve replace if no voltage to gas valve check safety circuit
Posted on Mar 19, 2016
2 Suggested Answers
SOURCE: My gas pool heater is banging
Hayward, gas heater... a metal clinking noise and the hoses doing a twitch every 5 to 20 seconds. my experience says it is that diverter shield has come loose...disconnect everything. unscrew the in and outlet connections.look into the hole, you will likely see a metal, plate with two half circles, one facing the inlet hole, and if you go around to the other side you will see the other end of the plate, with a half circle. this plate comes loose, whatever they use doesn't last.
one guy used a small hose clamp to keep it from sliding up and down the post, I used that two part plumbers putty, to "weld" it in place....homedepot, comes in a small cylinder, it's two part, you cut off a piece and mold it in your hands, worktime is only 3 min. cures in an hour.... no more clinking metal or twitching hoses.
Posted on Jun 11, 2010
Hayward H200P1 Pool Heater- need to convert propane to natural gas
all the parts needed will be in the kit. usually, its the control valve and the jets that get replaced. my manual shows its the same part all units. HAXCNK0002
Aug 09, 2014 | Hayward H Series Pool & Spa Heater 200k...
Swimming pool heater not getting hot
if power going in and transformer has voltage check safety circuit also check ignitor
Apr 20, 2014 | Hayward Pool & Spa
Jandy LX250 pool heater won't light - trips out after 3 attempts on "AGS Fault" - gas valve is getting 28V when needed and you can feel it click, and igniter is glowing fine - not getting the brief whiff...
Yes, it is either the gas valve or the gas supply that is the problem. Can you check the gas pressure with a manometer? How old is the heater? Gas valves go about 10-15 years on average.
Aug 13, 2013 | Honeywell Vr8305m4231 Pool Heater Gas...
Conversion for Hayward H200 Ing Pool heater from propane to NG
I have a hayward h-2001 natural gas heater that I wish to change to propane. perhaps we can swap parts. dbkohl@prodigy.net 920-324-5652
Jun 01, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
Heater Wont light
If it has been off for a while you probally just have to bleed the gas line out. Shut off the gas valve at the heater and then open the union at the heater. Turn the gas back on till you can smell gas. Shut it down and close the union then turn the gas back on and try it again.
May 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Pool heater will light then turns off
check gas pressure you should be getting about 10" water coloum
May 31, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool heater Maintenance
Pool Heater Maintainance - Gas Pool Heater Gas heaters are the most common type of pool heaters being used presently. The gas heaters work on natural gas or propane tanks. The gas heaters are favorite hide out of spiders and other insects. It is recommended to regularly clean the spider webs and the debris off the heater. For it can clog off the burner openings. You can clean them manually or with the help of a vacuum cleaner as well. The most important thing about maintaining the gas pool heaters is to check the gas supply regularly. Check out the pipes to detect any leakages. You can easily detect the leakages using a soap solution. Prepare a liquid dish soap and warm water in the spray bottle. Now spray the solution on the pipe joints. If you find any bubbles emerging from the surface, you immediately need to repair the pipes. Never use the heater until the pipes are replaced or repaired by a qualified plumber. Pool Heater Maintainance - Electrical Pool Heater Electrical pool heaters are also getting popular these days. The heaters produce the heat with the help of heating elements. The element can get coated with certain minerals present in the atmosphere. This hampers the heating process. You can easily take it out and clean with a wire brush. Some elements get damaged beyond repair. You have to replace the element. Take along the old element with you while looking around for a new one in the market. It is absolutely vital to change the element otherwise it can send some current in the swimming pool. First of all, turn off the power supply to the heater to avoid any injuries. Open up the drain pipe and take out water from it. Fix the new element and test the heater by filling water in your swimming pool so that the heater can work to its full efficiency.
Aug 27, 2008 | Raypak DOOR ASSEMBLY
Pool & Spa Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
